查看: 2057|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for Vector Signal Transceivers 14.0.2 Win32/64Eng LabVIEW2014矢量信号收发仪仪器设计库NIVST14.0.2
    发表于 2022-1-17 09:12:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW Instrument Design Libraries for Vector Signal Transceivers矢量信号收发仪仪器设计库
    LabVIEW Instrument Design Libraries for Vector Signal Transceivers提供的仪器功能可帮助您在PXI矢量信号收发仪(VST)上对FPGA进行编程。
    LabVIEW Instrument Design Libraries for Vector Signal Transceivers是用于PXI VST的驱动程序软件,可提供软件库。这些软件库可帮助主机和FPGA实现常见的仪器功能(例如硬件配置和数据通信),从而简化与VST上供应商代码的连接。LabVIEW Instrument Design Libraries for Vector Signal Transceivers包含基础板卡、多记录采集、波形定序器、触发器同步、嵌入式配置等库。
    14.0.2
    文件大小: 1514418976 字节 (1.41 GB)
    修改日期: 2015-12-17 05:00
    MD5: e6eaa1e808ab5fa9232750103c4b3168
    SHA1: 31550b04f9a091a68d04e0dee07aba514c94eb12
    SHA256: 7e69d73d7d77eaeb566a8b3a9c4944e697a1c9ca905a5bfa36ed5807d98d6829
    CRC32: aba22092
    NIVST14.0.2.txt (596 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW Instrument Design Libraries for Vector Signal Transceivers 14.0.2 Readme
    December 2015
    Thank you for using NI LabVIEW Instrument Design Libraries for Vector Signal Transceivers (the Instrument Design Libraries). This file contains important information about the instrument design libraries and is organized into the following sections:
    Accessing LabVIEW Sample Projects
    Driver Version Naming Changes
    Uninstalling/Modifying Instrument Design Libraries
    NI LabVIEW Instrument Design Libraries for Vector Signal Transceivers 14.0.2 includes improvements to the self-calibration procedure for the NI 5644R/5645R/5646R devices.
    NI PXIe-5644R/5645R/5646R Instrument Design Libraries 14.0 adds support for LabVIEW 2014.
    NI PXIe-5644R/5645R/5646R Instrument Design Libraries 13.5 adds support for the NI PXIe-5646R RF vector signal transceiver.
    NI PXIe-5644R/5645R Instrument Design Libraries 13.0 adds support for LabVIEW 2013.
    The instrument design libraries support the NI PXIe-5644R, NI PXIe-5645R, and NI PXIe-5646R RF vector signal transceivers (VSTs).
    The instrument design libraries support the following operating systems:
    • Windows 8.1 (32-bit and 64-bit) *
    * For VST devices, LabVIEW FPGA compilation tools cannot be executed on a machine running Windows 8.1. Refer to Cannot Compile FPGA VIs on a Windows 8 Computer for more information.
    Note  You must have a 64-bit OS to compile LabVIEW FPGA code.
    The instrument design libraries support the LabVIEW 2014 Real-Time Module real-time operating environment.
    Minimum System Requirements
    • RAM—2 GB
    • A screen resolution of 1,024 x 768 pixels
    • Windows 8.1/8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • Processor—Intel i7 or equivalent
    • RAM—6 GB
    • Windows 7 (64-bit), with all available critical updates and service packs
    Tip  NI recommends that you have 8 GB or more of system memory for compiling LabVIEW FPGA code.
    Note  You should install ADEs, such as NI LabVIEW, before installing the instrument design libraries. To add support for ADEs installed after installing the instrument design libraries, modify your instrument design libraries installation or launch the instrument design libraries installer again.
    • LabVIEW 2014 (32-bit only)
      Note  LabVIEW 2014 (32-bit) is the only supported version of LabVIEW for NI PXIe-5644R/5645R/5646R Instrument Design Libraries 14.0.2.
    • (optional) LabVIEW 2014 FPGA Module
    • (optional) LabVIEW 2014 Real-Time Module
    Installed Software, Documentation, and ExamplesFile Locations
    ItemInstalled Location on Windows 8.1 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    Instrument design libraries\Program Files\National Instruments\LabVIEW 2014\instr.lib\RF-RIO\
    Self-calibration executable\Program Files\National Instruments\NI VST\Self Calibration\
    Calibration support for LabVIEW\Program Files\National Instruments\LabVIEW 2014\instr.lib\niVST\Calibration\
    ItemInstalled Location on Windows 8.1 (64-bit)/7 (64-bit)/Vista (64-bit)
    Instrument design libraries\Program Files (x86)\National Instruments\LabVIEW 2014\instr.lib\RF-RIO\
    Self-calibration executable\Program Files (x86)\National Instruments\NI VST\Self Calibration\
    Calibration support for LabVIEW\Program Files (x86)\National Instruments\LabVIEW 2014\instr.lib\niVST\Calibration\
    Additional Calibration File Locations
    Note  $(NIEXTCCOMPILERSUPP) is configured as an environment variable on the target system. The variable evaluates by default to \Program Files\National Instruments\shared\ExternalCompilerSupport\C on a 32-bit system.
    ItemInstalled Location on Windows 8.1 (32-bit and 64-bit)/7 (32-bit and 64-bit)/Vista (32-bit and 64-bit)/XP
    Calibration header files<$(NIEXTCCOMPILERSUPP)>\include
    Calibration import libraries<$(NIEXTCCOMPILERSUPP)>\lib32\msvc
    Documentation for the instrument design libraries is located at Start»All Programs»National Instruments»Vector Signal Transceivers»LabVIEW. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI RF Vector Signal Transceivers HelpHTML/Windows HelpContains primary help content for NI RF VSTs. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI RF VSTs
    • Hardware device overviews
    • Programming overviews
    Getting Started Guide for your devicePrinted and PDFContains instructions for installing software and hardware, making first measurements, and troubleshooting information.
