查看: 2477|回复: 0
[NI软件产品] NI RFmx Demod/Analog Modulation/Digital Modulation 20.6 Full Win32/64Eng RFmx解调/模拟调制/数字调制20.6完整版
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2022-1-6 16:59:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    20.6x86/64
    文件大小: 770715648 字节 (735.01 MB)
    修改日期: 2021-01-20 15:18
    MD5: 1d213c6bc3f2125b8514b4b4e269b05e
    SHA1: 6a412177208ae83dbc98fda541199d06d867550b
    SHA256: 06f8e75e2e4446513712a70e72403a94ada09d5c565217bf3748a57eb0483b84
    CRC32: 69c8db70
    NI官方下载和百度网盘下载地址:
    RFMXdemod20.6.txt (568 Bytes, 下载次数: 1, 售价: 10 圆)
    RFmx Demod 20.6 Readme
    January 2021
    This file contains important information about the RFmx Demod, including system requirements, and installation instructions.
    Installed Software
    RFmx Demod Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Demod provides a highly optimized RF measurement experience. Use RFmx Demod to perform demodulation measurements on analog and digital modulation signal formats, including QAM and ASK.
    RFmx Demod 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx Demod 20.0 includes the following new features:
    RFmx Demod 19.1 includes the following new features:
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5841
    • PXIe-5840
    • PXIe-5841 with PXIe-5655
    RFmx Demod 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Demod dropped support for all 32-bit Windows operating systems. RFmx Demod will not install or run on an unsupported OS. Refer to RFmx Demod Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx Demod dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx Demod 20.6 to an unsupported OS. Additionally, after installing RFmx Demod 20.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Application SoftwareVersions Supported by RFmx Demod
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020
    LabWindows™/CVI™2015 or later
    Required Software
    • NI-RFSG 14.0.1 or later
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx Demod»RFmx Demod Measurement Interactive Panel to launch the RFmx Demod Measurement Interactive Panel.
    RFmx Demod palette VIs are available from the Functions » Measurement I/O » NI-RFmx » Demod palette.
    Documentation for RFmx Demod is located at Start » All Programs » National Instruments » RFmx Demod » RFmx Demod Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx Demod HelpHTML/Windows HelpContains primary help content for RFmx Demod. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Demod
    • A complete reference for all RFmx Demod programming functions and VIs
    RFmx Demod 20.6 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Demod examples at Start » All Programs » National Instruments » RFmx Demod » RFmx Demod Examples.
    The following items are behavior changes in RFmx Demod 19.1 from RFmx Demod 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxDemod Analyze (IQ) API. Use RFmxDemod Analyze (IQ, 1 Wfm) API instead
    The following items are the behavior changes in RFmx Demod 19.0 from RFmx Demod 3.0.
    You can access the RFmx Demod known issues list online at RFmx Demod 20.6 Known Issues.
    You can access the RFmx Demod bug fix list online at RFmx Demod 20.6 Bug Fixes. This list describes a subset of issues fixed in the RFmx Demod. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    RFmx Demod will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2014–2021 National Instruments. All rights reserved.
    374855P-01
    GMT+8, 2025-11-19 12:45
