查看: 1787|回复: 0
[RTE运行引擎] NI RFmx CDMA2000 19.1 Runtime Win32ENG运行版下载
    发表于 2022-3-29 12:06:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:
    2019/10/17
    包含的版本:
    19.1运行版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    应用程序位数:
    32位
    语言:
    英文
    文件大小: 573077504 字节 (546.53 MB)
    修改日期: 2019-10-18 18:02
    MD5: 3523e719601ab66934c7173ac85b6b8d
    SHA1: 3da337b3b49e4c22bedacd21536a984a36053e47
    SHA256: bcf5bcde21b839a8d0226a6e5f0ba7a50385fd2e2c5e6148622c20c154c14740
    CRC32: f80364ed
    注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 19.1RTE32.txt (559 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx CDMA2k 19.1 Readme
    October 2019
    This file contains important information about the RFmx CDMA2k, including system requirements and installation instructions.
    [url=]Overview[/url]
    RFmx CDMA2k is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development effort. Using this software, you can perform physical-layer analysis on CDMA2k cellular signals including MODACC, ACPR, CHP, OBW, QEVM, CDA, SlotPower, SlotPhase, and SEM. RFmx CDMA2k is completely interoperable with all RFmx APIs.
    [url=]New Features[/url]
    RFmx CDMA2k 19.1 includes the following new features:
    • Support for PXIe-5841
    RFmx CDMA2k 19.0 includes the following new features:
    RFmx CDMA2k 3.0 includes the following new features:
    • Support for PXIe-5820
    [url=]Supported Hardware[/url]
    The following hardware products are supported in all operating systems listed in the Supported Operating Systemssection.
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help .
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    [url=]System Requirements[/url]RFmx CDMA2k has the following requirements:
    [url=]Supported Operating Systems[/url]
    RFmx CDMA2k 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442and KB2919355for more information about how to install these updates.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929for more information about how to install this security update.
    Note   In 2019, RFmx CDMA2k dropped support for all 32-bit Windows operating systems. RFmx CDMA2k will not install or run on an unsupported OS. Refer to RFmx CDMA2k Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021for information about future OS support.
    [url=]Application Software Support[/url]
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx CDMA2k. To add support for application software installed after installing RFmx CDMA2k modify your RFmx CDMA2k installation or launch the RFmx CDMA2k installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Versions Supported by RFmx CDMA2k
    [url=]Required Software[/url]
    [url=]Microsoft Visual Studio Support[/url]
    If you are using the RFmx CDMA2k .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx CDMA2k .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    [url=]Installation Instructions[/url]
    NI installs RFmx CDMA2k using NI Package Manager. If you do not already have NI software installed, RFmx CDMA2k installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownloadto download NI Package Manager. Refer to the NI Package Manager Manualfor more information about installing, removing, and upgrading NI software using NI Package Manager.
    [url=]Installed Software[/url]
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.Cdma2kMX.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx CDMA2k» RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    [url=]Accessing the API[/url]
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » NI-RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start»All Programs»National Instruments»RFmx CDMA2k»RFmx CDMA2k Documentation . The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx CDMA2k HelpHTML/Windows HelpContains primary help content for RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx CDMA2k
    • A complete reference for all RFmx CDMA2k programming functions and VIs
    RFmx CDMA2k 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx CDMA2k examples at Start»All Programs»National Instruments»RFmx CDMA2k»RFmx CDMA2k Examples.
    [url=]Product Security and Critical Updates[/url]
    Visit ni.com/securityto view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updatesfor information about critical updates from National Instruments.
    [url=]Behavior Changes[/url]
    The following items are behavior changes in RFmx CDMA2k 19.0 from RFmx CDMA2k 3.0.
    [url=]Known Issues[/url]
    You can access the software and documentation known issues list online. Refer to the RFmx CDMA2k Known Issuesfor an up-to-date list of known issues.
    [url=]Bug Fixes[/url]
    The following items are the IDs and titles of a subset of issues fixed in RFmx CDMA2k . This is not an exhaustive list of issues fixed in the current version of the RFmx CDMA2kk . If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx CDMA2k 19.1 from RFmx CDMA2k 19.0
    ID
    Fixed Issue
    249283Fixed an issue to report an error when measurement bandwidth exceeds the device instantaneous bandwidth on PXIe-5668 and PXIe-5665 devices.
    234240Fixed an intermittent error occurring at Analyze IQ and Analyze Spectrum APIs when performing a composite measurement with different averaging count for each measurement
    The following items are changes in RFmx CDMA2k 3.0 from RFmx CDMA2k 2.5
    ID
    Fixed Issue
    248862Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    244193Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    [url=]Automating the Installation of NI Products[/url]
    [url=]Using NI Software with Microsoft Windows 10[/url]
    [url=]Using NI Software with Microsoft Windows 8.1[/url]
    [url=]RFmx CDMA2k Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021[/url]
    RFmx CDMA2k will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    For detailed information about NI application software product life cycles, visit ni.com/infoand enter one of the following Info Codes:
    Info Code
    LabWindows/CVIcvi_lifecycle
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarksfor information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    375524K-01
    GMT+8, 2026-1-13 08:10
