查看: 2156|回复: 0
[NI软件产品] NI RFmx 21.5 Full x64Win10 32/64bitEng NI Wireless Test Standard Software完整版ni-rfmx-suite_21.5.0
    3 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2022-3-14 16:20:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期
    2022/1/27
    包含的版本
    21.5.0完整版
    受支持的操作系统
    应用程序位数
    32/64位
    语言
    English
    校验和
    文件大小: 2829416448 字节 (2.64 GB)
    修改日期: 2022-01-27 13:48
    MD5: 64ae8700ee47d339e699311fd3bbf1d1(官方正确)
    SHA1: 7f879ad124671d8f5de96aad3aa256f165c7a87c
    SHA256: 7487d32bd0a604e2597aae4e08c4d695ef6c577a850f27484fc36887b7552d52
    CRC32: 120f9f2f
    NI RFmx 21.5.txt (568 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx 21.5 Readme
    January 2022
    This file contains important information about the RFmx, including system requirements, and installation instructions.
    • RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    Application Software
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    [url=]System Requirements[/url]
    RFmx has the following requirements:
    [url=]Supported Operating Systems[/url]
    RFmx 21.5 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 21.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 21.5 to an unsupported OS. Additionally, after installing RFmx 21.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    [url=]Application Software Support[/url]
    RFmx 21.5 supports the following application software versions, including service packs.
    Versions Supported by RFmx
    LabVIEW2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1, or 2021
    LabWindows™/CVI™2015 or later
    [url=]Installation Instructions[/url]
    Download the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    [url=]Product Security and Critical Updates[/url]
    [url=]Automating the Installation of NI Products[/url]
    [url=]Using NI Software with Microsoft Windows 10[/url]
    © 2019–2022 National Instruments Corporation. All rights reserved.
    377996H-01
    GMT+8, 2025-11-19 10:58
