NI RFmx 20.6 Full Win32/64Eng NI Wireless Test Standard Software完整版ni-rfmx-suite_20.6.0
RFmx
20.6
文件大小: 2416920576 字节 (2.25 GB)
修改日期: 2021-01-20 14:50
MD5: d0df0bcd08cb2fe3fe9a573896dc374a
SHA1: ef631d1899ab69efa05caf7d6aee9a1d23e58bc8
SHA256: 4229362212d2ee4a580419f094719c5385a0edf0fab64eaa53d5ebad484fe6de
CRC32: 646320fb
RFMX20.6.txt
(578 Bytes, 下载次数: 1, 售价: 10 圆)
RFmx 20.6 ReadmeJanuary 2021 This file contains important information about the RFmx, including system requirements, and installation instructions. System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 Legal Information
The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes. Application Software - RFmx Waveform Creator
- RFmx SpecAn
- RFmx Demod
- RFmx Noise Figure
- RFmx Phase Noise
- RFmx WLAN
- RFmx Bluetooth
- RFmx NR
- RFmx LTE
- RFmx WCDMA
- RFmx TD-SCDMA
- RFmx EV-DO
- RFmx CDMA2k
- RFmx GSM
Drivers System RequirementsRFmx has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Windows 10/8.1/7, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx 20.6 supports the following 64-bit operating systems: - Windows 10/8.1 1 /7 SP1 2
- Windows Server 2016
- Windows Server 2012 R2 1
- Windows Server 2008 R2 SP1 2
1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574 for more information about how to install these updates. Note In 2019, RFmx dropped support for all 32-bit Windows operating systems. RFmx will not install or run on an unsupported OS. Refer to RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support. For more information about the changes to our OS support for 2016, visit ni.com/r/OSSupport2016. Application Software SupportRFmx 20.6 supports the following application software versions, including service packs. | Application Software | Versions Supported by RFmx | | LabVIEW | 2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 | | LabWindows™/CVI™ | 2015 or later | Installation InstructionsNI automates software installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. RFmx Test Software is available for download from NI Software Product Downloads. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021RFmx will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport. Legal InformationCopyright © 2019–2021 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 377996D-01
