查看: 1806|回复: 0
[NI驱动程序] NI-USRP 21.0.1 Driver x64Win10 32/64bitEng NI通用软件无线电外设仪器驱动程序21.0.1下载
    昨天 15:45
  • 签到天数: 3536 天
    连续签到: 6 天
    发表于 2021-12-16 09:33:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI USRP
    NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
    NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
    21.0.1
    文件大小: 5912709120 字节 (5.51 GB)
    修改日期: 2021-11-02 04:18
    MD5: 47147a18577f3acedbfb3157b86a5de1(官方正确)
    SHA1: 310617602711c86e3ebc1797c13d99875a7c00f3
    SHA256: 89297546c37b9094caae6607a8aaf5ee408e464506651f976cbcd01cec09282d
    CRC32: 01a3bea3
    USRP21.0.1.txt (552 Bytes, 下载次数: 0, 售价: 10 元)
    NI-USRP 21.0 Readme
    September 2021
    This file contains installation instructions and compatibility information for NI-USRP.
    • NI-USRP Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-USRP: New features, behavior changes, and other documentation
    Finding Examples, Lessons, and Sample Projects
    This software installation provides support for customers using software defined radio (USRP) devices, software defined radio reconfigurable (USRP RIO) devices, and software defined radio stand-alone (USRP Stand-Alone) devices, as specified in the Supported Hardware section. To program your USRP, USRP RIO, or USRP Stand-Alone device, use the NI-USRP API or USRP RIO Instrument Design Library (IDL) included in the NI-USRP instrument driver.
    The getting started guide for your device provides information about how to install, configure, test, and begin using a USRP, USRP RIO, or USRP Stand-Alone device.
    NI-USRP 21.0 has the following requirements:
    • RAM— 2 GB RAM (64-bit)
    • Windows 10 with all available critical updates and service packs
    • Connector requirements shown in the following table
    DeviceUSB 2.0 or HigherGigabit EthernetPCI/MXI Express
    USRP-2900/2901
    USRP-2920/2921/2922
    USRP-2930/2932
    USRP-2940/2942/2943/2944/2945 √1
    USRP-2950/2952/2953/2954/2955 √1
    Ettus USRP X410 √2
    1 Recommended PCIe Gen1 x4 Interfaces: PCIe-8371 or PXIe-83742 Recommended PCIe Gen3 x8 Interfaces: PCIe-8398 or PXIe-8394
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW.
    Ethernet Support on USRP-294x/295x Devices
    NI USRP-294x/295x devices support both 1G Ethernet (1 GbE) and 10G Ethernet (10 GbE) using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G. Users programming with LabVIEW can use Ethernet.
    Note  The FPGA cannot be modified when the 294x/295x device is connected through Ethernet.
    Ethernet Support on Ettus USRP X410 Device
    Ethernet Support for the Ettus USRP X410 device depends on the utilized FPGA image.
    NI-USRP 21.0 supports the following operating systems:
    Note: NI-USRP no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-USRP 21.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-USRP 21.0 to an unsupported OS. Additionally, after installing NI-USRP 21.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-USRP 21.0 supports the following application software versions, including service packs. If you are using LabVIEW, you should install it before installing NI-USRP. To add support for application software installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
    DeviceLabVIEW 2018, 2019, 2020, or 2021NI Linux RT
    USRP-2900/2901
    USRP-2920/2921/2922
    USRP-2930/2932
    USRP-2945/2955
    Ettus USRP X410√*
    *The Ettus USRP X410 is only supported on LabVIEW 2020 and LabVIEW 2021.
    Download the NI-USRP installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    NI-USRP 21.0 includes the following new features:
    • Support for Ettus USRP X410 for use with LabVIEW 2021 and LabVIEW 2020
    • Support for LabVIEW 2021
    NI-USRP 20.5 adds performance and architectural enhancements.
    NI-USRP 20.0 includes the following new features:
    • Support for LabVIEW 2020
    • Support for LabVIEW NXG 5.0 and LabVIEW Communications System Design Suite 5.0
    The following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Refer to the Application Software Support section for information regarding supported application software versions.
