查看: 2100|回复: 0
[NI驱动程序] NI-Serial 21.5 Driver x64Win10 32/64bit中文/德语/日语/法语/英文/韩语 NI串口产品驱动ni-serial_21.5.0
    发表于 2022-3-15 11:50:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Serial为使用NI串口产品的客户提供支持。
    NI-Serial驱动程序可最大限度提高CPU的利用率,无需改变波特率即可提高仪器的数据吞吐量。您也可使用较大型的先入先出存内存缓冲器(FIFO)来执行DMA传输,使NI-Serial接口以更高的速率发送和接收更大量的数据。
    发布日期
    2022/1/27
    包含的版本
    21.5完整版
    受支持的操作系统
    语言
    中文/德语/日语/法语/英文/韩语
    程序位数
    32/64位
    校验和
    文件大小: 1251584000 字节 (1.17 GB)
    修改日期: 2022-01-28 07:16
    MD5: 632b4fc984903255680165c0819eedee(官方正确)
    SHA1: d3bff49c13623973c9df10da0f9436825bbe3c70
    SHA256: 85f9363f18cd03dd26660d8d68f8615e893f4d2e78c0c504a4378188aad39ad7
    CRC32: d947bac5
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI-Serial 21.5.txt (538 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Serial 21.5 Readme
    January 2022
    Thank you for using NI-Serial 21.5.
    This file contains installation instructions and compatibility information for NI-Serial for Windows and LabVIEW Real-Time.
    Parts of this document are relevant to only a full installation and do not apply to a runtime-only installation.
    NI-Serial 21.5 supports the following operating systems:
    NI-Serial 21.5 supports the following versions of the LabVIEW Real-Time Module:
    • LabVIEW Real-Time 2021
    • LabVIEW Real-Time 2020
    • LabVIEW Real-Time 2019
    • LabVIEW Real-Time 2018
    To download previous versions of NI-Serial drivers, refer to ni.com/updates and search for NI-Serial.
    Supported Interfaces
    Note  Refer to NI Serial Hardware for additional information about supported interfaces.
    PCI Interfaces
    • PCI-8430/2
    • PCI-8430/4
    • PCI-8430/8
    • PCI-8430/16
    • PCI-8431/2
    • PCI-8431/4
    • PCI-8431/8
    • PCI-8432/2
    • PCI-8432/4
    • PCI-8433/2
    • PCI-8433/4
    PCI Express Interfaces
    • NI PCIe-8430/2
    • NI PCIe-8430/8
    • NI PCIe-8430/16
    • NI PCIe-8431/2
    • NI PCIe-8431/8
    • NI PCIe-8431/16
    • NI PCIe-8432/2
    • NI PCIe-8433/2
    PXI Interfaces
    • PXI-8430/2
    • PXI-8430/4
    • PXI-8430/8
    • PXI-8430/16
    • PXI-8431/2
    • PXI-8431/4
    • PXI-8431/8
    • PXI-8432/2
    • PXI-8432/4
    • PXI-8433/2
    • PXI-8433/4
    PXI Express Interfaces
    • NI PXIe-8430/8
    • NI PXIe-8430/16
    • NI PXIe-8431/8
    • NI PXIe-8431/16
    USB Interfaces
    • USB-232
    • USB-232/2
    • USB-232/4
    • USB-485
    • USB-485/2
    • USB-485/4
    ExpressCard Interfaces
    • NI ExpressCard-8420/2
    • NI ExpressCard-8421/2
    Windows Embedded Controllers
    NI-Serial software is required to use any RS-485/422 ports on the following controllers. Any RS-232 ports are supported by Microsoft's serial driver and do not require NI-Serial to be installed.
    • cDAQ-913x
    • cRIO-908x
    • CVS-1458
    Real-Time Controllers
    • Desktop RT
    • PXI Controllers
    Serial C Series Modules1
    • NI 9870
    • NI 9871
    1Serial C Series Modules may be used through NI-Serial and NI-VISA on backplanes configured to use NI-RIO IO Scan. To enable this support, NI-Serial 9870 and 9871 Scan Engine Support must be installed on the controller. For assistance with configuring a controller and backplane to use NI-RIO IO Scan, please refer to the NI-RIO documentation.
    LabVIEW NXG Support and Considerations
    The following sections detail considerations for using LabVIEW NXG 5.0 with NI-Serial.
    LabVIEW NXG Hardware Support
    Refer to the Supported Interfaces section for a list of hardware supported in LabVIEW NXG.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-Serial no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 1996–2022 National Instruments Corporation. All rights reserved.
    375395J-01
    GMT+8, 2026-1-13 07:50
