NI mmWave OTA Validation Test Software 1.0 Win64Eng NI毫米波空口验证测试软件1.0
mmWave OTA验证测试软件
mmWave OTA验证测试软件可简化并加速5G封装天线波束成形器件的特性分析和验证测试。
mmWave OTA验证测试软件是一款应用软件,可帮助您配置、运行、可视化和报告5G mmWave封装天线集成电路(IC)空口(OTA)辐射性能。该软件可以执行系统校准,以测量每个信号路径的路径损耗,进而补偿测试仪器、电缆、天线和空口通信。此外,mmWave OTA验证测试软件还根据3GPP测试规范简化了配置和运行3D空间扫描的过程。您可以使用模板自定义测试序列,以自动执行数据采集、结果报告和存储。该软件包括一系列可视化工具,包括天线方向图、3D和极坐标图、波束宽度、热图等。
1.0
发布日期
2019/11/5
包含版本
1.0.0完整版
受支持的操作系统
Windows 7 (SP1) 64-bit
Windows 8.1 64-bit
Windows Server 2012 R2 64-bit
应用程序位数
64位
语言
英文
校验和
文件大小: 377290752 字节 (359.81 MB)
修改日期: 2021-09-11 22:43
MD5: 9f01794dbedfaadb7a080380545972b5
SHA1: bf9f0cd7e3564347763a0de001ad5b873345d544
SHA256: 8af83b328d99d012c76a760b1f7432539b5d0272c126b98d4c9709566634f6bd
CRC32: f7985f38
mmWAVE1.0.txt
(641 Bytes, 下载次数: 0, 售价: 10 圆)
mmWave OTA Validation Test Software 1.0 ReadmeOctober 2019 This file contains important information about the mmWave OTA Validation Test Software, including installation instructions, new features, and known issues.
Overview Required Software Supported Operating Systems Supported Hardware Installation Instructions Known Issues Accessing the Documentation Finding Installed Software Product Security and Critical Updates Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Legal Information OverviewThis software installation provides support for the mmWave OTA Validation Test Reference Architecture and helps you configure, run, visualize, and report the over-the-air (OTA) radiated performance of 5G mmWave antenna-in-package (AiP) integrated circuits. The mmWave OTA Validation Test Software can perform system calibration to measure the path losses of every signal path, compensating for test instruments, cables, antennas, and air interface. Additionally, the mmWave OTA Validation Test Software simplifies the process of configuring and running 3D spatial sweeps according to 3GPP test specifications. You can use templates to customize test sequences to automate data collection, results reporting, and storage. The software also includes a collection of visualization tools for antenna pattern cuts, 3D and polar plots, beamwidth, heat map, and more. Required Software- LabVIEW 2018 (64-bit)
- TestStand 2019 (64-bit)
- RFmx NR 19.0
- RFmx SpecAn 19.0
Refer to the documentation of each product for specific system requirements. Supported Operating SystemsmmWave OTA Validation Test Software supports Windows 10 (64-bit). Supported HardwaremmWave OTA Validation Test Software supports the mmWave OTA Validation Anechoic Chamber and all instruments used with the mmWave OTA Validation Test Reference Architecture. Installation InstructionsYou should install application software and required software products before installing mmWave OTA Validation Test Software. NI installs mmWave OTA Validation Test Software using NI Package Manager. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Known IssuesYou can access the software and documentation known issues list online. Visit mmWave OTA Validation Test Software Known Issues for an up-to-date list of known issues. Accessing the DocumentationRefer to the mmWave OTA Validation Test Reference Architecture Manual, accessible from ni.com/r/otahelp, for information about the mmWave OTA Validation Test Software. Finding Installed Software- is an alias for the following National Instruments file folder location: Users\Public\Public Documents\National Instruments
- is an alias for the following National Instruments file folder location: Program Files\National Instruments
Item | Installed Location | | TestStand Examples | \TestStand 2019 (64-bit)\Examples\OTA Test | | Configuration UI | \LabVIEW 2018\user.lib\OTA Test\Configuration UI\ConfigUI.vi | | Positioner Soft Front Panel | \LabVIEW 2018\user.lib\OTA Test\Plugins\Positioners\Positioner Example.vi | | Measurement Interface | \LabVIEW 2018\user.lib\OTA Test\Measurement Interface | | Visualizer | \OTA Test\Visualizer | | RF System Calibration Assistant | \RF System Calibration | Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Legal InformationCopyright © 2019 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 378173A-01
