查看: 1954|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1.0 Win32/64Eng LabVIEW可重配置示波器仪器设计库NIREOSCIDL2016
    发表于 2022-1-14 16:47:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW可重配置示波器仪器设计库
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes可帮助您使用用户可编程的FPGA为PXI示波器开发所需的应用程序。
    NIREOSCIDL2016
    文件大小: 1288779867 字节 (1.20 GB)
    修改日期: 2017-02-21 05:05
    MD5: 0e55c0a443935a6bca87b39ff132dc82
    SHA1: e8b22eedb99d07f0160459612f4b5a8b47c7cd4f
    SHA256: 50c02a267bc59ab11b1b4e984e6630524a8c5edbb9ebbd972cfba75f1b5b8cc4
    CRC32: 9311bdee
    NIREOSCIDL16.1.txt (595 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW 2016 Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1 Readme
    January 2017
    This file contains important information about NI LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes, including installation information, new features, a partial list of bugs fixed, and known issues.
    Installation Information
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1 includes the following new features:
      • Support for the PXIe-5164 reconfigurable oscilloscope
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.0 includes the following new features:
      • Support for LabVIEW 2016 (32-bit)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 15.0 includes the following new features:
      • Support for LabVIEW 2015 (32-bit)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 14.0 includes the following new features:
      • Support for LabVIEW 2014 (32-bit)
      • Support for the NI PXIe-5170R and NI PXIe-5171R reconfigurable oscilloscopes
    • PXIe-5164
    • NI PXIe-5171R
    • NI PXIe-5170R (4 CH)
    • NI PXIe-5170R (8 CH)
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1 has the following requirements:
    • Pentium 4 or equivalent processor
    • 2 GB RAM
    Note  To compile LabVIEW FPGA VIs, your computer must be running a 64-bit operating system. To compile VIs for reconfigurable oscilloscope FPGA targets, your computer must have at least 4 GB of RAM. The minimum system requirements support only the reconfigurable oscilloscopes runtime and compiled projects.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  FPGA VIs cannot be compiled on a computer running Windows 8 or Windows 8.1. Refer to Cannot Compile FPGA VIs on a Windows 8 Computer for more information.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes does not support LabVIEW Real-Time Module or LabWindows™/CVI™ Real-Time Module.
    The following table lists the application software versions, including service packs, supported by LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1.
    Application SoftwareVersions Supported by LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1
    LabVIEW (32-bit)2016 or later
    LabVIEW FPGA Module (recommended)2016 or later
    Note  Support for LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes was first available in LabVIEW 2014 (32-bit).
    Note  You should install ADEs, such as NI LabVIEW, before installing the instrument design libraries. To add support for ADEs installed after installing the instrument design libraries, modify your instrument design libraries installation or launch the instrument design libraries installer again.
    As part of the instrument design libraries installation, the following software is installed. To completely remove the instrument design libraries installation from your system, you must also remove all of the following packages:
    • NI PXI Platform Services 16.0.0
    • NI System Configuration Runtime 16.0.0
    • NI-RIO 16.0
    • NI Measurement & Automation Explorer 16.0
    NI Software Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1 drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1 to an unsupported OS. Additionally, after installing LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1.
    Refer to the NI Reconfigurable Oscilloscopes Help, accessible from Start»All Programs» National Instruments»Reconfigurable Oscilloscopes»Reconfigurable Oscilloscope Documentation, for information about the instrument design libraries.
    © 2014–2017 National Instruments. All rights reserved.
    374867D-01
    GMT+8, 2026-1-13 06:14
