查看: 1972|回复: 0
[NI软件产品] NI RFmx 20.7.1 Full Win32/64Eng NI Wireless Test Standard Software完整版ni-rfmx-suite_20.7.1
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2022-1-11 09:51:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    20.7.1
    文件大小: 4290447360 字节 (4.00 GB)
    修改日期: 2021-07-22 01:54
    MD5: 093961e70b7b11d9b5660c62cbda0931
    SHA1: 0554beb0c2b15fb378061e1e594c97b5b916d2da
    SHA256: 7f47217ef8ca61982253d127d6f36424fa4f5cd387dbd281581af1bc7bd919da
    CRC32: 4f49dba0
    RFMX20.7.1.txt (580 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx 20.7.1 Readme
    July 2021
    This file contains important information about the RFmx, including system requirements, and installation instructions.
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx Bluetooth
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx has the following requirements:
    RFmx 20.7.1 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 20.7.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 20.7.1 to an unsupported OS. Additionally, after installing RFmx 20.7.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support, visit http://www.ni.com/r/win32bitsupport.
    RFmx 20.7.1 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1
    LabWindows™/CVI™2015 or later
    RFmx Test Software is available for download from NI Software Product Downloads.
    © 2019–2021 National Instruments Corporation. All rights reserved.
    377996F-01
    GMT+8, 2025-11-19 12:49
