查看: 2079|回复: 0
[NI软件产品] NI RFmx Demod/Analog Modulation/Digital Modulation 2.3.0 Full Win32/64Eng RFmx解调/模拟调制/数字调制2.3.0完整版
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2022-1-6 16:18:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    2.3x86/64
    文件大小: 684584920 字节 (652.87 MB)
    修改日期: 2017-05-11 20:05
    MD5: bbe960989637c92ac66a60f1518e0af3
    SHA1: 1a5126147373902caf9ec327ebf5e560ddaf008a
    SHA256: af2fb8b829fb1cca2b6eeace5b04a0130cbd7cb676c42939a80936a03835d762
    CRC32: 1c85a691
    NI官方下载和百度网盘下载地址:
    RFMXdemod2.3.0.txt (521 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx Demod 2.3 Readme
    May 2017
    This file contains important information about NI-RFmx Demod and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx Demod
    NI-RFmx Demod 2.3 includes the following new features:
    • Support for Burst Analysis in DDemod
    • Support for Linearized GMSK Pulse Shaping Filter and 3*Pi/8 - 8PSK modulation for EDGE DDemod
    • Support for enabling or disabling IQ offset correction in EVM measurement
    NI-RFmx Demod 2.2 includes the following new features:
    • Support for LO leakage avoidance when using vector signal transciever as the analyzer
    • Support for Limited Configuration Change when sweeping frequency and reference level in test application
    • Addition of offset constellation trace for OQPSK modulation
    • Addition of advanced instrument attributes to the measurement interactive panel
    NI-RFmx Demod 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    Caution Before you install NI-RFmx Demod 2.3, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    Caution If you are using only RFmx LabVIEW Runtime products, NI recommends uninstalling all the RFmx Runtime products before installing a newer version of RFmx Runtime products.
    Note  Some of the installed NI-RFmx Demod.NET examples require the NI-RFSG .NET Class Library. For these examples to build and run successfully, install NI-RFSG .NET Class Library before or after installing NI-RFmx Demod.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx Demod 2.3 supports the following operating systems:
    Note  NI-RFmx Demod 2.3 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI, or Microsoft Visual Studio®, before installing NI-RFmx Demod. To add support for ADEs installed after installing NI-RFmx Demod, modify your NI-RFmx Demod installation or launch the NI-RFmx Demod installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016, or 2017
    • NI LabWindows/CVI 2010 or later
    Note  NI-RFmx Demod does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
    • NI-RFSG 14.0.1 or later
      • (32-bit) windows\system32
    ItemInstalled Location
    Function Panels
    \Shared\CVI\Bin\niRFmxDemod.lfp
    \Shared\CVI\Bin\niRFmxInstr.lfp
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET, NI TestStand
    Examples\RFmx\Demod\Examples
    LabWindows/CVI
    Examples\CVI\samples\RFmx\Demod
    Examples\LabVIEW \examples\RFmx\Demod
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx Demod»NI-RFmx Demod Measurement Interactive Panel to launch the NI-RFmx Demod Measurement Interactive Panel.
    Documentation for NI-RFmx Demod is located at Start»All Programs»National Instruments»NI-RFmx Demod»NI-RFmx Demod Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx Demod HelpHTML/Windows HelpInformation about NI-RFmx Demod. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx Demod
    • A complete reference for all NI-RFmx Demod programming functions and VIs
    NI-RFmx Demod 2.3 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx Demod palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    NI-RFmx Demod functions are available in LabWindows/CVI from the Library»RFmx Demod Library menu.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-RFmx Demod examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFmx» Demod or by directory structure at RFmx» Demod.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Demod" to locate all NI-RFmx Demod examples.
    You can also access all the installed NI-RFmx Demod examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFmx Demod»NI-RFmx Demod Examples.
    Refer to ni.com/examples for these examples and for more information.
    NI-RFmx Demod 2.3 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx Demod drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx Demod 2.3 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx Demod 2.3 to an unsupported OS. Additionally, after installing NI-RFmx Demod 2.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx Demod 2.3 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFmx Demod 2.3 installation, the following software is installed. To completely remove the NI-RFmx Demod 2.2 installation from your system, you must also remove the following packages:
    • NI-RFmx Demod Runtime 2.3
    • NI-RFmx Demod Runtime 2.3 (64-bit)
    The following item is a behavior change in NI-RFmx Demod 2.0 from NI-RFmx Demod 1.2.
    • OQPSK constellation returns two samples per symbol.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx Demod 2.3 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx Demod 2.3.
    The following items are changes in NI-RFmx Demod 2.3 from NI-RFmx Demod 2.2.
    The following items are changes in NI-RFmx Demod 2.2 from NI-RFmx Demod 2.1.
    533768Fixed an issue by renaming the FSK result, Mean RMS Deviation Error to Mean RMS FSK Error.
    The following items are changes in NI-RFmx Demod 2.1 from NI-RFmx Demod 2.0.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    © 2014–2017 National Instruments. All rights reserved.
    374847F-01
    GMT+8, 2025-11-19 12:47
