查看: 2004|回复: 0
[NI驱动程序] NI-845x Driver Software 2.1 Win32Eng NI-845x驱动软件2.1
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2022-1-11 15:57:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-845x支持I2C/SPI接口设备。
    NI-845x是一个驱动程序软件,用于对消费电子产品和集成电路的内部集成电路(I2C)、SCSI并行接口(SPI)或SMBus通信进行配置、编程和故障排除。NI-845x还提供一个通用数字I/O API,适用于各种应用,比如I2C设备的地址配置、LED切换或选通转换以及模拟转换器芯片常见的数据收发线等。
    2.1
    文件大小: 494558856 字节 (471.65 MB)
    修改日期: 2012-09-10 22:23
    MD5: 09c7e49ed19c12da7685da9bed27f3e9
    SHA1: 806f1fc104ce0b93086809ec90acdde4098e6253
    SHA256: 5c96f9dd3805c8d3db9e65ba17a12971cd90dc66badb53731a7170b34e18e34f
    CRC32: 50813c8a
    845x2.1.txt (522 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-845x 2.1 Readme
    August 2012
    ni.com/support
    This file contains information about the NI-845x software for Windows. Information in this file is organized in the following sections:
    • Documentation
    • Supported Platforms
    • Installing NI-845x
    • New Features and Changes
    • Known Issues
    • Bug Fixes
    • Errata
    The NI-845x Software and Hardware Installation Guide included with the NI-845x CD includes instructions for installing National Instruments hardware and software.
    The NI-845x Hardware and Software Manual is the primary document for NI 845x products. This manual includes an introduction to I2C and SPI buses, specifications for hardware, information about how to get started with application development, and a complete reference for all NI-845x functions.
    The NI-845x Hardware and Software Manual is in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at: www.adobe.com.
    Open the manual from Start»All Programs»National Instruments»NI-845x.
    Links to the NI-845x Hardware and Software Manual are in the online help for each NI-845x function within the National Instruments LabVIEW and LabWindows™/CVI™; development environments.
    Back to Top
    You can install and run this version of the NI-845x software on the following operating systems:
    • Windows Vista Business edition, Service Pack (SP) 1 or greater (32-bit and 64-bit)
    • Windows XP (32-bit) SP3 or greater
    • Windows Server 2003 R2, SP2 or greater (32-bit)
    • Windows Server 2008 R2, SP1 or greater (64-bit, not supported on Server Core Role)
    The NI-845x installer does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    Note:  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this may affect your use of Windows Server 2003 and what actions you may need to take, visit ni.com/info and enter the info code PAESupport.
    This version of the NI-845x software supports the following National Instruments hardware products:
    • National Instruments USB-8451 I2C/SPI Interface
    • National Instruments USB-8451 (OEM) I2C/SPI Interface
    • National Instruments USB-8452 I2C/SPI Interface
    • National Instruments USB-8452 (OEM) I2C/SPI Interface
    The NI-845x software supports only National Instruments I2C and SPI hardware products. For information about software for I2C and SPI products from other vendors, refer to the documentation you received with those products.
    This version of the NI-845x software supports the following development environments:
    • LabVIEW 2009 (32-bit and 64-bit), LabVIEW 2010 (32-bit and 64-bit), LabVIEW 2011 (32-bit and 64-bit) and LabVIEW 2012 (32-bit and 64-bit)
    • LabWindows/CVI 8.0 and higher
    • Microsoft Visual C/C++ 6.0 (or newer)
    Back to Top
    Installing NI-845x
    Before installing the NI-845x software, log on as Administrator or as a user with Administrator privileges. The NI-845x software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-845x software.
    • Insert the NI-845x installation media into your CD-ROM or DVD-ROM drive. The installer launches if your optical drive plays data disks automatically. If the installer does not launch automatically, navigate to the media using Windows Explorer and launch the autorun.exe file from your NI-845x installation media.
    • The installation wizard guides you through the necessary steps to install the NI-845x software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Back to Top
    New Features and Changes from Previous Releases
    The following changes were made to version 2.1 of the NI-845x software compared to NI-845x 2.0.1:
    • New Feature: Added support for LabVIEW 2009 (64-bit), LabVIEW 2010 (64-bit), LabVIEW 2011 (64-bit), LabVIEW 2012 (64-bit), and Microsoft Visual C (64-bit).
    • New Feature: Added support for the NI USB-8452 to be used as an I2C slave device.
    • New Feature: Added support for open-drain DIO for the NI USB-8452.
    • New Feature: SPI N-bit transactions—Added support for SPI basic and scripting APIs to perform transactions between 4..64 bits (NI USB-8452 only).
    • New Feature: Ack Polling—Allows the scripting API to wait for an EEPROM's write cycle to complete before continuing.
    • New Feature: uSec Delay—Improved the delay resolution from mSec to uSec when using the scripting API.
    • New Feature: Added I/O Trace Support for NI-845x function and VI calls.
    • New Feature: Variable Timeout—NI-845x API calls can have a user configurable timeout instead of a fixed 30 s timeout.
    • New Feature: System API Support—NI-845x devices can now be queried through the NI System Configuration API (no need for MAX to get the device info).
    • New Feature: Added support for multiple NI USB-8452 devices to concurrently stream to different devices.
