查看: 1844|回复: 0
[NI软件产品] NI RFmx CDMA2000 2.0 Full Win32/64ENG完整版下载
    发表于 2022-3-29 12:58:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:
    2015/10/16
    包含的版本:
    2.0完整版
    Windows Server 2008 R2 64-bit
    Windows 8.1
    Windows 7
    应用程序位数:
    32/64位
    语言:
    英文
    文件大小: 677471008 字节 (646.09 MB)
    修改日期: 2015-10-16 05:10
    MD5: efcab024ad6790b3803b34c6540d2de4
    SHA1: 4124e3ff6214fa0ca03fdaa0f094fd118ff7aa74
    SHA256: cdd4159d9b225c8c7aeb2bd86f6699698ffb0f71f1644c23d71ce3fa7ef2a9e9
    CRC32: 1df12266
    注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 2.0.txt (500 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx CDMA2k 2.0 Readme
    October 2015
    Thank you for using NI-RFmx CDMA2k. This file contains important information about NI-RFmx CDMA2k and is organized into the following sections:
    Caution  Before you install NI-RFmx CDMA2k 2.0, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers requires that all the installed driver versions remain the same for proper functionality because NI-RFmx drivers use shared components between them. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    NI-RFmx CDMA2k 2.0 supports the following operating systems:
    • Windows 10 (32-bit and 64-bit)
    • Windows 8.1 (32-bit and 64-bit)
    • Windows 8.0 (32-bit and 64-bit)
    Note  NI-RFmx CDMA2k 2.0 does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—2 GB*
    • A screen resolution of 1,300 x 700 with 256 colors
    • Windows 10/8.1/8.0/7, with all available critical updates and service packs
    Recommended System
    • RAM—4 GB*
    • NI LabVIEW 2013 SP1 (32-bit and 64-bit) f6 patch, 2014 SP1 (32-bit and 64-bit) f3 patch, 2015 (32-bit and 64-bit) f1 patch
    Note  NI-RFmx CDMA2k does not operate correctly without the LabVIEW service packs and patches mentioned in the preceding list.
    Note  Install NI LabVIEW before you install NI-RFmx CDMA2k. To add support for ADEs installed after installing NI-RFmx CDMA2k, modify your NI-RFmx CDMA2k installation or relaunch the NI-RFmx CDMA2k installer.
    Other Required Software
      • Windows 10 (32-bit)/8.1 (32-bit)/8.0 (32-bit)/7 (32-bit): Program Files\National Instruments
      • Windows 10 (64-bit)/8.1 (64-bit)/8.0 (64-bit)/7 (64-bit): Program Files (x86)\National Instruments
      • Windows 10 (32-bit)/8.1 (32-bit)/8.0 (32-bit)/7 (32-bit): windows\system32
        • 32-bit DLL: windows\SysWow64
        • 64-bit DLL: windows\system32
    ItemInstalled Location on Windows 10/8.1/8.0/7
    LabVIEW Examples\LabVIEW \examples\RFmx\CDMA2k
    Select Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Measurement Interactive Panel to launch the NI-RFmx CDMA2k Measurement Interactive Panel.
    Documentation for NI-RFmx CDMA2k is located at Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx CDMA2k HelpHTML/Windows HelpInformation about NI-RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx CDMA2k
    • A complete reference for all NI-RFmx CDMA2k programming functions
    NI-RFmx CDMA2k 2.0 ReadmeHTML (this document)Information about supported hardware, supported operating systems, and legal notices.
    Accessing VIs and Functions
    NI-RFmx CDMA2k palette VIs are available from the Functions»Measurement I/O»NI-RFmx»CDMA2k palette.
    You can access all the installed NI-RFmx CDMA2k examples at Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Examples.
    Uninstalling/Modifying NI-RFmx CDMA2k
    • Select NI-RFmx CDMA2k 2.0 from the dialog box that appears.
    For Windows 10/8.1/8.0, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-RFmx CDMA2k 2.0 installation, the following software is installed. To completely remove the NI-RFmx CDMA2k 2.0 installation from your system, you must also remove the following package:
    • NI-RFmx CDMA2k Runtime 2.0 for LabVIEW
    You can access the software and documentation known issues list online. Refer to the NI-RFmx CDMA2k 2.0 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx CDMA2k 2.0.
    When developing memory intensive applications, you may encounter memory limits because 32-bit Windows applications utilize only 2 GB of memory by default. To expand the amount of memory an application can utilize, you can configure the executable to be large address aware to gain access to up to 3 GB of memory on a 32-bit Windows operating system and up to 4 GB of memory on a 64-bit Windows operating system.
    Note  LabVIEW 8.5 and later are large address aware. For more information about LabVIEW memory usage, refer to KB 2HDEH9DT, How Much Memory can LabVIEW 32-bit or 64-bit Use?.
    In TestStand 2013 and later, the Large Address Aware flag is enabled by default for the TestStand Sequence Editor and TestStand User Interfaces. For more information, refer to KB 5ZREUK2G, Using the Large Address Aware Flag With TestStand Applications.
    Using NI Software with Microsoft Windows 8.x
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    © 2015 National Instruments. All rights reserved.
    375524A-01
    GMT+8, 2026-1-13 09:36
