查看: 2608|回复: 0
[NI软件套件] HIL and Real-Time Test Software Suite 20.6 Win32ENG 硬件在环和实时测试软件套件2020秋季版英文
  • 签到天数: 3629 天
    连续签到: 3 天
    发表于 2021-9-15 10:09:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    HIL and Real-Time Test Software Suite是用于验证嵌入式软件和运行模型物理测试的软件集合。
    HIL and Real-Time Test Software Suite将LabVIEW集成开发环境(IDE)与应用软件和模块相结合,用于创建实时测试应用程序。借助该套件,您可以开发仿真模型和控制算法,并将其部署到实时硬件中。您还可以添加自定义功能,确保测试系统具有足够的灵活性来满足几乎任何应用需求,此外,您还可以在NI可重配置I/O硬件上执行高速仿真和处理。
    套件包含:
    LabVIEW专业版开发系统
    LabVIEW高级信号处理工具包
    VeriStand完整版开发系统
    LabVIEW Real-Time模块
    LabVIEW FPGA模块
    LabVIEW控制设计与仿真模块
    LabVIEW状态图模块
    相关NI设备驱动程序
    2020Fall ENG32/64
    发布日期
    2021/1/8
    包含版本
    Fall 2020
    受支持的操作系统
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    应用程序位数
    32/64位
    语言
    英文
    校验和
    文件大小: 34502977536 字节 (32.13 GB)
    修改日期: 2021-01-07 08:15
    MD5: 918168c2140a470589f51034d04c6844(官方正确)
    SHA1: c45662089173d1756f82ecfe7979a9255da27a40
    SHA256: 51d2afee73f6a771390a44300229e2ce9deba577156c0f7839be9cc2c7444842
    CRC32: fe15f760
    HILRT TSS20.6ENG.txt (699 Bytes, 下载次数: 2, 售价: 40 圆)
    NI HIL and Real-Time Test Software Suite Fall 2020 Readme
    January 2021
    This file contains important information about the NI HIL and Real-Time Test Software Suite, including installation instructions, compatibility issues, and a list of products included on the media.
    Products Included on the NI HIL and Real-Time Test Software Suite Media
    NI HIL and Real-Time Test Software Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Installation InstructionsInstalling and Activating the NI HIL and Real-Time Test Software Suite
    NI installs the NI HIL and Real-Time Test Software Suite using NI Package Manager. If you do not already have NI software installed, the NI HIL and Real-Time Test Software Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the NI HIL and Real-Time Test Software Suite. For more information on the NI HIL and Real-Time Test Software Suite activation, refer to NI Software Activation.
    If you install software using the NI HIL and Real-Time Test Software Suite installation media, complete the following steps to install products:
    • Insert the NI HIL and Real-Time Test Software Suite installation media.
    Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the NI HIL and Real-Time Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the NI HIL and Real-Time Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    The following products are included on the NI HIL and Real-Time Test Software Suite media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    ProductVersionBitness
    LabVIEW (32-bit) Chinese2020 SP132-bit
    LabVIEW (32-bit) English2020 SP132-bit
    LabVIEW (32-bit) French2020 SP132-bit
    LabVIEW (32-bit) German2020 SP132-bit
    LabVIEW (32-bit) Japanese2020 SP132-bit
    LabVIEW (32-bit) Korean2020 SP132-bit
    VeriStand2020 R464-bit
    Add-Ons
    JKI VI Package Manager202032-bit and 64-bit
    LabVIEW Advanced Signal Processing Toolkit (32-bit)202032-bit
    LabVIEW Control Design and Simulation Module (32-bit)202032-bit
    LabVIEW Desktop Execution Trace Toolkit202032-bit and 64-bit
    LabVIEW Digital Filter Design Toolkit (32-bit)202032-bit
    LabVIEW FPGA Compilation Tool for ISE 14.7202032-bit and 64-bit
    LabVIEW FPGA Compilation Tool for Vivado 2019.1202064-bit
    LabVIEW FPGA Compile Farm Toolkit202032-bit and 64-bit
    LabVIEW FPGA Module (32-bit) Chinese2020 f132-bit
    LabVIEW FPGA Module (32-bit) English2020 f132-bit
    LabVIEW FPGA Module (32-bit) Japanese2020 f132-bit
    LabVIEW MathScript Module (32-bit) Chinese202032-bit
    LabVIEW MathScript Module (32-bit) English202032-bit
    LabVIEW MathScript Module (32-bit) French202032-bit
    LabVIEW MathScript Module (32-bit) German202032-bit
    LabVIEW MathScript Module (32-bit) Japanese202032-bit
    LabVIEW MathScript Module (32-bit) Korean202032-bit
    LabVIEW Model Interface Toolkit202032-bit
    LabVIEW Real-Time Module Chinese202032-bit
    LabVIEW Real-Time Module English202032-bit
    LabVIEW Real-Time Module Japanese202032-bit
    LabVIEW Unit Test Framework Toolkit (32-bit)202032-bit
    LabVIEW VI Analyzer Toolkit (32-bit)202032-bit
    VeriStand Model Framework2020 R432-bit and 64-bit
    VeriStand Model Generation Support for LabVIEW 20202020 R432-bit and 64-bit
    Driver Software
    FlexRIO with Integrated I/O20.6.032-bit and 64-bit
    FlexRIO with Modular I/O20.6.032-bit and 64-bit
    NI CompactRIO20.5.032-bit and 64-bit
    NI PXI Platform Services20.5.032-bit and 64-bit
    NI R Series Multifunction RIO20.0.032-bit and 64-bit
    NI-488.220.0.032-bit and 64-bit
    NI-DAQmx20.1.032-bit and 64-bit
    NI-DCPower20.5.032-bit and 64-bit
    NI-Industrial Communications for EtherCAT20.0.032-bit
    NI-SWITCH20.0.032-bit and 64-bit
    NI-Serial20.0.032-bit and 64-bit
    NI-Sync20.1.032-bit and 64-bit
    NI-VISA20.0.032-bit and 64-bit
    NI-XNET20.5.032-bit and 64-bit
    Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit. You can locate the readmes for these products in the labview\readme directory.
    To compare the products included in NI Software Suites, including the NI HIL and Real-Time Test Software Suite, refer to Compare NI Software Suites.
    Back to Top
    NI HIL and Real-Time Test Software Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Back to Top
    © 2014–2021 National Instruments Corporation. All rights reserved.
    377943D-01
    GMT+8, 2025-8-20 20:35
