HIL and Real-Time Test Software Suite 19.1 Win32ENG 硬件在环和实时测试软件套件2019秋季版英文
HIL and Real-Time Test Software Suite是用于验证嵌入式软件和运行模型物理测试的软件集合。
HIL and Real-Time Test Software Suite将LabVIEW集成开发环境(IDE)与应用软件和模块相结合,用于创建实时测试应用程序。借助该套件,您可以开发仿真模型和控制算法,并将其部署到实时硬件中。您还可以添加自定义功能,确保测试系统具有足够的灵活性来满足几乎任何应用需求,此外,您还可以在NI可重配置I/O硬件上执行高速仿真和处理。
套件包含:
LabVIEW专业版开发系统
LabVIEW高级信号处理工具包
VeriStand完整版开发系统
LabVIEW Real-Time模块
LabVIEW FPGA模块
LabVIEW控制设计与仿真模块
LabVIEW状态图模块
相关NI设备驱动程序
2019Fall ENG32
发布日期
2019/10/28
包含版本
Fall 2019
受支持的操作系统
Windows 7 (SP1) 32-bit
Windows 7 (SP1) 64-bit
Windows 8.1 32-bit
Windows 8.1 64-bit
Windows 10 32-bit
Windows Server 2012 R2 64-bit
应用程序位数
32位
语言
英文
校验和
文件大小: 36183277568 字节 (33.70 GB)
修改日期: 2019-10-29 03:06
MD5: 655f01ec7f306d6638b69d67b8f451e9(官方正确)
SHA1: 14c6be2df85939253f934e60b38c42ea6f6ee3f9
SHA256: af7ea92d0dabbae0a71231efb7b6fb9e8aa8a3e12aa3e41ba23bdbc9f3cbcb43
CRC32: a372e0a3
HILRT TSS19.1ENG.txt
(696 Bytes, 下载次数: 0, 售价: 40 圆)
NI HIL and Real-Time Test Software Suite Fall 2019 ReadmeSeptember 2019 This file contains important information about the NI HIL and Real-Time Test Software Suite, including installation instructions, compatibility issues, and a list of products included on the media. Installation Instructions Products Included on the NI HIL and Real-Time Test Software Suite Media Product Security and Critical Updates Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 NI HIL and Real-Time Test Software Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 Legal Information Installation InstructionsInstalling and Activating the NI HIL and Real-Time Test Software SuiteNI installs the NI HIL and Real-Time Test Software Suite using NI Package Manager. If you do not already have NI software installed, the NI HIL and Real-Time Test Software Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes
- If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate the NI HIL and Real-Time Test Software Suite. For more information on the NI HIL and Real-Time Test Software Suite activation, refer to National Instruments Software Activation.
If you install software using the NI HIL and Real-Time Test Software Suite installation media, complete the following steps to install products: - Insert the NI HIL and Real-Time Test Software Suite installation media.
- Follow the installer prompts, enter any required information, and activate when prompted, if necessary.
Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers. Installing LabVIEW Add-OnsInstalling LabVIEW add-ons, such as modules and toolkits, from the NI HIL and Real-Time Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the NI HIL and Real-Time Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly. Products Included on the NI HIL and Real-Time Test Software Suite MediaThe following products are included on the NI HIL and Real-Time Test Software Suite media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes. Application SoftwareProduct | Version | Bitness | LabVIEW Professional Development System | 2019 SP1 | 32-bit | VeriStand | 2019 R2 | 32-bit and 64-bit | Add-OnsProduct | Version | Bitness | LabVIEW Advanced Signal Processing Toolkit | 2019 | 32-bit | LabVIEW Control Design and Simulation Module | 2019 | 32-bit | LabVIEW Desktop Execution Trace Toolkit | 2019 | 32-bit and 64-bit | LabVIEW Digital Filter Design Toolkit | 2019 | 32-bit | LabVIEW FPGA Compile Farm Toolkit | 2019 | 32-bit and 64-bit | LabVIEW FPGA ISE Compilation Tool 14.7 | 2019 | 32-bit and 64-bit | LabVIEW FPGA Module | 2019 | 32-bit | LabVIEW FPGA Vivado Compilation Tool 2017.2 | 2019 SP1 | 64-bit | LabVIEW MathScript Module | 2019 | 32-bit | LabVIEW Model Interface Toolkit | 2019 | 32-bit and 64-bit | LabVIEW Real-Time Module | 2019 | 32-bit | LabVIEW Unit Test Framework Toolkit | 2019 | 32-bit and 64-bit | LabVIEW VI Analyzer Toolkit | 2019 | 32-bit | JKI VI Package Manager | 2019 | 32-bit and 64-bit | VeriStand Model Generation Support for LabVIEW | 2019 R2 | 32-bit and 64-bit | VeriStand Model Framework | 2019 R2 | 32-bit and 64-bit | Device DriversProduct | Version | FlexRIO with Modular I/O | 19.5 | FlexRIO with Integrated I/O | 19.0 | NI CompactRIO | 19.5 | NI PXI Platform Services | 19.5 | NI R Series Multifunction RIO | 19.1 | NI-488.2 | 19.5 | NI-DAQmx | 19.5 | NI-DCPower | 19.5 | NI-Industrial Communications for EtherCAT | 19.0 | NI-Serial | 19.5 | NI-SLSC | 19.0 | NI-SWITCH | 19.5 | NI-Sync | 19.5 | NI-VISA | 19.5 | NI-XNET | 19.5 |
Note The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit. You can locate the readmes for these products in the labview\readme directory. To compare the products included in NI Software Suites, including the NI HIL and Real-Time Test Software Suite, refer to Compare NI Software Suites. Back to Top Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Software Platform Bundle, refer to Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. NI HIL and Real-Time Test Software Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021NI HIL and Real-Time Test Software Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: Product | Info Code | LabVIEW | lifecycle | LabWindows/CVI | cvi_lifecycle | Measurement Studio | mstudiolifecycle | TestStand | tslcp | DIAdem | ddlcp | VeriStand | nivslifecycle |
Back to Top Legal InformationCopyright © 2014–2019 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 377943B-01 |
