查看: 2498|回复: 0
[NI软件产品] NI RFIC Test Software 21.5.0 x64Win10 64bitEng NI-RFIC测试软件21.5.0
    发表于 2022-3-11 15:21:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFIC测试软件
    RFIC测试软件简化了宽带RF IC的特性分析。
    RFIC测试软件是一款应用软件,可帮助您分析功率放大器(PA)和前端模块(FEM)等RFIC的特性。如果要对PA进行线性化,有多种针对特定应用的数字预失真(DPD)算法可供选择,例如查找表(LUT)、记忆多项式(MP)和广义记忆多项式(GMP)。此外,您还可以集成并运行NI联盟伙伴的线性化算法或技术。当使用像PXI矢量信号收发仪这样的NI仪器时,您还可以使用该软件来分析包络跟踪(ET)等功率效率优化技术。您可以使用GUI来保存手动配置和执行,以便重复使用这些配置和执行或与其他测试平台共享。National Instruments Alliance Partner(NI联盟伙伴)是独立于NI的商业实体,与NI之间不存在代理、合伙或合资关系。
    21.5.0
    发布日期
    2022/2/18
    包含的版本
    21.5.0完整版
    受支持的操作系统
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 753446912 字节 (718.54 MB)
    修改日期: 2022-02-16 23:54
    MD5: 50a5f28f1c2663c87b131ea6c834d254(官方正确)
    SHA1: 7f4991855267aca3edf0d6ab254e1573ac2c268b
    SHA256: abbcf308d65e13b5382b7204abcd9c3918477e7bebe7373d6208bc80949db85f
    CRC32: 7f546747
    NI RFIC Test Software 21.5.txt (578 Bytes, 下载次数: 0, 售价: 10 圆)
    RFIC Test Software 21.5 Readme
    January 2022
    This file contains installation instructions and compatibility information for RFIC Test Software 21.5.
    RFIC Test Software enables you to explore testing advanced RF integrated circuit (RFIC) devices featuring envelope tracking (ET), digital predistortion (DPD), and hardware-accelerated power servoing. Available measurements include adjacent channel power (ACP), spectral emission mask (SEM), error vector magnitude (EVM), AM-to-AM, and AM-to-PM. To set up measurements for your device, use the installed examples or the RFIC Test Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    RFIC Test Software 21.5 has the following minimum requirements:
    • Processor—Intel Pentium 4 or equivalent
    • 1 GB RAM*
    • A screen resolution of 1,024 x 768 with 256 colors
    NI recommends the following requirements:
    • 4 GB RAM*
    • A screen resolution of 1,600 x 1,200
    * Depending on the amount of data acquired and/or processed a larger amount of memory may be required.
    RFIC Test Software 21.5 supports Windows 10 (64-bit only).
    RFIC Test Software 21.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Note  Install application software, such as LabVIEW or Microsoft Visual Studio, before installing RFIC Test Software. To add support for application software installed after installing RFIC Test Software, modify your RFIC Test Software installation or launch the RFIC Test Software installer again.
    Versions Supported by RFIC Test Software
    LabVIEW (64-bit only)2018, 2018 SP1, 2019, 2019 SP1, 2020, 2020 SP1, and 2021
    Microsoft Visual Studio2017 (minimum)
    TestStand2021
    Note  RFIC Test Software cannot operate correctly without the service packs previously mentioned.
    If you are using the RFIC Test Software .NET Class Library, .NET Framework 4.5 (minimum) is required.
    Driver and Add-On Requirements
    RFIC Test Software requires the following driver and add-on versions:
    • NI-RFSG 21.0
    • NI-RFSA 21.0
    • NI-FGEN 21.3
    • NI-DCPower 21.3
    • NI-SCOPE 21.0
    • RFmx SpecAn 21.5
    • RFmx Analog Modulation 21.5
    • RFmx LTE 21.51
    • RFmx NR 21.51
    • RFmx WLAN 21.51
    • NI-RFSG Playback Library 21.5
    • (Optional) NI-SWITCH 21.32
    • (Optional) NI-Digital Pattern Driver 21.03
    • (Optional) Semiconductor Device Control Add-On 2021 for InstrumentStudio3
    • (Optional) Single-Band RF Power Amplifier Linearizer 1.7 or later⁴
    • (Optional) Dual-Band RF Power Amplifier Linearizer 2.1 or later⁴
    • (Optional) NI-DMM 21.3⁵
    • (Optional) NI-568x Driver Software 20.0⁶
    1 Installation and licensing are only required for standard-specific measurements.
    2 Required to use the PXI-2599 RF Relay Module to connect the PXIe-5841/5840 and the PXIe-5831/5830 Vector Signal Transceivers.
    3 Required to control DUTs that use the MIPI® RF front-end (RFFE) or SPI hardware protocol.
    ⁴ Requires a valid license.
    ⁵ Required to measure system power-added efficiency (PAE) with PXIe-4080/4081 Digital Multimeters.
    ⁶ Required to measure RF power level with USB-5681/5683/5684 RF Power Sensor Devices.
    Note  The run-time versions of these products are sufficient to run the RFIC Test SFP.
    Refer to the readme of each driver and add-on for more information about system requirements, installation instructions, and activation.
