查看: 2489|回复: 0
[NI驱动程序] NI RF Signal Analyzers 21.0.0 Linux64Eng NI PXI矢量信号分析仪驱动NI-RFSA 21.0.0 Linux在线安装版
    昨天 15:45
  • 签到天数: 3536 天
    连续签到: 6 天
    发表于 2021-9-12 21:47:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSA
    发布日期
    2021/9/9
    包含的版本
    21.0.0在线版
    受支持的操作系统
    RedHat
    CentOS
    SUSE
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 18178 字节 (17.75 KB)
    修改日期: 2021-09-11 21:53
    MD5: 0e86cfb821d1180ed5933386810f1d5a
    SHA1: bbf78c9a05ad42f06672fd2945fb4f7c0698357e
    SHA256: 22e2fbe1eb702470da4bbae2387fbb8a1ec892a0b35dbc267d9b1ebf6bb1f0ce
    CRC32: 2383e1cf
    RFSA21.0-Linux Online.txt (547 Bytes, 下载次数: 0, 售价: 5 元)
    NI RF Signal Analyzers (NI-RFSA) 21.0 Readme
    August 2021
    This file contains installation instructions and compatibility information for NI-RFSA.
    • NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSA Manuals: New features, behavior changes, and other documentation
    This software installation provides support for customers using vector signal analyzer or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSA instrument driver or NI-RFSA Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSA 21.0 includes the following new features:
    • Support for LabVIEW 2021
    • Support for Linux
    NI-RFSA 20.7 includes peer-to-peer support for the PXIe-5668
    NI-RFSA 20.5.4 includes a bug fix to address a .NET initialization issue for PXIe-5830/1/2 devices in RFmx
    NI-RFSA 20.5 includes the following new features:
    • Support for the PXIe-5832
    • Support for selected ports in configuration lists on the PXIe-5830/5831/5832
    NI-RFSA 20.0 includes the following new features:
    • Support for LabVIEW 2020
    • Support for RF list mode on the PXIe-5841 with PXIe-5655
    The following table shows which hardware products are supported in the NI-RFSA instrument driver and the NI-RFSA SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware Product
    Hardware Model
    NI-RFSA
    RF Signal DownconverterPXI-5600
    PXIe-5601
    PXIe-5603
    PXIe-5605
    PXIe-5606
    Vector Signal AnalyzerPXI-5661
    PXIe-5663/5663E
    PXIe-5665
    PXIe-5667
    PXIe-5668
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5830
    PXIe-5831
    PXIe-5832
    PXIe-5840
    PXIe-5841
    RF Analog Signal Generator
    RF Preselector ModulePXIe-5693
    IF Conditioning ModulePXIe-5694
    RF AmplifierPXIe-5698
    NI-RFSA has the following requirements:
    • 4 GB RAM*
    • Windows 10 with all available critical updates and service packs
    NI-RFSA 21.0 and NI-RFSA SFP 21.0 support the following operating systems:
    NI-RFSA supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSA. To add support for application software installed after installing NI-RFSA, modify your NI-RFSA installation or launch the NI-RFSA installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSA
    LabVIEW2018 SP1, 2019, 2020, or 2021
    LabWindows/CVI2017 to current
    Note  Install any toolkits or add-on software you intend to use with the NI-RFSA instrument driver after NI-RFSA installation is complete. Refer to the getting started guide for your device for more information about software and hardware installation.
    If you are using the NI-RFSA .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. For more information on .NET development using NI .NET drivers, visit ni.com/info and enter Info Code NETAPIdriversupport.
    To install the NI-RFSA .NET Class Library, ensure that you select .NET Framework 4.5 Languages Support or .NET Framework 4.0 Languages Support in the NI-RFSA installer.
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    NI-RFSA VIs are available in LabVIEW from the Functions»Measurement I/O»NI-RFSA palette.
    LabWindows/CVI
    .NET Framework
    You can use the NI-RFSA .NET Class library by adding a reference to NationalInstruments.ModularInstruments.NIRfsa.Fx40 or NationalInstruments.ModularInstruments.NIRfsa.Fx45 and any dependent class libraries from within the Solution Explorer in Visual Studio.
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output»Modular Instruments»NI-RFSA. You can also select the Search tab to search all installed examples by keyword.
    You can access all the installed NI-RFSA examples at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Examples.
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI RF Vector Signal Analyzers HelpHTML/Windows HelpContains primary help content for NI-RFSA products. The help is an HTML version of a traditional user manual that includes the following information:
    • Hardware device overviews
    • The NI-RFSA Soft Front Panel Help
    • A complete reference for all NI-RFSA VIs, properties, and functions, as well as the NI-RFSA .NET Class Library Help
    NI RF Signal Analyzers ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, and legal notices.
    Few other documentation for NI-RFSA is located at Program Files\IVI Foundation\IVI\Drivers\niRFSA\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSA no longer installs IVI Compliance Package (ICP). NI-RFSA supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    NI-RFSA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    © 2004–2021 National Instruments Corporation. All rights reserved.
    374797AG-01
    GMT+8, 2025-5-12 03:10
