查看: 1728|回复: 0
[NI驱动程序] NI-FGEN 21.3 Driver x64Win10 32/64bitEng/Jpn NI-FGEN波形发生器仪器驱动程序21.3
    昨天 15:45
  • 签到天数: 3536 天
    连续签到: 6 天
    发表于 2021-12-7 16:39:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    NI-FGEN是一款NI仪器驱动程序,可实现复杂测量解决方案所需的频率扫描和跳频、波形链接和循环以及频移键控(FSK)调制。 NI-FGEN驱动程序可兼容可互换虚拟仪器(IVI),它具有一系列操作和属性,可以执行波形或信号发生器的功能,并提供交互式软件前面板和示例。
    Win32/64Eng/Jpn 21.3
    文件大小: 3271684096 字节 (3.05 GB)
    修改日期: 2021-10-23 05:48
    MD5: 9c0c2a29677e5ac294791ce3fd3c8b42(官方正确)
    SHA1: 83f64c379fe9b4a662f1bc5f95db55515e6cda7d
    SHA256: 600d94eebcfb115f8a10b5227027cf58047bf65878a30a601747ad52b7b863ca
    CRC32: 7845acc8
    FGEN21.3.txt (550 Bytes, 下载次数: 0, 售价: 10 元)
    NI-FGEN 21.3 Readme
    October 2021
    This file contains important information about NI-FGEN, including installation instructions, supported operating systems, new features and application software.
    • NI-FGEN Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-FGEN Manuals: New features, behavior changes, and other documentation
    Onboard Signal Processing
    Upgrading Firmware
    NI-FGEN is an NI instrument driver that enables you to implement frequency sweeping and hopping, waveform linking and looping, and frequency shift keying (FSK) modulation for complex measurement solutions. NI-FGEN is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the waveform or signal generator and includes an interactive soft front panel and examples.
    NI-FGEN 21.3 has the following requirements:
    • Processor—1 GHz or faster 64-bit (x64) processor
    • RAM—2 GB RAM (64-bit)
    • Windows 10 with all available critical updates and service packs
    The following list details the hardware models supported in NI-FGEN 21.3:
    Hardware ProductSupported Under Windows 10
    NI-DAQmx-Based Waveform Generators
    PXI/PCI-5402
    PXI-5404
    PXI/PCI-5406
    PXI/PCI-5412
    PXI/PCI-5421
    PXI-5422
    PXI-5441
    PXIe–5442
    PXIe–5450
    PXIe–5451
    NI 5413, 5423, and 5433 Waveform Generators
    PXIe–5413
    PXIe–5423
    PXIe–5433
    NI-FGEN 21.3 supports the following operating systems:
    • NI Linux® Real-Time
    Note    NI-FGEN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-FGEN 21.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-FGEN 21.3 to an unsupported OS. Additionally, after installing NI-FGEN 21.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-FGEN 21.3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-FGEN
    LabVIEW2018, 2019, 2020, 2021
    LabVIEW Real-Time Module12018, 2019, 2020, 2021
    LabVIEW Real-Time Module with NI Linux® Real-Time2019, 2020, 2021
    LabVIEW NXG5.0, 5.1
    LabWindows™/CVI™2017 and later
    LabWindows™/CVI™ Real-Time Module12017 and later
    1No support for PXIe-5413/5423/5433 waveform generators
    If you are using the NI-FGEN .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-FGEN .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-FGEN installer to install the the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    Download the NI-FGEN installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note
    • NI Script Editor is no longer installed with NI-FGEN.
    NI-FGEN no longer installs IVI Compliance Package (ICP). NI-FGEN supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    • NI-FGEN 21.3 adds support for NI Linux® Real-Time
    • NI-FGEN 21.3 adds support for LabVIEW 2021
    • NI-FGEN 20.0 adds support for LabVIEW 2020 and LabVIEW NXG 5.0
    NI-FGEN driver when used with NI Linux® Real-Time will not support Onboard Signal Processing. This feature remains supported on Windows.
    Upgrading Firmware
    The PXIe-5442, PXIe-5450, and PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files (x86)\National Instruments\NI-FGEN\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update.
    • NI-FGEN 21.3 removes support for Manual Peer-to-Peer functionality.
    • NI-FGEN 21.3 removes support for NI-HWS.
    • The NI-FGEN Soft Front Panel has been replaced by InstrumentStudio, which is automatically installed when you install the NI-FGEN driver. You can access InstrumentStudio in one of the following ways:
      • From the Windows start menu, select National Instruments»InstrumentStudio [year]. This launches InstrumentStudio and runs a soft front panel populated with devices detected on your system.
      • From Measurement & Automation Explorer (MAX), select a device and then click Test Panels.... This launches InstrumentStudio and runs a soft front panel for the device you selected.
    Note   The deprecated NI-FGEN Soft Front Panel remains available for download. Visit Legacy Soft Front Panels for NI-FGEN for more information.
    Refer to the NI Signal Generators Help, accessible from Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Documentation, for information about NI-FGEN.
    You can access all the installed NI-FGEN examples for LabVIEW, LabWindows/CVI, C, and .NET at Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Examples and online at ni.com/examples. Examples also are available online that demonstrate integrating NI waveform generators with NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-FGEN are located in the LabVIEW XXXX\examples\instr\niFgen directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–FGEN or by directory structure at instr»niFgen.
    • Click the Search tab to search all installed examples by keyword. For example, search for "FGEN" to locate all waveform generator examples.
    The following sections detail considerations for using LabVIEW NXG with NI-FGEN.
    LabVIEW NXG Hardware Support[tr][/tr]
    PXI/PCI-5402
    PXI-5404
    √2
    PXI/PCI-5406
    PXI/PCI-5412
    PXI/PCI-5421
    PXI-5422
    PXI-5441
    PXIe–5442
    PXIe–5450
    PXIe–5451
    PXIe–5413
    PXIe–5423
    PXIe–5433
    2 External calibration of this module is not supported in LabVIEW NXG.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 2007–2021 National Instruments Corporation. All rights reserved.
    374945W-01
    GMT+8, 2025-5-12 03:08
