查看: 2298|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for Vector Signal Transceivers 13.0 Win32/64Eng LabVIEW2013矢量信号收发仪仪器设计库NIVST13.0
    发表于 2022-1-17 08:57:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW Instrument Design Libraries for Vector Signal Transceivers矢量信号收发仪仪器设计库
    LabVIEW Instrument Design Libraries for Vector Signal Transceivers提供的仪器功能可帮助您在PXI矢量信号收发仪(VST)上对FPGA进行编程。
    LabVIEW Instrument Design Libraries for Vector Signal Transceivers是用于PXI VST的驱动程序软件,可提供软件库。这些软件库可帮助主机和FPGA实现常见的仪器功能(例如硬件配置和数据通信),从而简化与VST上供应商代码的连接。LabVIEW Instrument Design Libraries for Vector Signal Transceivers包含基础板卡、多记录采集、波形定序器、触发器同步、嵌入式配置等库。
    13.0
    文件大小: 1383260960 字节 (1.29 GB)
    修改日期: 2014-03-28 00:00
    MD5: 7aef8c1bfea1f09ff1af83158d363f9c
    SHA1: 46519bb8f667548bc6ca778e7d7d804a945e341b
    SHA256: 8e267d397f85cb55a43e4132044c790f85b7b8c49d47adfe22663c703bf12e4c
    CRC32: 47490c43
    NIVST13.0.txt (591 Bytes, 下载次数: 0, 售价: 10 圆)
    NI PXIe-5644R/5645R Instrument Design Libraries Readme
    Version 13.0.0
    Thank you for using NI PXIe-5644R/5645R Instrument Design Libraries (instrument design libraries). This file contains important information about the instrument design libraries and is organized into the following sections:
    • Supported Hardware
    • System Requirements
    • Updates and Notifications
    • Uninstalling/Modifying Instrument Design Libraries
    • Known Issues
    • How to Use NI Software with Microsoft Windows 8
    • NI PXIe-5644R/5645R Instrument Design Libraries Drops Support for Microsoft Windows XP and Windows Server 2003 in 2016
    • Important Information
    The instrument design libraries support the NI PXIe-5644R and NI PXIe-5645R RF vector signal transceivers (VSTs).
    The instrument design libraries support the following operating systems:
      Note  LabVIEW FPGA compilations cannot be executed on a machine running Windows 8. Refer to Cannot Compile FPGA VIs on a Windows 8 Computer for more information.
    Note  You must have a 64-bit OS to compile LabVIEW FPGA code.
    The instrument design libraries support the LabVIEW Real-Time Module 2013 real-time operating environment.
    Minimum System Requirements
    • RAM—2 GB
    • A screen resolution of 1,024 x 768 pixels
    • Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • Processor—Intel i7 or equivalent
    • RAM—6 GB
    • Windows 7 (64-bit), with all available critical updates and service packs
    Tip  NI recommends that you have 8 GB or more of system memory for compiling LabVIEW FPGA code.
    Application Development Environments (ADEs) and Application Software
    • LabVIEW 2013 (32-bit)
      Note  NI PXIe-5644R/5645R Instrument Design Libraries 13.0.0 (this version) supports LabVIEW 2013 (32-bit) only. For LabVIEW 2012 SP1 (32-bit) support, use NI PXIe-5644R/5645R Instrument Design Libraries 2012.1 available by visiting ni.com/info and entering vst2012.
    • (optional) LabVIEW FPGA Module 2013
    • (optional) LabVIEW Real-Time Module 2013
    • NI PXIe-5644R/5645R Instrument Design Libraries 13.0.0
    Installed File Names and LocationsFile Locations
    ItemInstalled Location on Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP:
    Instrument design libraries\Program Files\National Instruments\LabVIEW 2013\instr.lib\RF-RIO\
    Self-calibration executable\Program Files\National Instruments\NI VST\Self Calibration\
    Calibration support for LabVIEW\Program Files\National Instruments\LabVIEW 2013\instr.lib\niVST\Calibration\
    ItemInstalled Location on Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    Instrument design libraries\Program Files (x86)\National Instruments\LabVIEW 2013\instr.lib\RF-RIO\
    Self-calibration executable\Program Files (x86)\National Instruments\NI VST\Self Calibration\
    Calibration support for LabVIEW\Program Files (x86)\National Instruments\LabVIEW 2013\instr.lib\niVST\Calibration\
    Additional Calibration File Locations
    Note  $(NIEXTCCOMPILERSUPP) is configured as an environment variable on the target system. The variable evaluates by default to \Program Files\National Instruments\shared\ExternalCompilerSupport\C on a 32-bit system.
    ItemInstalled Location on Windows 8 (32-bit and 64-bit)/7 (32-bit and 64-bit)/Vista (32-bit and 64-bit)/XP:
    Calibration header files<$(NIEXTCCOMPILERSUPP)>\include
    Calibration import libraries<$(NIEXTCCOMPILERSUPP)>\lib32\msvc
    Documentation is available at Start»All Programs»National Instruments»Vector Signal Transceivers»LabVIEW. The documentation set is composed of the following documents:
    • NI RF Vector Signal Transceivers Readme
    • Getting started guide for your device—Printed and PDF format. Contains instructions for installing software and hardware, making first measurements, and troubleshooting information.
    • NI RF Vector Signal Transceivers Help—HTML help format. Contains hardware reference information, an overview of the hardware functions, and information about designing application-specific instrumentation.
    • Getting Started With Your NI Vector Signal Transceiver (VST)—Web page. Contains resources for designing application-specific instrumentation for your VST. Available at ni.com/vstgettingstarted.
    • Specifications for your device—Printed and PDF format. Provides signal information and specifications.
    • Calibration procedures for your device—PDF format. Provides instructions for calibrating your VST. The latest procedures are available at ni.com/calibration.
    Note  To view PDF documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    Perform the following procedure to uninstall the instrument design libraries:
    • Click Change/Remove.
    • Select NI PXIe-5644R/5645R Instrument Design Libraries 13.0.0 from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Right-click the Start screen.
    • Select All apps and launch the Control Panel.
    • Click the Uninstall button.
    As part of the instrument design libraries installation, the following software is installed. To completely remove the instrument design libraries from your system, you must also remove all of the following packages:
    • NI PXI Platform Services 3.2.3
    • NI System Configuration Runtime 5.5
    • NI-RIO 13.0
    • NI-RIO 13.0 for LabVIEW Real-Time
    • NI Measurement & Automation Explorer 5.5
    You can access the software and documentation known issues list online. Refer to the NI PXIe-5644R/5645R Instrument Design Libraries 13.0.0 Known Issues at ni.com for an up-to-date list of known issues in the instrument design libraries.
    • For more information about silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI PXIe-5644R/5645R Instrument Design Libraries Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments PXIe-5644R/5645R Instrument Design Libraries will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of instrument design libraries that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2012-2013 National Instruments. All rights reserved.
    GMT+8, 2026-1-13 06:13
