查看: 2043|回复: 0
[NI软件产品] NI RFmx 21.3 Full Win32/64Eng NI Wireless Test Standard Software完整版ni-rfmx-suite_21.3.0
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2022-1-11 09:56:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    21.3
    文件大小: 2811322368 字节 (2.62 GB)
    修改日期: 2021-10-22 16:54
    MD5: d42f8c75c2f7e2947c8020928cbff051
    SHA1: 2442a0ed40d204a6738a13a05df259f4885fa505
    SHA256: d593907574c826855481841a6be27d0588a7cb788440550e04c1cc3ce63f2923
    CRC32: c5bbc267
    RFMX21.3.txt (578 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx 21.3 Readme
    October 2021
    This file contains important information about the RFmx, including system requirements, and installation instructions.
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx Bluetooth
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx has the following requirements:
    RFmx 21.3 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 21.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 21.3 to an unsupported OS. Additionally, after installing RFmx 21.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support, visit http://www.ni.com/r/win32bitsupport.
    RFmx 21.3 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx
    LabVIEW2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1, or 2021
    LabWindows™/CVI™2015 or later
    RFmx Test Software is available for download from NI Software Product Downloads.
    © 2019–2021 National Instruments Corporation. All rights reserved.
    377996G-01
    GMT+8, 2025-11-19 12:46
