查看: 1625|回复: 0
[RTE运行引擎] NI RFmx 21.5 Runtime x64Win10 64bitEng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_21.5.0
    8 小时前
  • 签到天数: 3566 天
    连续签到: 11 天
    发表于 2022-3-14 16:24:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期
    2022/1/27
    包含的版本
    21.5.0运行版
    受支持的操作系统
    应用程序位数
    64位
    语言
    English
    校验和
    文件大小: 804759552 字节 (767.48 MB)
    修改日期: 2022-01-27 13:46
    MD5: 2a88792d8e3a454c9f63ff6819fbc2ea
    SHA1: ada29aab1274a8ebc61c5e868bb26e19ac7f3d13
    SHA256: 71850a35a387926997231d939626e7472bf77cdd6579ac36ab884f8b3564fef0
    CRC32: d3978aae
    NI RFmx 21.5 RTEx64.txt (593 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx Runtime (64-Bit) 21.5 Readme
    January 2022
    This file contains important information about the RFmx Runtime (64-Bit), including system requirements, and installation instructions.
    The following products are included in the RFmx Runtime (64-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    Application Software
    • RFmx SpecAn Runtime (64-Bit)
    • RFmx Demod Runtime (64-Bit)
    • RFmx WLAN Runtime (64-Bit)
    • RFmx for Bluetooth® Test Runtime (64-Bit)
    • RFmx NR Runtime (64-Bit)
    • RFmx LTE Runtime (64-Bit)
    • RFmx WCDMA Runtime (64-Bit)
    • RFmx TD-SCDMA Runtime (64-Bit)
    • RFmx EV-DO Runtime (64-Bit)
    • RFmx CDMA2k Runtime (64-Bit)
    • RFmx GSM Runtime (64-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    [url=]System Requirements[/url]
    RFmx Runtime (64-Bit) has the following requirements:
    [url=]Supported Operating Systems[/url]
    RFmx Runtime (64-Bit) 21.5 supports the following 64-bit operating systems:
    Note RFmx Runtime (64-Bit) no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Runtime (64-Bit) 21.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Runtime (64-Bit) 21.5 to an unsupported OS. Additionally, after installing RFmx Runtime (64-Bit) 21.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    [url=]Installation Instructions[/url]
    Download the RFmx Runtime (64-Bit) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    [url=]Product Security and Critical Updates[/url]
    [url=]Automating the Installation of NI Products[/url]
    [url=]Using NI Software with Microsoft Windows 10[/url]
    © 2019–2022 National Instruments Corporation. All rights reserved.
    377999H-01
    GMT+8, 2025-6-13 16:15
