查看: 2036|回复: 0
[RTE运行引擎] NI RFmx 20.7.0 Runtime Win64Eng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_20.7.0
    3 小时前
  • 签到天数: 3767 天
    连续签到: 18 天
    发表于 2022-1-11 09:49:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    20.7.0RTEx64
    文件大小: 806303744 字节 (768.95 MB)
    修改日期: 2021-04-20 12:37
    MD5: e946407a4ab5a5a7ae1173ffcb1aef51
    SHA1: b35ab1ba82b1cb23234d537ea273bceba6320218
    SHA256: d9fde0b42a13fb1e11d0c2b6e8e66864cb5f00a48d8be9bf3688ee6e132d8785
    CRC32: 39809cab
    RFMX20.7.0RTEx64.txt (611 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 20.7 Readme
    April 2021
    This file contains important information about the RFmx, including system requirements, and installation instructions.
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx Bluetooth
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx has the following requirements:
    RFmx 20.7 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 20.7 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 20.7 to an unsupported OS. Additionally, after installing RFmx 20.7, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support, visit http://www.ni.com/r/win32bitsupport.
    RFmx 20.7 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1
    LabWindows™/CVI™2015 or later
    RFmx Test Software is available for download from NI Software Product Downloads.
    © 2019–2021 National Instruments Corporation. All rights reserved.
    377996E-01
    GMT+8, 2026-1-9 11:33