    Download the RFIC Test Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Activation Notice
    The following table lists the measurements and features included in the RFIC Test Software Base and Professional versions. You must have a valid license to activate RFIC Test Software Professional. Use the serial number that is included with your software to activate RFIC Test Software Professional. For more information about activation, refer to NI Software Activation.
    Measurement and Feature
    General measurements
    Software-based power servo
    Excludes power meter-based servo
    Hardware-accelerated power servo
    Transmission power (TXP)
    Adjacent channel power (ACP)
    Modulation accuracy (ModAcc - including EVM)
    Spectral emission mask (SEM)
    AM-to-AM (AMAM) and AM-to-PM (AMPM)
    Digital predistortion (DPD)
    Load pull
    Single point only, excludes sweeping
    PAE
    Dynamic EVM (DEVM)
    Envelope tracking (ET)
    Crest factor reduction (pre-DPD and post-DPD)
    Swept measurements (power, frequency, and load pull)
    Power sweeping only
    Complementary cumulative distribution function (CCDF)
    Routing triggers
    Cross-correlation EVM optimization
    RFIC Test Software 21.5 includes the following new features:
    • Support for using digital multimeters (DMMs) in system PAE measurements
    • Support for using a power meter at the DUT input port for power measurement or power servo
    • Support for new functionalities in the example sequences generated by RFIC Test Automation Wizard
    • New C# examples and TestStand sequences for NanoSemi DPD single- and dual-band in RFIC Test Automation Wizard
    • Enhancements to the fast convergence algorithm in cross-correlation EVM measurements
    The following table details the hardware models supported in RFIC Test Software 21.5.
    Hardware Product
    Hardware Model
    Application
    Vector Signal TransceiverPXIe-5830Hardware-accelerated power servoing
    PXIe-5831
    PXIe-5840
    PXIe-5841
    PXIe-5820Envelope waveform generation when testing ET DUTs
    Waveform GeneratorPXIe-5451Envelope waveform generation when testing ET DUTs
    Note  For DEVM measurements, use the PXIe-5820.
    OscilloscopePXIe-5162
    • PAE measurements
    • (Optional) Recommended for envelope waveform/delay analysis when testing ET DUTs
    PXIe-5185
    PXIe-5186
    Source Measure UnitPXIe-4139Vcc sourcing and system PAE measurements
    PXIe-414x
    RF Power Sensor DeviceUSB-5681
    • DUT output and/or input power monitoring
    • Software power servoing
    Note  Instrument drivers for R&S® NRP-Z are used for R&S® power sensors. R&S® NRP50S is verified.
    USB-5683
    USB-5684
    R&S® NRP50S
    RF Relay ModulePXI-2599For switching between VSTs on frequency ranges for WLAN measurements.
    Digital Pattern InstrumentPXIe-6571For controlling DUTs using the MIPI® RFFE or SPI hardware protocol.
    Digital MultimeterPXIe-4080For measuring system PAE when using a third-party power supply.
    PXIe-4081
    Accessing the APIsLabVIEW
    ETSync VIs are available in LabVIEW from the Functions»Addons»ET palette.
    Power Servo VIs are available in LabVIEW from the Functions»User Libraries»NI Power Servoing IP palette.
    NanoSemi Linearizer VIs and NanoSemi Dual Band VIs are available in LabVIEW from the Functions»User Libraries»NanoSemi Linearizer and NanoSemi Dual Band palettes, respectively.
    .NET Framework
    You can use the ETSync .NET Class library by adding a reference to niETSync.cs, niETUtil.cs, and niFGEN.cs from C:\Users\Public\Public Documents\National Instruments\NI-ETSync\DotNET Wrappers\CS\ and any dependent class libraries from within the Solution Explorer in Visual Studio.
    You can use the Power Servo .NET Class library by adding a reference to niVSTPowerServo.cs, niRFSA.cs, and niInteropCommon.cs from C:\Users\Public\Public Documents\National Instruments\FPGA Power Servo\DotNET Wrappers\CS\ and any dependent class libraries from within the Solution Explorer in Visual Studio.
    C
    You can use the ETSync C dynamically linked library by adding a reference to: Program Files\IVI Foundation\IVI\Bin\niETSync_64.dll.
    You can use the Power Servo C dynamically linked library by adding a reference to: Program Files\IVI Foundation\IVI\Bin\niVSTPowerServo_64.dll.
    RFIC Test SFP
    To launch the RFIC Test SFP, select Start»National Instruments»RFIC Test Soft Front Panel.
    Refer to the RFIC Test Software User Manual (rfichelp.chm), located at Start»National Instruments»RFIC Documentation. The manual includes the following information:
    • The supported measurements and wireless standards
    • RFIC Test Soft Front Panel information and examples
    • How to get started with RFIC Test Automation Wizard
    • Legacy examples
    • How to configure hardware for use with the ETSync API and reference for the ETSync VIs
    • Theory of operation information on power servoing and reference for the Power Servo VIs
    For information about your device, such as getting started, technical specifications, and calibration instructions, refer to the documentation for your device. For the most recent revisions of documentation and newly released documentation, visit ni.com/manuals.
    LabVIEW, .NET, and TestStand examples are available via RFIC Test Automation Wizard, accessible from Start»National Instruments»RFIC Test Automation Wizard.
    RFIC Test Software no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    377985J-01
    GMT+8, 2026-1-13 07:52
