查看: 2075|回复: 0
[RTE运行引擎] NI RFmx 20.6 Runtime Win32Eng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite-x86_20.6.0
    3 小时前
  • 签到天数: 3767 天
    连续签到: 18 天
    发表于 2022-1-11 09:45:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    20.6RTEx86
    文件大小: 778301440 字节 (742.25 MB)
    修改日期: 2021-01-20 14:49
    MD5: 384ec14ce611713a47c98f572f40b9b9
    SHA1: 1e868a9fc4d1cd3377f6994f88674fb4a115bc4b
    SHA256: 2c2af09eba379e11d0b26334378f3bd7ddae7165345cbbeccaef3081f8cb93ba
    CRC32: e9bf7d64
    RFMX20.6RTEx86.txt (621 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 20.6 Readme
    January 2021
    This file contains important information about the RFmx, including system requirements, and installation instructions.
    RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx Noise Figure
    • RFmx Phase Noise
    • RFmx WLAN
    • RFmx Bluetooth
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx has the following requirements:
    RFmx 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note In 2019, RFmx dropped support for all 32-bit Windows operating systems. RFmx will not install or run on an unsupported OS. Refer to RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx 20.6 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020
    LabWindows™/CVI™2015 or later
    RFmx Test Software is available for download from NI Software Product Downloads.
    RFmx will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2019–2021 National Instruments. All rights reserved.
    377996D-01
    GMT+8, 2026-1-9 11:18
