查看: 2501|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 21.5.0 x64Win10 32/64bitEng LabVIEW可重配置示波器仪器设计库NIREOSCIDL2021
    发表于 2022-3-11 12:21:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW可重配置示波器仪器设计库
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes可帮助您使用用户可编程的FPGA为PXI示波器开发所需的应用程序。
    发布日期:2022/1/27
    包含的版本:21.5.0完整版
    语言:英文English
    文件大小: 1787301888 字节 (1.66 GB)
    修改日期: 2022-01-28 07:16
    MD5: 8dbd4fc3a5fbc77eeab5ad080bd3e3f0
    SHA1: 9dd8c6bcb3b28ff93c43f641deea97a3a025d616
    SHA256: ba319175dd9d6e323b0b3bda4b052e02cfe85381cc30ec02cb28a3f55a01268d
    CRC32: 61e6bb9e
    请注册登陆机器视觉论坛账号,购买附件查看下载地址
    NI-REOSCIDL 21.5.txt (685 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 21.5 Readme
    January 2022
    This file contains important information about LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes.
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes Manuals: New features, behavior changes, and other documentation
    Installation Information
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 21.5 provides support for customers using the PXIe-5164, PXIe-5170, PXIe-5171, and PXIe-5172 reconfigurable oscilloscopes with LabVIEW 2021.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 21.5 has the following requirements:
    • Pentium 4 or equivalent processor
    • 2 GB RAM
    Note  To compile LabVIEW FPGA VIs, your computer must be running a 64-bit operating system. To compile VIs for reconfigurable oscilloscope FPGA targets, your computer must have at least 4 GB of RAM (8 GB recommended). The minimum system requirements support only the reconfigurable oscilloscopes runtime and compiled projects.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes supports the following operating systems:
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes does not support LabVIEW Real-Time Module or LabWindows™/CVI™ Real-Time Module.
    The following table lists the application software versions, including service packs, supported by LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 21.5.
    Versions Supported by LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 21.5
    LabVIEW (64-bit)2021
    LabVIEW FPGA Module (recommended)2021
    Note  Support for LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes was first available in LabVIEW 2014 (32-bit).
    Note  You should install ADEs, such as LabVIEW, before installing the instrument design libraries. To add support for ADEs installed after installing the instrument design libraries, modify your instrument design libraries installation or launch the instrument design libraries installer again.
    As part of the instrument design libraries installation, the following software is installed. To completely remove the instrument design libraries installation from your system, you must also remove all of the following packages:
    • NI PXI Platform Services
    • NI System Configuration Runtime
    • NI-RIO
    Notice  Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 21.5 includes the following new feature:
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 20.0 includes the following new feature:
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 19.1 includes the following new feature:
      • Support for new bandwidth-limiting filters and onboard clock rates for the PXIe-5172
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 19.0 includes the following new feature:
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 18.0 includes the following new feature:
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 17.0 includes the following new feature:
      • Support for LabVIEW 2017 (32-bit)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.2 includes the following new features:
      • Support for the following PXIe-5172 devices:
        • PXIe-5172 (4 channel, 325T FPGA)
        • PXIe-5172 (8 channel, 325T FPGA)
        • PXIe-5172 (8 channel, 410T FPGA)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1 includes the following new feature:
      • Support for the PXIe-5164 reconfigurable oscilloscope
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.0 includes the following new feature:
      • Support for LabVIEW 2016 (32-bit)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 15.0 includes the following new feature:
      • Support for LabVIEW 2015 (32-bit)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 14.0 includes the following new features:
      • Support for LabVIEW 2014 (32-bit)
      • Support for the PXIe-5170 and PXIe-5171 reconfigurable oscilloscopes
    • PXIe-5164
    • PXIe-5170
    • PXIe-5171
    • PXIe-5172
    Refer to the NI Reconfigurable Oscilloscopes Help, accessible from Start»All Programs» National Instruments»Reconfigurable Oscilloscopes»Reconfigurable Oscilloscope Documentation , for information about the instrument design libraries.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2014–2022 National Instruments Corporation. All rights reserved.
    374867L-01
    GMT+8, 2026-1-13 07:50
