查看: 1759|回复: 0
[RTE运行引擎] NI RFmx CDMA2000 2.3.1 Runtime Win32ENG运行版下载
    发表于 2022-3-28 18:23:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:
    2017/10/16
    包含的版本:
    2.3.1运行版
    Windows 10
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    应用程序位数:
    32位
    语言:
    英文
    文件大小: 381833216 字节 (364.14 MB)
    修改日期: 2017-10-12 23:45
    MD5: 0d3d88728e24ecc08a5521a217bb06cc
    SHA1: 5b2f1fae695d4674600bd8856e7013b251683906
    SHA256: d02d412cebb83d4eb8574008b00f410c06dc97996f1327967b7eebe1df6ba4fa
    CRC32: 228b055b
    注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 2.3.1RTE32.txt (521 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx CDMA2k 2.3.1 Readme
    October 2017
    This file contains important information about NI-RFmx CDMA2k and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx CDMA2k
    [url=]New Features[/url]
    NI-RFmx CDMA2k 2.3 includes the following new features:
    • Addition of code domain analysis (CDA) measurement
    • Addition of Slot Phase measurement
    NI-RFmx CDMA2k 2.2 includes the following new features:
    • Addition of QPSK EVM (QEVM) measurements
    • Addition of I/Q gain imbalance and I/Q quadrature error measurement results for ModAcc measurements
    • Improved robustness of channel auto detection in ModAcc measurements
    • Support for reading measurement configuration internally used by RFmx for spectral measurements
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    • Support for LO leakage avoidance when using vector signal transceiver as the analyzer
    NI-RFmx CDMA2k 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre-Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    [url=]Installation Instructions[/url]
    Caution  Before you install NI-RFmx CDMA2k 2.3.1, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    Caution   If you are using only RFmx LabVIEW Runtime products, NI recommends uninstalling all the RFmx Runtime products before installing a newer version of RFmx Runtime products.
    [url=]Supported Hardware[/url]Vector Signal Analyzers
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    [url=]System Requirements[/url]Supported Operating Systems
    NI-RFmx CDMA2k 2.3.1 supports the following operating systems:
    Note  NI-RFmx CDMA2k 2.3.1 and later does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx CDMA2k. To add support for ADEs installed after installing NI-RFmx CDMA2k, modify your NI-RFmx CDMA2k installation or launch the NI-RFmx CDMA2k installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016 or 2017
    Note  NI-RFmx CDMA2k will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
    [url=]Installed Software, Documentation, and Examples[/url]Installed Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\RFmx\CDMA2k\Examples
    Examples\LabVIEW \examples\RFmx\CDMA2k
    Select Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Measurement Interactive Panel to launch the NI-RFmx CDMA2k Measurement Interactive Panel.
    [url=]Documentation[/url]
    Documentation for NI-RFmx CDMA2k is located at Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx CDMA2k HelpHTML/Windows HelpContains primary help content for NI-RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx CDMA2k
    • A complete reference for all NI-RFmx CDMA2k programming functions and VIs
    NI-RFmx CDMA2k 2.3 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    [url=]Accessing VIs and Functions[/url]
    NI-RFmx CDMA2k palette VIs are available from the Functions»Measurement I/O»NI-RFmx»CDMA2k palette.
    [url=]Finding Examples[/url]
    You can access all the installed NI-RFmx CDMA2k examples at Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Examples.
    NI-RFmx CDMA2k 2.3.1 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx CDMA2k drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx CDMA2k 2.3.1 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx CDMA2k 2.3.1 to an unsupported OS. Additionally, after installing NI-RFmx CDMA2k 2.3.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    [url=]Product Security and Critical Updates[/url]
    [url=]Uninstalling/Modifying NI-RFmx CDMA2k[/url]
    • Select NI-RFmx CDMA2k 2.3.1 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFmx CDMA2k 2.3.1 installation, the following software is installed. To completely remove the NI-RFmx CDMA2k 2.3.1 installation from your system, you must also remove the following package:
    • NI-RFmx CDMA2k Runtime 2.3.1
    • NI-RFmx CDMA2k Runtime 2.3.1 (64-bit)
    [url=]Behavior Changes[/url]
    The following items are behavior changes in NI-RFmx CDMA2k 2.3.1 from NI-RFmx CDMA2k 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty sting).
    • The alias 'default@CDMA2k' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    The following item is a behavior change in NI-RFmx CDMA2k 2.2 from NI-RFmx CDMA2k 2.1.
    • RC1/2 analysis for ModAcc measurements is now standard compliant. The RC1/2 analysis employs a band limiting filter instead of the ICI removal filter (in contrast to all other RC's), therefore for RC1/2 the chip constellation trace shows the ICI introduced by the transmit filter.
    [url=]Known Issues[/url]
    You can access the software and documentation known issues list online. Refer to the NI-RFmx CDMA2k 2.3.1 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx CDMA2k 2.3.1.
    [url=]Bug Fixes[/url]
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx CDMA2k. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx CDMA2k. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx CDMA2k 2.3.1 from NI-RFmx CDMA2k 2.3.
    The following items are changes in NI-RFmx CDMA2k 2.3 from NI-RFmx CDMA2k 2.2.
    The following items are changes in NI-RFmx CDMA2k 2.2 from NI-RFmx CDMA2k 2.1.
    529110/537284Fixed an issue with instability of the RC1/2 measurement.
    [url=]Increasing Available Memory For Your Application[/url]
    [url=]Automating the Installation of NI Products[/url]
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer.
    [url=]Using NI Software with Microsoft Windows 10[/url]
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    [url=]Using NI Software with Microsoft Windows 8.1[/url]
    [url=]Legal Information[/url]
    © 2015–2017 National Instruments. All rights reserved.
    375524E-01
    GMT+8, 2026-1-13 07:51