    • New Firmware Upgrade Utility for the NI USB-8451 on Windows XP: A separate utility is now installed with this driver release that is necessary only when changing the NI USB-8451 firmware to the latest firmware installed with the NI-845x 2.1 driver. This utility is necessary only when running on Windows XP. If you have an older firmware device connected to a Windows 7/Vista computer the firmware upgrades automatically.
    The following changes were made to version 2.0.1 of the NI-845x software compared to NI-845x 2.0:
    • New Feature: Added support for LabVIEW 2012 (32-bit).
    • Change: Removed support for LabVIEW 8.6.
    • Change: Removed support for Windows XP prior to Service Pack 3.
    The following changes were made to version 2.0 of the NI-845x software compared to NI-845x 1.1.5:
    • New Feature: Added support for the NI USB-8452 (OEM) device.
    • New Feature: SPI Streaming support (NI USB-8452 only).
    • New Feature: Onboard pullups for I2C (NI USB-8452 only).
    • New Feature: Increased clock rates for I2C and SPI (NI USB-8452 only).
    • New Feature: Support for I2C Fast Mode Plus and High Speed Mode (NI USB-8452 only).
    • Change: Improved multithreading support.
    The following changes were made to version 1.1.5 of the NI-845x software compared to NI-845x 1.1.4:
    • New Feature: Added support for LabVIEW 2011 (32-bit).
    • Change: Removed support for LabVIEW 8.5.
    • Change: Removed support for Windows XP prior to Service Pack 2.
    The following changes were made to version 1.1.4 of the NI-845x software compared to NI-845x 1.1.3:
    • New Feature: Added support for LabVIEW 2010 (32-bit).
    • Change: Removed support for LabVIEW 8.2.
    • Change: Dropped support for Windows 2000.
    The following changes were made to version 1.1.3 of the NI-845x software compared to NI-845x 1.1.2:
    • New Feature: Added support for LabVIEW 2009 (32-bit).
    • Change: Removed support for LabVIEW 7.1.
    The following changes were made to version 1.1.2 of the NI-845x software compared to NI-845x 1.1.1:
    • New Feature: Added support for LabVIEW 8.6.
    • Change: Removed support for LabVIEW 8.0.
    • Change: Location of the C language interface and example files changed:
      The language interface and example files for Microsoft Visual C/C++ 6.0 have moved from the Program Files\National Instruments\NI-845x\MS Visual C\ directory to the Users\Public\Documents\National Instruments\NI-845x\MS Visual C\ directory on Windows Vista and the Documents and Settings\All Users\Shared Documents\National Instruments\NI-845x\Examples\MS Visual C\ directory on Windows XP/2000. This change satisfies Windows Vista requirements when allowing users to save changes or add files to the directory.
      The NIEXTCCOMPILERSUPP environment variable is provided as an alias to the location of C language support files (.h and .lib). You can use this variable when compiling and linking an application.
    The following changes were made to version 1.1.1 of the NI-845x software compared to NI-845x 1.1:
    • New Feature: Added support for LabVIEW 8.5.
    Back to Top
    Known issues
    The following items are the IDs and titles of a subset of issues known to be present in NI-845x. If you have a CAR ID, you can search this list to validate issues known not to have been addressed for this release. This is not an exhaustive list of known issues in the current version of NI-845x.
    Issue NumberIssue
    None
    Back to Top
    The following items are the IDs and titles of a subset of issues fixed in a given release of the NI-845x software. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed.
    The following items were fixed between version 2.0.1 and version 2.1 of the NI-845x software.
    Bug IDFixed Issue
    363149Running an I2C script with an uninitialized clock rate on the NI USB-8452 no longer defaults to a 1 MHz clock. It now defaults to a 100 kHz clock.
    358686Streaming API: Tightened the timing between drive high/low signals and starting of the waveform to minimize the response to the first DRDY.
    329125The TI ADS833x EVM example has been rewritten to allow for selecting multiple channels.
    245664Fixed an issue that could cause the NI USB-8451 to hang when connected to a noisy SDA signal.
    The following items were fixed between version 1.1.5 and version 2.0 of the NI-845x software.
    Bug IDFixed Issue
    278688Refnum constants/controls cannot be created for configurations, making it harder to create subVIs.
    207029NI 845x runs at half speed with two devices.
    898939NI 845x does not reference count LabVIEW open calls.
    The following items were fixed between version 1.1.1 and version 1.1.2 of the NI-845x software.
    Bug IDFixed Issue
    110899Memory leak in NI-845x Create Config Reference and NI-845x Close Reference.
    Back to Top
    Additional Programming TopicsMulti-Process Support
    On Windows Vista and Windows 7, access to the NI USB-845x I2C/SPI Interface is limited to a single process. This means you cannot control a single NI USB-845x I2C/SPI interface from multiple executables at the same time.
    Back to Top
    Errata to the NI-845x Hardware and Software Manual
    The following items are comments, clarifications, or updates to the current NI-845x documentation that haven't been added currently:
    • Clarification of DRDY (data ready) SPI signal is discussed in a white paper on ni.com: SPI Stream Configuration using the TI ADS833x Example in the "Configuring CONV, DRDY, and CS" section. You can find this white paper by going to ni.com/infocode and entering: TIADS833X.
    Back to Top
    • Review \_Legal Information\_Legal Information.txt for information on including legal information in installers built with NI products.
    Copyright 2005–2012 National Instruments. All rights reserved.
    CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    GMT+8, 2025-10-29 12:17
