查看: 1750|回复: 0
[RTE运行引擎] NI RFmx Demod/Analog Modulation/Digital Modulation 2.5 Runtime Win32Eng RFmx解调/模拟调制/数字调制2.5运行版
    4 小时前
  • 签到天数: 3600 天
    连续签到: 8 天
    发表于 2022-1-6 16:34:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    2.5RTEx86
    文件大小: 314621944 字节 (300.05 MB)
    修改日期: 2018-07-03 17:46
    MD5: b9288b3616cdbdbf990531e88fe3447b
    SHA1: 0b722f612579fac5c3210ae6287f2ca88ab64eac
    SHA256: 3309090bb6afdad063b7ac85aab9516ff6a7f97e102d630b1dccc85f90467388
    CRC32: 2805c72f
    NI官方下载和百度网盘下载地址:
    RFMXdemod2.5RTEx86.txt (533 Bytes, 下载次数: 0, 售价: 5 元)
    NI-RFmx Demod 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx Demod and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx Demod 2.5 includes the following new features:
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for querying configuration attributes without calling RFmxDemod Commit API
    NI-RFmx Demod 2.3.1 includes the following new features:
    • Support for CFO estimation mode
    • Support for Search Length attribute to decouple acquisition time and number of symbols to measure
    NI-RFmx Demod 2.3 includes the following new features:
    • Support for Burst Analysis in DDemod
    • Support for Linearized GMSK Pulse Shaping Filter and 3*Pi/8 - 8PSK modulation for EDGE DDemod
    • Support for enabling or disabling IQ offset correction in EVM measurement
    Caution Before you install NI-RFmx Demod 2.5, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    Caution If you are using only RFmx LabVIEW Runtime products, NI recommends uninstalling all the RFmx Runtime products before installing a newer version of RFmx Runtime products.
    Note  Some of the installed NI-RFmx Demod.NET examples require the NI-RFSG .NET Class Library. For these examples to build and run successfully, install NI-RFSG .NET Class Library before or after installing NI-RFmx Demod.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx Demod 2.5 supports the following operating systems:
    Note  In 2016, NI-RFmx Demod dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx Demod 2.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx Demod 2.5 to an unsupported OS. Additionally, after installing NI-RFmx Demod 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  NI-RFmx Demod 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI, or Microsoft Visual Studio®, before installing NI-RFmx Demod. To add support for ADEs installed after installing NI-RFmx Demod, modify your NI-RFmx Demod installation or launch the NI-RFmx Demod installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    • NI LabWindows/CVI 2010 or later
    Note  NI-RFmx Demod does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
    • NI-RFSG 14.0.1 or later
      • (32-bit) windows\system32
    ItemInstalled Location
    Function Panels
    \Shared\CVI\Bin\niRFmxDemod.lfp
    \Shared\CVI\Bin\niRFmxInstr.lfp
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET, NI TestStand
    Examples\NI-RFmx\Demod\Examples
    LabWindows/CVI
    Examples\CVI\samples\NI-RFmx\Demod
    Examples\LabVIEW \examples\RFmx\Demod
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx Demod»NI-RFmx Demod Measurement Interactive Panel to launch the NI-RFmx Demod Measurement Interactive Panel.
    Documentation for NI-RFmx Demod is located at Start»All Programs»National Instruments»NI-RFmx Demod»NI-RFmx Demod Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx Demod HelpHTML/Windows HelpInformation about NI-RFmx Demod. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx Demod
    • A complete reference for all NI-RFmx Demod programming functions and VIs
    NI-RFmx Demod 2.5 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx Demod palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    NI-RFmx Demod functions are available in LabWindows/CVI from the Library»RFmx Demod Library menu.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-RFmx Demod examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFmx» Demod or by directory structure at RFmx» Demod.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Demod" to locate all NI-RFmx Demod examples.
    You can also access all the installed NI-RFmx Demod examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFmx Demod»NI-RFmx Demod Examples.
    Refer to ni.com/examples for these examples and for more information.
    The following items are the behavior changes in NI-RFmx Demod 2.3.1 from NI-RFmx Demod 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@Demod' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx Demod 2.5 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx Demod 2.5.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx Demod. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx Demod. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx Demod 2.5 from NI-RFmx Demod 2.4.
    644169Fixed an issue to enhance the CFO estimation for QAM.
    699425Fixed an issue to align the Quadrature skew definition with NI-RFmx Waveform Creator.
    The following items are changes in NI-RFmx Demod 2.4 from NI-RFmx Demod 2.3.1.
    656549Fixed an issue with EVM measurements resulted from the IQ imbalance application to half-sine filtered OQPSK signal.
    656458Fixed an issue with impairments estimation of OQPSK modulated signal.
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    641411Fixed an issue with running DDEM measurement with Auto Level.
    The following items are changes in NI-RFmx Demod 2.3.1 from NI-RFmx Demod 2.3.
    653303Fixed an issue with synchronization bit pattern detection with MSK modulation and differential encoding.
    654064Fixed an issue where high magnitude error reported with FSK modulation when a valid synchronization bit pattern is detected.
    657793Fixed an issue in measurement filter used with FSK modulation signal with RRC pulse shaping.
    The following items are changes in NI-RFmx Demod 2.3 from NI-RFmx Demod 2.2.
    © 2014–2018 National Instruments. All rights reserved.
    374855J-01
    GMT+8, 2025-7-21 15:15
