查看: 3921|回复: 0
[NI软件产品] NI ECU Test System Maintenance Software 21.1.1 x64Win10 64bitEng NI ECU测试系统维护软件ECUTSMS21.1.1下载
    14 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2021-10-11 15:55:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ECU测试系统维护软件
    ECU测试系统维护软件可帮助您执行现场诊断测试并管理ECU测试系统(ECUTS)。
    ECU测试系统维护软件是用于管理ECUTS配置(例如仪器资源和校准信息)的应用软件。该软件还包括现场诊断测试仪(FDT)工具,用于现场的诊断和测试。ECUTS随附了ECU测试系统维护软件。
    ECU测试系统维护软件21.1.1发布日期
    2021/9/21
    包含的版本
    21.1.1完整版
    受支持的操作系统
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 1285627904 字节 (1.20 GB)
    修改日期: 2021-09-21 22:31
    MD5: d26ecc1d08061bc230563e0b04e32473
    SHA1: a05bd7ab45b8aaef1cd8aab9f278faa3586e3c57
    SHA256: a4007928e706fc850a23cb9c45f66ee23e02968b552af3a2eef8889b982878f3
    CRC32: db9d966e
    ECUTSMS21.1.1.txt (840 Bytes, 下载次数: 0, 售价: 10 圆)
    ECU Test System Maintenance Software 21.1 Readme
    July 2021
    This file contains important information about getting started with the ECU Test System Maintenance Software 21.1, including system requirements and installation instructions.
    • ECU Test System Maintenance Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Use the ECU Test System Maintenance Software to interactively test ECU Test System (ECUTS) hardware components. Launch the ECU Test System Maintenance Software from the Test System Maintenance Software desktop shortcut.
    The ECU Test System Maintenance Software has the following requirements:
    • Pentium 4 G1 (or equivalent) or later 64-bit (x64) processor
    • 2 GB of disk space
    • 4 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 pixels screen resolution
    • 64-bit version of Windows 10 (version 1903)
    The ECU Test System Maintenance Software uses the LabVIEW 2019 Run-Time Engine.
    The ECUTS is delivered with the ECU Test System Maintenance Software 21.1 installed. If you need to install the ECU Test System Maintenance Software yourself, download the installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Dropped support for the FDT-16040.
    Refer to the Test System Maintenance Software Help, accessible via the Help button in the ECU Test System Maintenance Software, for information about the ECU Test System Maintenance Software.
    © 2020–2021 National Instruments Corporation. All rights reserved.
    • Additional Test System Maintenance Software licenses are located in the \Test System Maintenance directory.
    378228C-01
    GMT+8, 2026-4-1 14:20
