查看: 2523|回复: 0
[NI软件产品] NI RFmx CDMA2000 2.3 Full Win32/64ENG完整版下载
    发表于 2022-3-28 18:13:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:
    2017/5/4
    包含的版本:
    2.3完整版
    Windows 10
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    应用程序位数:
    32/64位
    语言:
    英文
    文件大小: 712372184 字节 (679.37 MB)
    修改日期: 2017-05-11 19:40
    MD5: 621f28c1a47af456ba90b92cb80072ff
    SHA1: 242a7a3458b5149a0bb5e2f0448a0255ad478ecc
    SHA256: 5f0c1b0621b1f15b97f4bf1136b7d4c4918d6caa882dbb81412f9d45974ce149
    CRC32: 554bac3b
    注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 2.3.0.txt (500 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx CDMA2k 2.3 Readme
    May 2017
    This file contains important information about NI-RFmx CDMA2k and is organized into the following sections:
    NI-RFmx CDMA2k 2.3 includes the following new features:
    • Addition of code domain analysis (CDA) measurement
    • Addition of Slot Phase measurement
    NI-RFmx CDMA2k 2.2 includes the following new features:
    • Addition of QPSK EVM (QEVM) measurements
    • Addition of I/Q gain imbalance and I/Q quadrature error measurement results for ModAcc measurements
    • Improved robustness of channel auto detection in ModAcc measurements
    • Support for reading measurement configuration internally used by RFmx for spectral measurements
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    • Support for LO leakage avoidance when using vector signal transciever as the analyzer
    NI-RFmx CDMA2k 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    Caution  Before you install NI-RFmx CDMA2k 2.3, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    Caution   If you are using only RFmx LabVIEW Runtime products, NI recommends uninstalling all the RFmx Runtime products before installing a newer version of RFmx Runtime products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx CDMA2k 2.3 supports the following operating systems:
    Note  NI-RFmx CDMA2k 2.3 and later does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx CDMA2k. To add support for ADEs installed after installing NI-RFmx CDMA2k, modify your NI-RFmx CDMA2k installation or launch the NI-RFmx CDMA2k installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016 or 2017
    Note  NI-RFmx CDMA2k will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
      Item
      Installed Location
      Import Library files (32-bit)
      Import Library files (64-bit)
      C, .NET
      Examples\RFmx\CDMA2k\Examples
      Examples\LabVIEW \examples\RFmx\CDMA2k
      Select Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Measurement Interactive Panel to launch the NI-RFmx CDMA2k Measurement Interactive Panel.
      Documentation for NI-RFmx CDMA2k is located at Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Documentation. The documentation set is composed of the following documents.
      Document
      Format
      Description
      NI-RFmx CDMA2k HelpHTML/Windows HelpContains primary help content for NI-RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
      • An introduction to NI-RFmx CDMA2k
      • A complete reference for all NI-RFmx CDMA2k programming functions and VIs
      NI-RFmx CDMA2k 2.3 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
      Accessing VIs and Functions
      NI-RFmx CDMA2k palette VIs are available from the Functions»Measurement I/O»NI-RFmx»CDMA2k palette.
      You can access all the installed NI-RFmx CDMA2k examples at Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Examples.
      NI-RFmx CDMA2k 2.3 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
      With this release, NI-RFmx CDMA2k drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx CDMA2k 2.3 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx CDMA2k 2.3 to an unsupported OS. Additionally, after installing NI-RFmx CDMA2k 2.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
      Uninstalling/Modifying NI-RFmx CDMA2k
      • Select NI-RFmx CDMA2k 2.3 from the dialog box that appears.
      • Select Control Panel.
      • Click the Uninstall button.
      As part of the NI-RFmx CDMA2k 2.3 installation, the following software is installed. To completely remove the NI-RFmx CDMA2k 2.3 installation from your system, you must also remove the following package:
      • NI-RFmx CDMA2k Runtime 2.3
      • NI-RFmx CDMA2k Runtime 2.3 (64-bit)
      The following item is a behavior change in NI-RFmx CDMA2k 2.2 from NI-RFmx CDMA2k 2.1
      • RC1/2 analysis for ModAcc measurements is now standard compliant. The RC1/2 analysis employs a band limiting filter instead of the ICI removal filter (in contrast to all other RC's), therefore for RC1/2 the chip constellation trace shows the ICI introduced by the transmit filter.
      You can access the software and documentation known issues list online. Refer to the NI-RFmx CDMA2k 2.3 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx CDMA2k 2.3.
      The following items are changes in NI-RFmx CDMA2k 2.3 from NI-RFmx CDMA2k 2.2.
      ID
      Fixed Issue
      The following items are changes in NI-RFmx CDMA2k 2.2 from NI-RFmx CDMA2k 2.1.
      ID
      Fixed Issue
      529110/537284Fixed an issue with instability of the RC1/2 measurement.
      The following items are changes in NI-RFmx CDMA2k 2.1 from NI-RFmx CDMA2k 2.0.
      ID
      Fixed Issue
      554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
      562712
      Fixed an issue with fetching the ModAcc results from the property node when traces are disabled.
      Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
      © 2015–2017 National Instruments. All rights reserved.
      375524D-01
    GMT+8, 2026-1-13 07:51