    NI RF Vector Signal Transceivers ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    ExamplesAccessing LabVIEW Sample Projects
    To access the LabVIEW sample projects and templates from the New Project dialog box, select Sample Projects in the left pane and navigate to the project that best matches your application requirements.
    NI LabVIEW Instrument Design Libraries for Vector Signal Transceivers versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI PXIe-5644R/5645R/5646R Instrument Design Libraries 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI PXIe-5644R/5645R Instrument Design Libraries 2012.1. The first version released under the new numbering scheme is NI PXIe-5644R/5645R Instrument Design Libraries 13.0.
    Perform the following procedure to uninstall the instrument design libraries:
    • Click Change/Remove.
    • Select NI LabVIEW Instrument Design Libraries for Vector Signal Transceivers 14.0.2 from the dialog box that appears.
    For Windows 8.1/8, complete the following steps:
    • Click the Uninstall button.
    As part of the instrument design libraries installation, the following software is installed. To completely remove the instrument design libraries from your system, you must also remove all of the following packages:
    • NI PXI Platform Services 15.0.0
    • NI System Configuration Runtime 15.0.0
    • NI-RIO 14.0
    • NI-RIO 14.0 for LabVIEW Real-Time
    • NI Measurement & Automation Explorer 15.0
    You can access the software and documentation known issues list online. Refer to the NI PXIe-5644R/5645R/5646R Instrument Design Libraries 14.0 and 14.0.2 Known Issues at ni.com for an up-to-date list of known issues in the instrument design libraries.
    The following items are changes in NI PXIe-5644R/5645R/5646R Instrument Design Libraries 14.0 from NI PXIe-5644R/5645R/5646R Instrument Design Libraries 13.5.
    467086Fixed an issue in which the fractional decimator spurious free dynamic range specification is out of specification at certain output sample rates.
    461909Fixed an issue in which the output valid and output calculated boolean indicators in the Fractional Decimator VI have inconsistent timing between assertions.
    The following items are changes in NI PXIe-5644R/5645R/5646R Instrument Design Libraries 13.5 from NI PXIe-5644R/5645R Instrument Design Libraries 13.0.
    438745Fixed an issue in which LabVIEW crashes when the niRFSA Initialize VI or the niRFSA_init function is called with an invalid RIO alias name.
    437169Fixed an issue in which the VST Streaming Sample Project provides poor streaming throughput.
    417655Fixed an issue in which interacting with a VST resource control causes the program to pause for several seconds.
    431606Fixed an issue in which the fixed point representation of the data overflowed on the FPGA while configuring the IQ Out Digital Correction.
    366548Fixed an issue in which the amplitude settling parameters are not present in the niRFRIO RF In Create Settling Settings VI and the niRFRIO RF Out Create Settling Settings VI.
    404057Fixed an issue in which you cannot create a new VST Streaming sample project with a file name prefix.
    401346Fixed an issue in which fetch requests can start past the end of a completed record.
    395781Fixed an issue in which you cannot rewrite a waveform.
    387196Fixed an issue in which NI PXIe-5644R and NI PXIe-5645R devices do not appear in the resource controls when using NI-RFSA or NI-RFSG.
    356334Fixed an issue in which not closing an external calibration session causes the device to lock.
    365006Fixed an issue in which uninstalling the NI PXIe-5644R/5645R/5646R Instrument Design Libraries does not remove files from <;Program Files>\National Instruments\RT Images\NI VST\.
    385412Fixed an issue in which PXI backplane triggers are invalid digital Start Triggers in the Simple VSA/VSG Sample Project.
    420800Fixed an issue in which the documentation for NI PXIe-5644R/5645R/5646R devices is not installed in document specific sub-folders at <;Program Files>\National Instruments\NI VST\documentation\.
    385746Fixed an issue in which the Help button in the VST Self Calibrate application opens an invalid webpage.
    386784Fixed an issue in which fetching a record not configured in the Simple VSA/VSG sample project is allowed.
    The following items are changes in NI PXIe-5644R/5645R Instrument Design Libraries 2012.1 from LabVIEW 2012 Support for NI PXIe-5644R.
    386326Fixed an issue in which calling Configure Clocks more than once could cause the DAC outputs of the VST to load in unexpected phases.
    372623Fixed an issue in which the DIO can fail to enable if a Boolean TRUE is wired to an Output Enable line.
    372033Fixed an issue in which the NI RF Vector Signal Transceivers Readme version 1.0.0 does not state that local compilations require a 64-bit operating system.
    365866Fixed an issue in which the NI PXIe-5644R Specifications includes an incorrect footnote in the Absolute Amplitude Accuracy table.
    365671Fixed an issue in which the Open Session VI from the ECB instrument design library does not clear the ECB port memory when the clear memory parameter is set to TRUE.
    • For more information about silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
    When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Windows 8.1 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, click the down arrow on the bottom left of the screen.
    For more information about NI support for Windows 8.1, visit ni.com/windows8.
    NI LabVIEW Instrument Design Libraries for Vector Signal Transceivers Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI LabVIEW Instrument Design Libraries for Vector Signal Transceivers will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of instrument design libraries that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2012–2015 National Instruments. All rights reserved.
    GMT+8, 2026-1-13 06:12
