查看: 3694|回复: 0
[NI软件产品] NI VeriStand 2020R6 Win64Eng PC版完整版及运行版NIVS2020R6 20.6.0不含驱动版6.06GB
    发表于 2022-1-18 16:18:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2020R6
    文件大小: 6502234112 字节 (6.06 GB)
    修改日期: 2021-08-04 16:18
    MD5: 09b4e6a21e9d31bc01aac0b8218f5141
    SHA1: 6fba06cca569f5656ee02c6a143b2c6e4e7533a8
    SHA256: 412e8aee4c70c0ffba9ec98fea36e7a7d55e25e0d725fb59ffa4b145102a4292
    CRC32: 251a0f3a
    Veristand2020R6.txt (572 Bytes, 下载次数: 2, 售价: 10 圆)
    VeriStand 2020 R6 Readme
    July 2021
    This file contains installation instructions and compatibility information for VeriStand 2020 R6.
    • VeriStand Manual: New features, behavior changes, and other documentation
    VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and simulation models. The VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be customized and extended with LabVIEW, NI TestStand, and other software tools. Use VeriStand's run-time editable user interface to implement triggered multi-file data logging, stimulus generation and playback, and real-time test sequencing.
    VeriStand 2020 R6 installs with the following:
    • NI-DAQmx 21.0
    • NI-VISA 21.0
    • NI-SLSC 20.0.1
    • NI-XNET 21.0
    • NI R Series Multifunction RIO 20.7
    Simulation Models
    • To develop a model using MathWorks Simulink® software, you must be a licensed user and have MathWorks MATLAB® software (32-bit or 64-bit version) and MathWorks Simulink software installed on the host computer.
    • The VeriStand Model Framework supports only certain versions of MathWorks Simulink software. If the VeriStand Model Framework is used with an unsupported version of MathWorks Simulink®, VeriStand cannot initialize it.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2020. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    VeriStand 2020 R6 supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 10 64-bit version 20H21
    • Phar Lap ETS2
    • NI Linux Real-Time
    2 Releases after 2021 will no longer include support for Phar Lap ETS. For more information, refer to the Phar Lap RT OS EOL Road Map.
    Note  VeriStand will not install or run on an unsupported OS. You cannot deploy or distribute applications that use VeriStand 2020 R6 to an unsupported OS. For more information about the changes to our OS support for 2021, refer to National Instruments Support for Windows 7, Windows Server 2008 R2, and All 32-Bit Windows.
    When formatting a disk with a PXI Linux RT system image for VeriStand 2020 R6, select Linux RT System Image 21.0 and enable support for the LabVIEW 2020 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target.
    Online Installer
    Installation Media
    The following sections describe issues to be aware of when you upgrade to VeriStand 2020 R6.
    Note  NI recommends that you also review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2020 R6. To access the documents, refer to the VeriStand Release Notes.
    Known Conflict with .NET 4.6.2 and MSVC 2010
    To run the VeriStand editor, the .NET Framework 4.6.2 must be installed. However, installing the .NET Framework 4.6.2 can break the Microsoft Visual C++ 2010 compilers, which are used to compile models for PharLap VeriStand targets. Using broken compilers results in error LNK1123. To resolve this Microsoft compiler issue, apply all service packs and updates for your version of Microsoft Visual Studio or Windows SDK. Refer to Microsoft Support Article 2757355 for more information.
    Uncompiled Models
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2020. The LabVIEW functionality in VeriStand requires like-numbered versions.
    The VeriStand Model Framework contains changes to the files used to develop and compile models in C/C++ and third-party modeling environments. If your system contains models compiled with previous versions of the Model Framework, choose from the following options to continue to use the models in VeriStand 2020 R6:
    Models with Tuneable Parameters
    VeriStand Model Framework 2019 R3 to 2020 R4 does not support updates to tunable parameters if all the following are true:
    • The model uses tunable parameters.
    • The model uses model references to call subsystems.
    • The tunable parameter is not used or referenced in the top-level model.
    NI recommends recompiling this type of model with Model Framework 2020 R6. Use the VeriStand suite installer to separately download the Model Framework. Models compiled with Model Framework 2020 R6 are compatible with VeriStand 2019 R3 to 2020 R6.
    Migrating Files from VeriStand 2010 to 2018 SP1
    VeriStand 2020 R6 can open projects from VeriStand 2010 to 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    VeriStand Custom Devices Not Included
    In VeriStand 2020 and later, built-in Custom Devices, including the Embedded Data Logger, are no longer included when installing from offline media. Use NI Package Manager to include all supported Custom Devices during installation. To install Custom Devices separately, see the release page for each Custom Device on the VeriStand Add-ons support page
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help...
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2020 R6 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand.Windows Start menu: All Programs»National Instruments»VeriStand 2020 R6 .NET API Help.
    VeriStand Model Framework IntroductionInformation about how to use the VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in VeriStand.Access this guide from the \VeriStand\\ModelInterface\custom directory, where RootDrive is the drive where NI software installs and xxxx is the VeriStand version number.
    Note  Select VeriStand Model Framework when you run the VeriStand installer.
    • VeriStand Project—An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—VeriStand Stimulus Profile Editor examples are located in the \National Instruments\NI VeriStand\Examples directory.
      Note  On the Windows OS, the default location of the directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2020\examples\NI Veristand directory.
    © 2009–2021 National Instruments Corporation. All rights reserved.
    375380V-01
    GMT+8, 2026-1-13 06:12
