查看: 2698|回复: 0
[NI软件套件] Embedded Control and Monitoring Software Suite Spring 2020 Win32Eng 嵌入式控制和监控软件套件2020春季英文版ECMSS20.0
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2021-10-27 15:44:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    套件包含:
    LabVIEW专业版
    LabVIEW Real-Time模块
    LabVIEW FPGA模块
    LabVIEW MathScript模块
    LabVIEW高级信号处理工具包
    LabVIEW数字滤波器设计工具包
    视觉采集软件
    视觉开发模块
    LabWindows/CVI执行评测工具包
    LabWindows/CVI Real-Time模块
    LabWindows/CVI SQL工具包
    LabWindows/CVI完整版
    Measurement Studio企业版
    发布日期
    2020/5/15
    包含的版本
    Spring 2020
    受支持的操作系统
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    语言
    English
    校验和
    2020Spring
    32Eng
    文件名: ni-embedded-control-and-monitoring-suite-x86_20.0.0.49152-0+f0_offline.iso
    文件大小: 31959193600 字节 (29.76 GB)
    修改日期: 2020-05-12 04:44
    MD5: d0d7e36b3d9481634ac19bb2ecfe2657(官方正确)
    SHA1: ac7902955fb48166b858e9a823261f51e30c5554
    SHA256: 3a80b569a622657d39afb3250af3945fcf703bce34f9caeefaaefee22351602a
    CRC32: 2d7e9dea
    2020SpringEng.txt (685 Bytes, 下载次数: 0, 售价: 40 圆)
    NI Embedded Control and Monitoring Software Suite Spring 2020 Readme
    May 2020
    This file contains important information about the NI Embedded Control and Monitoring Software Suite, including installation instructions, compatibility issues, and a list of products included on the media.
    Products Included on the NI Embedded Control and Monitoring Software Suite Media
    NI Embedded Control and Monitoring Software Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Installation InstructionsInstalling and Activating the NI Embedded Control and Monitoring Software Suite
    NI installs the NI Embedded Control and Monitoring Software Suite using NI Package Manager. If you do not already have NI software installed, the NI Embedded Control and Monitoring Software Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the NI Embedded Control and Monitoring Software Suite. For more information on the NI Embedded Control and Monitoring Software Suite activation, refer to National Instruments Software Activation.
    Complete the following steps to install products using the NI Embedded Control and Monitoring Software Suite media.
    • Insert the NI Embedded Control and Monitoring Software Suite installation media.
    Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the NI Embedded Control and Monitoring Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the NI Embedded Control and Monitoring Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    Back to Top
    The following products are included on the NI Embedded Control and Monitoring Software Suite media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    LabVIEW Professional Development System202032-bit and 64-bit
    LabVIEW NXG5.064-bit
    Add-Ons
    Version
    Bitness
    LabVIEW Advanced Signal Processing Toolkit202032-bit and 64-bit
    LabVIEW Desktop Execution Trace Toolkit202032-bit
    LabVIEW Digital Filter Design Toolkit202032-bit and 64-bit
    LabVIEW FPGA Compile Farm Toolkit202032-bit and 64-bit
    LabVIEW FPGA ISE Compilation Tool 14.7202032-bit and 64-bit
    LabVIEW FPGA Module202032-bit
    LabVIEW FPGA Vivado Compilation Tool 2019.1202032-bit and 64-bit
    LabVIEW MathScript Module202032-bit
    LabVIEW NXG FPGA Module5.064-bit
    LabVIEW NXG Real-Time Module5.064-bit
    LabVIEW NXG Web Module5.064-bit
    LabVIEW Real-Time Module202032-bit
    LabVIEW Unit Test Framework Toolkit202032-bit and 64-bit
    LabVIEW VI Analyzer Toolkit202032-bit and 64-bit
    NI Vision Development Module202032-bit and 64-bit
    JKI VI Package Manager202032-bit and 64-bit
    Driver Software
    Version
    FlexRIO with Modular I/O20.0
    FlexRIO with Integrated I/O20.0
    NI CompactRIO20.0
    FPGA Interface C API20.0
    NI R Series Multifunction RIO20.0
    NI-DAQmx20.0
    NI-IMAQ20.0
    NI-IMAQ I/O20.0
    NI-IMAQdx20.0
    NI-Serial20.0
    NI-Sync20.0
    NI-VISA20.0
    NI-XNET20.0
    Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit.
    To compare the products included in NI Software Suites, including the NI Embedded Control and Monitoring Software Suite, refer to Compare NI Software Suites.
    Back to Top
    Back to Top
    Back to Top
    NI Embedded Control and Monitoring Software Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2014–2020 National Instruments. All rights reserved.
    377939C-01
    GMT+8, 2026-1-30 02:31
