查看: 2122|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for IF Digitizers 19.0.1 Win32/64Eng LabVIEW IF数字化仪仪器设计库19.0.1
    发表于 2022-1-14 16:22:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW Instrument Design Libraries for IF Digitizers提供的仪器功能可帮助您在PXIe-5624R IF数字化仪上对FPGA进行编程。
    LabVIEW Instrument Design Libraries for IF Digitizers是一款旨在提供软件库的驱动软件。这些软件库通过为主机和FPGA提供通用的仪器功能(例如硬件配置和数据通信)来简化与模块上供应商代码的连接。LabVIEW Instrument Design Libraries for IF Digitizers还包括了范例项目和模板。
    19.0.1
    文件大小: 1462228992 字节 (1.36 GB)
    修改日期: 2021-04-10 01:01
    MD5: f7fe47648dc9ff9ea5ccd3915e193b1b
    SHA1: c8aaac338dd01cd1ea2e2085ff0c75490b1a367b
    SHA256: 00f6c55047961bd813f34ef434826226c6be31dfcf3012822520b7b77716a04e
    CRC32: a4a6bc30
    LV Instrument Design Libraries for IF Digitizers19.0.1.txt (629 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW Instrument Design Libraries for IF Digitizers 19.0 Readme
    July 2020
    Thank you for using NI LabVIEW Instrument Design Libraries for IF Digitizers (the Instrument Design Libraries). This file contains important information about the Instrument Design Libraries and is organized into the following sections:
    Accessing VIs and Functions
    Accessing LabVIEW Sample Projects
    NI LabVIEW Instrument Design Libraries for IF Digitizers Drops Support for Windows 7 (64-Bit) and Windows Server 2008 in 2021
    NI LabVIEW Instrument Design Libraries for IF Digitizers 19.0 adds support for LabVIEW 2019 (32-bit or 64-bit).
    The Instrument Design Libraries support the PXIe-5624 IF digitizer.
    System RequirementsMinimum System Requirements (Systems Not Compiling FPGA Images Locally)
    • Processor—Intel Pentium 4 or equivalent
    • RAM—4 GB
    • A supported 64-bit operating system, with all available critical updates and service packs
    Minimum System Requirements (Systems Compiling FPGA Images Locally)
    • RAM—8 GB
    Recommended System
    • Processor—Intel i7 or equivalent
    • RAM—16 GB
    Note  Memory requirements vary according to both the FPGA target and the FPGA VI you create for that target. Additional RAM beyond the recommended system requirements may be necessary to compile multiple FPGA images concurrently. Refer to the LabVIEW FPGA Module Readme for more information about determining your memory needs for FPGA VI compilation.
    Note  You should install LabVIEW and LabVIEW FPGA (recommended) before installing the Instrument Design Libraries. To add support for ADEs installed after installing the Instrument Design Libraries, modify your Instrument Design Libraries installation or relaunch the Instrument Design Libraries installer.
    • LabVIEW 2019 (32-bit or 64-bit)
    • (Recommended) LabVIEW 2019 FPGA Module
    Note  LabVIEW 2019 (32-bit or 64-bit) is the only supported version of LabVIEW for NI LabVIEW Instrument Design Libraries for IF Digitizers 19.0.
    NI LabVIEW Instrument Design Libraries for IF Digitizers 19.0 supports the following operating systems:
    • Windows 10, 8.11, 7 SP12 (64-bit)
    Note  In 2019, NI LabVIEW Instrument Design Libraries for IF Digitizers dropped support for all 32-bit Windows operating systems. NI LabVIEW Instrument Design Libraries for IF Digitizers will not install or run on an unsupported OS. Refer to NI LabVIEW Instrument Design Libraries for IF Digitizers Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    is an alias for the following National Instruments file folder location: Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
    Files
    Installed Location
    IF Digitizer Instrument Design Libraries\LabVIEW 2019\instr.lib\niIFDig
    Common Instrument Design Libraries\LabVIEW 2019\instr.lib\_nInstr
    Calibration Support for LabVIEW\LabVIEW 2019\instr.lib\niIFDig\Calibration
    Documentation for the Instrument Design Libraries is located at Start»National Instruments»IF Digitizers Documentation. The documentation set is composed of the following documents. You can find hardware documentation for the PXIe-5624 on ni.com/manuals.
    Document
    Format
    Description
    NI IF Digitizers HelpHTML/Windows HelpContains primary help content for NI IF digitizer products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI IF digitizers
    • Hardware device information
    • Programming overviews
    NI LabVIEW Instrument Design Libraries for IF Digitizers ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    The Instrument Design Libraries palette VIs are available on the host from the Functions»FPGA Interface»Software-Designed Instruments»IF Digitizers palette. For FPGA VIs, palettes specific to the FPGA target are available from the Functions palette.
    To access the LabVIEW sample projects and templates from the Create Project dialog box, select Sample Projects»IF Digitizers in the left pane and navigate to the project that best matches your application requirements.
    Known IssuesMigrating from Previous Releases
    When migrating from NI LabVIEW Instrument Design Libraries for IF Digitizers 15.0 or earlier, note that the new Instruction Framework library has stricter requirements about closing sessions. To avoid leaking Instruction Framework sessions, be sure to generate new 19.0 sample projects and call the sample-project Close Session VI as they illustrate.
    If you are not using a sample project directly, follow the example of the sample-project Close Session VI in your own code. After closing all other instrument design libraries that depend on them:
    • Close each niInstr Subsystem Map v1 Host.lvclass produced by niInstr Subsystem Map v1 Host.lvclass:Read Subsystem Map.
    • Close each niInstr FIFO Register Bus Host.lvclass produced by niInstr FIFO Register Bus V1 Host.lvclass:Open Session.vi
    Other Issues
    Refer to the NI LabVIEW Instrument Design Libraries for IF Digitizers 19.0 page online for a list of known issues.
    NI LabVIEW Instrument Design Libraries for IF Digitizers 19.0 does not include any bug fixes.
    NI LabVIEW Instrument Design Libraries for IF Digitizers Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI LabVIEW Instrument Design Libraries for IF Digitizers will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2014–2020 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help�Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    374894C-01
    GMT+8, 2026-1-13 06:12
