查看: 2353|回复: 0
[NI驱动程序] NI RF Signal Generators 21.5.0 x64Win10 32/64bitEng NI RF信号发生器NI-RFSG21.5.0
    发表于 2022-3-11 17:51:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    发行日期
    2022/01/28
    包含的版本
    21.5.0完整版
    受支持的操作系统
    程序位数
    32/64位
    语言
    英文
    校验和
    文件大小: 5522141184 字节 (5.14 GB)
    修改日期: 2022-01-28 20:48
    MD5: feb8b2241b578a30654a1ff8123e6af8
    SHA1: c51ebef71dd28ba35c0d54c33e2150c43a9d5601
    SHA256: 7bfb82cf997838bdb60d1215d4a0d2ddb57f9e5ae68cc359c7fe5c5e725d6a65
    CRC32: fb2c4797
    NI-RFSG 21.5.txt (518 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 21.5 Readme
    January 2022
    This file contains installation instructions and compatibility information for NI-RFSG.
    [url=]Overview[/url]
    This software installation provides support for customers using RF signal generator or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    [url=]New Features[/url]
    NI-RFSG 21.5 includes the following new features:
    • Support for RF list mode on PXIe-5840/5841 for LO Source, Upconverter Frequency Offset Mode, and Signal Bandwidth attributes
    NI-RFSG 21.0 includes the following new features:
    • Support for LabVIEW 2021
    • Support for Linux
    NI-RFSG 20.7 includes the following new features:
    • Added new InstrumentStudio-based NI-RFSG Soft Front Panel with the ability to debug and monitor applications for the PXIe-5840/5841 and PXIe-5830/5831/5832
    • Added the ability to load waveforms from TDMS files into the device memory for the PXIe-5840/5841 and PXIe-5830/5831/5832
    • Added the ability to configure certain properties for a specific waveform on the PXIe-5840/5841 and PXIe-5830/5831/5832
    [url=]Supported Hardware[/url]
    The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware Product
    Hardware Model
    NI-RFSG
    NI-RFSG Soft Front Panel (Classic)
    NI-RFSG Soft Front Panel (InstrumentStudio)
    RF Signal UpconverterPXI-5610
    I/Q ModulatorPXIe-5611
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5830
    PXIe-5831
    PXIe-5832
    PXIe-5840
    PXIe-5841
    PXIe-5841 with
    PXIe-5655 RF Analog Signal Generator
    RF Analog Signal GeneratorPXI/PXIe-5650
    PXI/PXIe-5651
    PXI/PXIe-5652
    PXIe-5653
    PXIe-5654
    PXIe-5654 with
    PXIe-5696 Amplitude Extender
    Vector Signal GeneratorPXI-5670
    PXI-5671
    PXIe-5672
    PXIe-5673/5673E
    • 4 GB RAM*
    Note  NI-RFSG 21.5 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 21.5.
    [url=]Supported Operating Systems[/url]
    [url=]Application Software Support[/url]
    Versions Supported by NI-RFSG
    LabVIEW2018 SP1, 2019, 2020, or 2021
    LabWindows/CVI2018 to current
    [url=]Microsoft Visual Studio Support[/url]
    [url=]Installation Instructions[/url]
    [url=]Accessing the API[/url]LabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    [url=]Finding Examples[/url]
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    [url=]Product Security and Critical Updates[/url]
    [url=]IVI Compliance Package Functionality[/url]
    NI-RFSG no longer installs IVI Compliance Package (ICP). NI-RFSG supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    [url=]Automating the Installation of NI Products[/url]
    [url=]Unsupported Windows Operating Systems[/url]
    374769AG-01
    GMT+8, 2026-1-13 07:50