    • USRP-2900
    • USRP-2901
    • USRP-2920
    • USRP-2921
    • USRP-2922
    • USRP-2930
    • USRP-2932
    • USRP-2940 40 MHz
    • USRP-2940 120 MHz
    • USRP-2942 40 MHz
    • USRP-2942 120 MHz
    • USRP-2943 40 MHz
    • USRP-2943 120 MHz
    • USRP-2944
    • USRP-2945
    • USRP-2950 40 MHz
    • USRP-2950 120 MHz
    • USRP-2952 40 MHz
    • USRP-2952 120 MHz
    • USRP-2953 40 MHz
    • USRP-2953 120 MHz
    • USRP-2954
    • USRP-2955
    • Ettus Research USRP2*
    • Ettus Research N200*
    • Ettus Research N210*
    • Ettus Research X300*
    • Ettus Research X310*
    • Ettus USRP X410
    *The NI-USRP instrument driver supports TwinRX, UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, XCVR2450 daughterboards. Other daughterboards may also be compatible, but they have not been tested.
    Device-specific information about these modules is included in the NI-USRP Help.
    The following are the behavior changes in NI-USRP 21.0 from NI-USRP 20.5:
    • Dropped support for LabVIEW NXG 5.0 and LabVIEW Communications System Design Suite 5.0.
    The following are the behavior changes in NI-USRP 18.5 from NI-USRP 18.0:
    • The SDR Basic Elements IDL is obsolete in instrument driver version 18.5.
    Documentation for NI-USRP is located at Start»National Instruments»NI-USRP»Documentation and online at ni.com/manuals. The documentation set is composed of the following documents.
    DocumentFormatLocationDescription
    NI-USRP 21.0 ReadmeHTML (this document)Start»National Instruments»NI-USRP»NI-USRP Documentation and online at ni.com/manualsContains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-USRP HelpHTML/Windows HelpStart»National Instruments»NI-USRP»NI-USRP Documentation and online at ni.com/manualsThe primary document for most USRP products used in LabVIEW. The help is an installed and online version of a traditional user manual that includes the following information:
    • An introduction to USRP
    • A complete programming reference for all NI-USRP programming functions and VIs in LabVIEW
    NI-USRP ManualOnline HelpOnline at ni.com/manualsThe primary document for most USRP products. The help is an installed and online version of a traditional user manual that includes the following information:
    Getting started guide for your devicePrinted and PDFOnline at ni.com/manualsContains software and hardware installation, configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePDFOnline at ni.com/manualsLists technical specifications for your device.
    Manual for your deviceOnline HelpOnline at ni.com/manualsContains information about supported hardware, including pinouts, block diagrams, and specifications.
    NI-USRP examples, lessons, and sample projects are available in the following locations.
    Content TypeDescriptionLabVIEW
    ExamplesNI-USRP includes several example applications that serve as interactive tools, programming models, and building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality.
    Note  You can access additional examples from the Code Sharing Community at ni.com/usrp.
    • From the Start menu at Start»National Instruments»NI-USRP»Examples.
    • From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
    LessonsNI-USRP includes lessons that guide you through the process of identifying and demodulating an FM signal with your device.N/A
    Sample ProjectsUSRP RIO includes several sample projects that serve as starting points to build a USRP RIO streaming application.From the Create Project dialog, select Sample Projects in the left pane and navigate to the NI-USRP Simple Streaming project.
    Ettus USRP X410 Reference FPGA ProjectNI-USRP includes a LV FPGA reference project that generates default bitfiles designed for the Ettus USRP X410. The reference project also serves as a starting point to customize the FPGA of the Ettus USRP X410.For detailed information on the Ettus USRP X410 Reference Project, visit ni.com/r/x410refproj.
    ©2011–2021 National Instruments Corporation. All rights reserved.
    374760AA-01
    GMT+8, 2025-5-12 02:49
