NI mmWave OTA Validation Test Software 21.0 x64Win10 64bitEng NI毫米波空口验证测试软件21.0
mmWave OTA验证测试软件
mmWave OTA验证测试软件可简化并加速5G封装天线波束成形器件的特性分析和验证测试。
mmWave OTA验证测试软件是一款应用软件,可帮助您配置、运行、可视化和报告5G mmWave封装天线集成电路(IC)空口(OTA)辐射性能。该软件可以执行系统校准,以测量每个信号路径的路径损耗,进而补偿测试仪器、电缆、天线和空口通信。此外,mmWave OTA验证测试软件还根据3GPP测试规范简化了配置和运行3D空间扫描的过程。您可以使用模板自定义测试序列,以自动执行数据采集、结果报告和存储。该软件包括一系列可视化工具,包括天线方向图、3D和极坐标图、波束宽度、热图等。
21.0
发布日期
2021/8/25
包含版本
21.0.0完整版
受支持的操作系统
应用程序位数
64位
语言
英文
校验和
文件大小: 771059712 字节 (735.34 MB)
修改日期: 2021-09-12 00:00
MD5: 60be61dc21abaa332dc31d96dcd4d2fa
SHA1: 4ade27f21d6bc398c101d309007417aacc92d6d2
SHA256: 461c30ae379303a7896069f3cc6371f485705b9112967d3a7ca7915d01271d68
CRC32: 5f831029
mmWAVE21.0.txt
(645 Bytes, 下载次数: 0, 售价: 10 圆)
mmWave OTA Validation Test Software 21.0 ReadmeAugust 2021 This file contains installation instructions and compatibility information for mmWave OTA Validation Test Software. You can find more release information on ni.com. - mmWave OTA Validation Test Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
Overview New Features Required Software Supported Operating Systems Supported Hardware Installation Instructions Accessing the Documentation Finding Installed Software Product Security and Critical Updates Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Legal Information OverviewThis software installation provides support for the mmWave OTA Validation Test Reference Architecture and helps you configure, run, visualize, and report the over-the-air (OTA) radiated performance of 5G mmWave antenna-in-package (AiP) integrated circuits. mmWave OTA Validation Test Software can perform system calibration to measure the path losses of every signal path, compensating for test instruments, cables, antennas, and air interface. Additionally, mmWave OTA Validation Test Software simplifies the process of configuring and running 3D spatial sweeps according to 3GPP test specifications. You can use templates to customize test sequences to automate data collection, results reporting, and storage. The software also includes a collection of visualization tools for antenna pattern cuts, 3D and polar plots, beamwidth, heat map, and more. New FeaturesmmWave OTA Validation Test Software 21.0 adds the following new features: - LabVIEW Measurement Plugin in the mmWave OTA Validation Configurator for executing an OTA test
- Support for using two PXIe-5831 modules
- User interface improvements to the mmWave OTA Validation Configurator
Required SoftwaremmWave OTA Validation Test Software 21.0 requires the following software versions. Software | Required for LabVIEW Support | Required for TestStand Support | Required for C# .NET Support | Required for MATLAB Support | Required for Python Support | | LabVIEW 2019 (64-bit) | √ | √ | — | — | — | | LabVIEW 2019 Runtime Engine (64-bit) | — | — | √ | √ | √ | | TestStand 2019 (64-bit) | — | √ | — | — | — | | Microsoft Visual Studio† 2017 | — | — | √ | — | — | | MATLAB† 2019 | — | — | — | √ | — | | Python† 3.8 | — | — | — | — | √ | | RFmx NR 20.6 | √ | √ | √ | √ | √ | | RFmx SpecAn 20.6 | √ | √ | √ | √ | √ | | NI-DAQmx 20.1 | √ | √ | √ | √ | √ | | NI-RFSA 20.5 | √ | √ | √ | √ | √ | | NI-RFSG 20.5 | √ | √ | √ | √ | √ | | NI-RFSG Playback Library 20.6 | √ | √ | √ | √ | √ |
† If you are using the mmWave OTA Validation Test C# .NET API, MATLAB examples, and Python examples, .NET Framework 4.0 (minimum) is required. To use the .NET API, you must also install .NET support for the required drivers. Refer to the documentation of each software product for specific system requirements. Supported Operating SystemsmmWave OTA Validation Test Software supports Windows 10 (64-bit). Supported HardwaremmWave OTA Validation Test Software supports the mmWave OTA Validation Anechoic Chamber and all instruments used with the mmWave OTA Validation Test Reference Architecture. Refer to the mmWave OTA Validation Test Reference Architecture Manual at ni.com/r/otahelp for a full list of supported instruments. Installation InstructionsDownload the mmWave OTA Validation Test Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Accessing the DocumentationRefer to the mmWave OTA Validation Test Reference Architecture Manual, accessible from ni.com/r/otahelp, for information about mmWave OTA Validation Test Software. The mmWave OTA Validation Test Reference Architecture documentation is also accessible from Start»National Instruments»OTA Documentation. Finding Installed Software- is an alias for the following National Instruments file folder location: Users\Public\Public Documents\National Instruments
- is an alias for the following National Instruments file folder location: Program Files\National Instruments
Item | Installed Location | | mmWave OTA TestStand Examples | \TestStand 2019 (64-bit)\Examples\OTA Test | | mmWave OTA Validation Configurator | \OTA Test\Configurator | | mmWave OTA Validation Positioner Control Panel | \OTA Test\Positioner | | mmWave OTA Support for LabVIEW | \LabVIEW 2019\user.lib\OTA Test | | mmWave OTA Support for .NET, MATLAB, and Python | \OTA Test\Examples | | mmWave OTA Validation Visualizer | \OTA Test\Visualizer | | mmWave OTA Validation Antenna Alignment Helper | \OTA Test\Antenna Alignment | | RF System Calibration Assistant | \RF System Calibration | Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Legal InformationCopyright © 2019–2021 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 378173D-01
