查看: 1795|回复: 0
[RTE运行引擎] NI RFmx Demod/Analog Modulation/Digital Modulation 19.0 Runtime Win32Eng RFmx解调/模拟调制/数字调制19.0运行版
    昨天 10:31
  • 签到天数: 3600 天
    连续签到: 8 天
    发表于 2022-1-6 16:50:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    19.0RTEx86
    文件大小: 532473856 字节 (507.81 MB)
    修改日期: 2019-07-17 15:35
    MD5: c13a8203fced349bae1d41f53fea2ef4
    SHA1: 9b89b3f65054c18a6e052a18ae2d2550e0a7c973
    SHA256: fe61c79231e2d23b5bd702b6de1c781cc8dbdb4a73cb3561f098489fa0f6ddb1
    CRC32: 333990bb
    NI官方下载和百度网盘下载地址:
    RFMXdemod19.0RTEx86.txt (575 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx Demod 19.0 Readme
    June 2019
    This file contains important information about RFmx Demod, including installation instructions, new features, bugs fixes, and known issues.
    Installed Software
    RFmx Demod Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Demod provides a highly optimized RF measurement experience. Use RFmx Demod to perform demodulation measurements on analog and digital modulation signal formats, including QAM and ASK.
    RFmx Demod 19.0 includes the following new features:
    • Support for PXIe-5830 (EAP) and PXIe-5831 (EAP)
    RFmx Demod 3.0 includes the following new features:
    • Support for NI PXIe-5820
    RFmx Demod 2.5 includes the following new features:
    • Addition of RFmx Debug Configuration Utility to configure debug settings
    • Support for querying configuration attributes without calling RFmxDemod Commit API
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830 (EAP)
    • PXIe-5831 (EAP)
    • 4 GB RAM*
    RFmx Demod 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2019, RFmx Demod dropped support for all 32-bit Windows operating systems. RFmx Demod will not install or run on an unsupported OS. Refer to RFmx Demod Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx Demod
    LabWindows™/CVI™2013 SP2 or laterOther Required Software
    • NI-RFSG 14.0.1 or later
    ItemInstalled Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\Demod\Examples
    Examples\LabVIEW \examples\RFmx\Demod
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMX.Fx40.dll
    Select Start»All Programs»National Instruments»RFmx Demod»RFmx Demod Measurement Interactive Panel to launch the RFmx Demod Measurement Interactive Panel.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output»Modular Instruments»NI-RFmx»Demod. You can also select the Search tab to search all installed examples by keyword.
    You can access all the installed RFmx Demod examples at Start»All Programs»National Instruments»RFmx Demod»RFmx Demod Examples.
    Documentation for RFmx Demod is located at Start»All Programs»National Instruments»RFmx Demod»RFmx Demod Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx Demod HelpHTML/Windows HelpContains primary help content for RFmx Demod. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Demod
    • A complete reference for all RFmx Demod programming functions and VIs
    RFmx Demod 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx Demod palette VIs are available from the Functions»Measurement I/O»NI-RFmx»Demod palette.
    The following items are the behavior changes in RFmx Demod 19.0 from RFmx Demod 3.0.
    The following items are the behavior changes in RFmx Demod 2.3.1 from RFmx Demod 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string)
    • The alias 'default@Demod' for the default signal name is accepted as a valid signal name in a selector string parameter
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported
    The following items are the IDs and titles of a subset of issues fixed in RFmx Demod. This is not an exhaustive list of issues fixed in the current version of the RFmx Demod. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx Demod 3.0 from RFmx Demod 2.5
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    The following items are changes in RFmx Demod 2.5 from RFmx Demod 2.4.
    644169Fixed an issue to enhance the CFO estimation for QAM.
    699425Fixed an issue to align the Quadrature skew definition with RFmx Waveform Creator.
    The following items are changes in RFmx Demod 2.4 from RFmx Demod 2.3.1.
    656549Fixed an issue with EVM measurements resulted from the IQ imbalance application to half-sine filtered OQPSK signal.
    656458Fixed an issue with impairments estimation of OQPSK modulated signal.
    640495Fixed an issue where switching between measurements from an RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    641411Fixed an issue with running DDEM measurement with Auto Level.
    RFmx Demod will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2014–2019 National Instruments. All rights reserved.
    374855L-01
    GMT+8, 2025-7-22 04:55
