查看: 2256|回复: 0
[NI软件产品] NI VeriStand 2020R5 Win64Eng PC版完整版及运行版NIVS2020R5 20.5.0不含驱动版6.69GB
    发表于 2022-1-18 16:14:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2020R5
    文件大小: 7188609024 字节 (6.69 GB)
    修改日期: 2021-04-22 10:19
    MD5: a46ee0e33942fa81dbee908e5779433c
    SHA1: db6e19c9298018245f47484a27de37dfc18b4048
    SHA256: 9ea866837b1917d7d2a114613b021024c0cba5b14b88713f1384923ff1bd20d9
    CRC32: 511abad7
    Veristand2020R5.txt (572 Bytes, 下载次数: 0, 售价: 10 圆)
    VeriStand 2020 R5 Readme
    April 2021
    This file contains installation instructions and compatibility information for VeriStand 2020 R5.
    • VeriStand Manuals: New features, behavior changes, and other documentation
    VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be customized and extended with LabVIEW, NI TestStand, and other software tools. VeriStand includes a run-time editable user interface you can use to configure and implement triggered multi-file data logging, stimulus generation and playback, and real-time test sequencing.
    VeriStand 2020 R5 has the following requirements:
    Windows 64-bit Operating System
    Real-Time Targets
    Required Software
    • (Required) NI-DAQmx 20.7
    • (Required) NI-VISA 20.0
    • (Required) NI-SLSC 20.0.1
    • (Required) NI-XNET 20.5
    • (Recommended) NI R Series Multifunction RIO 20.7
    VeriStand software, which you can install from NI Measurement & Automation Explorer (MAX)
    Note  The following sections describe system requirements that apply if you use models, LabVIEW functionality, and .NET APIs in your system.
    Simulation Models
    To configure and run a simulation using your existing compiled model, you need only VeriStand installed. You need additional software to perform other tasks with models, as the following list describes:
    • To develop a model using MathWorks Simulink® software, you must be a licensed user and have MathWorks MATLAB® software (32-bit or 64-bit version) and MathWorks Simulink software installed on the host computer.
    • The VeriStand Model Framework supports only certain versions of MathWorks Simulink software. If the VeriStand Model Framework is used with an unsupported version of MathWorks Simulink®, VeriStand cannot initialize it.
    If you use other modeling environments, contact your model vendor for requirements for developing a model and converting it into a compiled model.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2020. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    • A .NET environment capable of interacting with .NET Framework 4.6.2-based assemblies, such as Microsoft Visual Studio 2015 or LabVIEW 2020.
    VeriStand supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 10 64-bit version (1909/8.1 Update 11)
    • Phar Lap ETS2
    • NI Linux Real-Time
    2 Releases after 2021 will no longer include support for Phar Lap ETS. For more information, refer to the Phar Lap RT OS EOL Road Map.
    Note  In 2021, VeriStand dropped support for Windows 7, Windows 8.1, Windows Server 2012, Windows Server 2008, and all Windows 32-bit systems. VeriStand 2020 R5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use VeriStand 2020 R5 to an unsupported OS. For more information about the changes to our OS support for 2021, refer to National Instruments Support for Windows 7, Windows Server 2008 R2, and All 32-Bit Windows.
    When formatting a disk with a PXI Linux RT system image for VeriStand 2020 R5, select Linux RT System Image 20.7 and enable support for the LabVIEW 2020 programming environment. This feed contains the same driver versions included with the VeriStand 2020 R5 installer and avoids driver version conflicts while deploying XNET to a real-time target.
    To install VeriStand, you must log on as an administrator or as a user with administrator privileges. You can activate VeriStand when prompted by the installer or activate later using NI License Manager. To use LabVIEW with VeriStand, install the like-numbered version of LabVIEW on the host computer.
    You should also disable any automatic virus detection programs before you install. Some virus detection programs interfere with the installer. Be sure to check your computer for viruses and enable your virus detection programs after installing VeriStand.
    You can install VeriStand with either the online installer or with installation media.
    Online Installer
    Installation Media
    The following sections describe issues to be aware of when you upgrade to VeriStand 2020 R5.
    Note  NI recommends that you also review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2020 R5. To access the documents, refer to the VeriStand Release Notes.
    Known Conflict with .NET 4.6.2 and MSVC 2010
    To run the VeriStand editor, the .NET Framework 4.6.2 must be installed. However, installing the .NET Framework 4.6.2 can break the Microsoft Visual C++ 2010 compilers, which are used to compile models for PharLap VeriStand targets. Using broken compilers results in error LNK1123. To resolve this Microsoft compiler issue, apply all service packs and updates for your version of Microsoft Visual Studio or Windows SDK. Refer to Microsoft Support Article 2757355 for more information.
    Uncompiled Models
    VeriStand 2020 R5 does not support communication with uncompiled models.
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2020. The LabVIEW functionality in VeriStand requires like-numbered versions.
    The VeriStand Model Framework contains changes to the files you use to develop and compile models in C/C++ and third-party modeling environments. If your system contains models compiled with previous versions of the Model Framework, choose from the following options to continue to use the models in VeriStand 2020 R5:
    • If you do not need to update your model, you can continue to use the model as-is.
    • If you need to update functionality of your model that does not require the changes in the latest version of the Model Framework, you can recompile the model against the deprecated Model Framework files. These files are installed at \VeriStand\version\ModelInterface\custom\src\obsolete.
    Models with Tuneable Parameters
    VeriStand Model Framework 2019 R3 to 2020 R4 does not support updates to tunable parameters if all the following are true:
    • The model uses tunable parameters.
    • The model uses model references to call subsystems.
    • The tunable parameter is not used or referenced in the top-level model.
    NI recommends recompiling this type of model with Model Framework 2020 R5. You can use the VeriStand suite installer to separately download the Model Framework. Models compiled with Model Framework 2020 R5 are compatible with VeriStand 2019 R3 to 2020 R5.
    Migrating Files from VeriStand 2010 to 2018 SP1
    VeriStand 2020 R5 can open projects from VeriStand 2010 to 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    VeriStand Custom Devices Not Included
    In VeriStand 2020 and later, built-in Custom Devices, including the Embedded Data Logger, are no longer included when installing from offline media. Use NI Package Manager to include all supported Custom Devices during installation. To install Custom Devices separately, see the release page for each Custom Device on the VeriStand Add-ons support page
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help...
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2020 R5 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including NI LabVIEW™ and NI TestStand™.Windows Start menu: All Programs»National Instruments»VeriStand 2020 R5 .NET API Help.
    VeriStand Model Framework IntroductionInformation about how to use the VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in VeriStand.You can access this guide from the \VeriStand\\ModelInterface\custom directory, where RootDrive is the drive where NI software installs and xxxx is the VeriStand version number.
    Note  You must explicitly select VeriStand Model Framework when you run the VeriStand installer.
    Note  If you install VeriStand with the compatible version of LabVIEW, you also can access a subset of the VeriStand Help, including information about the VeriStand VIs and extending VeriStand functionality with LabVIEW, from the LabVIEW Help. From LabVIEW, select Help»LabVIEW Help.
    • VeriStand Project—An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—VeriStand Stimulus Profile Editor examples are located in the \National Instruments\NI VeriStand\Examples directory.
      Note  On the Windows OS, the default location of the directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2020\examples\NI Veristand directory.
    © 2009–2021 National Instruments Corporation. All rights reserved.
    375380U-01
    GMT+8, 2026-1-13 06:12
