查看: 1553|回复: 0
[RTE运行引擎] NI RFmx Demod/Analog Modulation/Digital Modulation 19.1 Runtime Win64Eng RFmx解调/模拟调制/数字调制19.1运行版
    昨天 07:58
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2022-1-6 16:52:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    19.1RTEx64
    文件大小: 532189184 字节 (507.54 MB)
    修改日期: 2019-10-18 18:03
    MD5: 49e4c16d5b5f20f88fcd1cf4a7c44c6a
    SHA1: 72d91b31de3ff2072819dec405a5d053b21c5b55
    SHA256: e632a932aca8f1c238182434931d257293f266f1ce0c245fbdcd3789920a8fa1
    CRC32: c827757a
    NI官方下载和百度网盘下载地址:
    RFMXdemod19.1RTEx64.txt (567 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx Demod 19.1 Readme
    October 2019
    This file contains important information about the RFmx Demod, including system requirements and installation instructions.
    Installed Software
    RFmx Demod Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Demod provides a highly optimized RF measurement experience. Use RFmx Demod to perform demodulation measurements on analog and digital modulation signal formats, including QAM and ASK.
    RFmx Demod 19.1 includes the following new features:
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    RFmx Demod 19.0 includes the following new features:
    • Support for PXIe-5830 and PXIe-5831
    RFmx Demod 3.0 includes the following new features:
    • Support for PXIe-5820
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help .
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsRFmx Demod has the following requirements:
    RFmx Demod 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Demod dropped support for all 32-bit Windows operating systems. RFmx Demod will not install or run on an unsupported OS. Refer to RFmx Demod Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx Demod supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx Demod. To add support for application software installed after installing RFmx Demod modify your RFmx Demod installation or launch the RFmx Demod installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support .
    Application SoftwareVersions Supported by RFmx Demod
    LabWindows™/CVI™2013 SP2 or later
    Required Software
    • NI-RFSG 14.0.1 or later
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx Demod»RFmx Demod Measurement Interactive Panel to launch the RFmx Demod Measurement Interactive Panel.
    RFmx Demod palette VIs are available from the Functions » Measurement I/O » NI-RFmx » Demod palette.
    Documentation for RFmx Demod is located at Start»All Programs»National Instruments»RFmx Demod»RFmx Demod Documentation . The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx Demod HelpHTML/Windows HelpContains primary help content for RFmx Demod. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Demod
    • A complete reference for all RFmx Demod programming functions and VIs
    RFmx Demod 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Demod examples at Start»All Programs»National Instruments»RFmx Demod»RFmx Demod Examples.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    The following items are behavior changes in RFmx Demod 19.1 from RFmx Demod 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxDemod Analyze (IQ) API. Use RFmxDemod Analyze (IQ, 1 Wfm) API instead
    The following items are the behavior changes in RFmx Demod 19.0 from RFmx Demod 3.0.
    You can access the software and documentation known issues list online. Refer to the RFmx Demod Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in RFmx Demod . This is not an exhaustive list of issues fixed in the current version of the RFmx Demod . If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx Demod 19.1 from RFmx Demod 19.0
    245802Fixed an issue with EVM instability for 8PSK modulation.
    249283Fixed an issue to report an error when measurement bandwidth exceeds the device instantaneous bandwidth on PXIe-5668 and PXIe-5665 devices.
    234240Fixed an intermittent error occurring at Analyze IQ API when performing a composite measurement with different averaging count for each measurement
    The following items are changes in RFmx Demod 3.0 from RFmx Demod 2.5
    248862Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    244193Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx Demod will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2014–2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    374855M-01
    GMT+8, 2025-5-14 01:44
