查看: 2841|回复: 0
[LV工具模块] LabVIEW Electric Motor Simulation Toolkit 2015 Win32Eng LabVIEW电动机仿真工具包NIEMsim2015
    昨天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
    发表于 2021-9-8 22:31:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW电动机仿真工具包提供了开发桌面和硬件在环电动机系统仿真模型所需的建模元件。
    LabVIEW电机仿真工具包是LabVIEW和VeriStand的软件附件。它为电子仿真、控制和硬件在环(HIL)提供了LabVIEW项目模板,以及适用于各种电机类型的VeriStand软件附件。该工具包可帮助您在主机上执行模型,以进行桌面仿真、LabVIEW实时仿真和基于FPGA的仿真。电动机仿真工具包包括开关磁阻电动机(SRM)、应电机和永磁同步电机模型,这些模型可以是近乎线性的简单模型也可以是更高保真度的模型。
    NIEMsim2015
    发布日期
    2015/2/11
    包含的版本
    2015完整版
    受支持的操作系统
    Windows 8
    Windows 7
    Windows Vista
    Windows XP
    Windows Server 2008 R2 64-bit
    Windows Server 2003 R2 32-bit
    应用程序位数
    32位
    语言
    英文
    校验和
    文件大小: 221066492 字节 (210.83 MB)
    修改日期: 2019-06-25 02:53
    MD5: d974fc9ceb0f167f63cff423a84e08b3(官方正确)
    SHA1: 0463cae5a02bc008d08f9bcbd2f07eb0934b71a8
    SHA256: 15807dbaa63980e1180728ed877a2fab655d3d8edb93a8515126417687d7900b
    CRC32: 3306f200
    EMsim2015.txt (615 Bytes, 下载次数: 0, 售价: 10 元)
    NI Electric Motor Simulation Toolkit 2015 Readme
    October 2015
    This file contains important information about the NI Electric Motor Simulation Toolkit, including installation instructions, new features, recommended hardware, activating instructions, a partial list of bugs fixed for 2015, and known issues.
    Activating the Software
    Recommended Hardware
    New Features and Behavior Changes
    The Electric Motor Simulation Toolkit is an add-on for both the LabVIEW platform and NI VeriStand. This toolkit provides LabVIEW VIs and sample projects to help you control and simulate an electric motor by writing your own applications. This toolkit also extends the functionality of VeriStand by providing a series of custom devices for you to design and implement a real-time motor simulation application. This toolkit uses field-programmable gate array (FPGA) technology and integrates the finite element analysis (FEA) method to provide high-speed and high-fidelity electric motor simulation.
    This toolkit provides built-in examples of JMAG RTT files and ANSYS motor model files for motor simulation. You can use the RTT files or the ANSYS motor model files with the examples, sample projects, or custom devices. To configure the controller and simulator and use the built-in RTT files or ANSYS motor model files, refer to the NI website for more information.
    In addition to the system requirements for the LabVIEW Development System, the Electric Motor Simulation Toolkit has the following requirements for LabVIEW support:
    • LabVIEW 2015 Full or Professional Development System (32-bit)
    • LabVIEW 2015 Real-Time Module
    • LabVIEW 2015 FPGA Module
    • LabVIEW 2015 Control Design and Simulation Module
    • FlexRIO Support 15.0
    • NI CompactRIO Device Drivers August 2015
    • NI R Series Multifunction RIO Device Drivers August 2015
    • At least 256 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    For VeriStand support, the Electric Motor Simulation Toolkit has the following requirements:
    • VeriStand 2015
    Refer to the NI VeriStand Readme for additional system requirements and supported operating systems for VeriStand 2015.
    Double-click the setup.exe file in the root directory of the Electric Motor Simulation Toolkit installer and follow the instructions on the screen to install this product.
    For LabVIEW support, you evaluate and activate the Electric Motor Simulation Toolkit the same as activating LabVIEW. Refer to the LabVIEW Help for more information about activating your software.
    For VeriStand support, complete the following steps to activate the Electric Motor Simulation Toolkit:
    • Launch NI License Manager by selecting Start»All Programs»National Instruments»NI License Manager or from NI Launcher in Windows 8.x.
    • In the NI License Manager tree, navigate to the Electric Motor Simulation Toolkit in the Local Licenses»LabVIEW 2015»Toolkits folder.
    • Double-click the toolkit name or right-click the toolkit and select Activate from the shortcut menu.
    • In the NI Activation Wizard that appears, select Apply one or more 20-character activation codes previously acquired for this computer and click the Next button.
    • Enter the activation code and click the Next button. The activation code is the serial number on the product packing slip or on the shipping label.
    • Check the activation status of this toolkit in the NI License Manager.
    Note  If you installed the Electric Motor Simulation Toolkit with a serial number, the Activation Wizard launches after the installation is complete. You can complete step 4-6 to activate the toolkit.
    NI recommends the following hardware for you to use with this toolkit.
    ModelSimulating on RTSimulating on FPGA
    ACIM Constant Parameter ModelNI PXIe-8135 RTNI PXI-7854R
    PMSM Constant Parameter ModelNI PXIe-8135 RTNI PXI-7854R
    PMSM Variable Parameter ModelNI PXIe-8135 RTNI PXI-7854R
    PMSM FEA ModelNI PXIe-8135 RTNI PXIe-7966R + HKS-9609 by Keisokugiken Corporation (KGC)
    Note  You can use NI PXIe-7965R for simulating on an FPGA target. However, when you compile the FPGA code, you must set the frequency of Top-Level Clock on the FPGA target to 80 MHz or less. Otherwise, LabVIEW fails to compile the FPGA bitfile.
    SRM Linear ModelNI PXIe-8135 RTNI PXI-7854R
    SRM FEA ModelNI PXIe-8135 RTNI PXIe-7965R/7966R + HKS-9609 by Keisokugiken Corporation (KGC)
    New Features and Behavior ChangesNew Features
    The Electric Motor Simulation Toolkit 2015 supports ANSYS motor model files (.txt) for simulating a PMSM with the variable parameter model. The Electric Motor Simulation Toolkit 2015 adds a new instance called ANSYS File to the Create PMSM Variable Parameter Model VI. You can use the ANSYS File instance to read the ANSYS motor model file to get a LabVIEW class reference of the PMSM variable parameter model.
    You can use the following components in the Electric Motor Simulation Toolkit 2015 to read the ANSYS motor model file:
    • The PMSM Variable Parameter Model Closed Loop example
    • The PMSM Variable Parameter Model Control Simulation example
    • The PMSM Variable Parameter Model Simulation on Real-Time Targets sample project
    • The PMSM Variable Parameter Model Simulation on FPGA Targets sample project
    • The PMSM Variable Parameter Model Custom Device
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the Electric Motor Simulation Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the Electric Motor Simulation Toolkit. This is not an exhaustive list of issues fixed in the current version of the Electric Motor Simulation Toolkit. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    518078The FPGA PMSM FEA model can output unexpected results
    539420The resistance input in the PMSM variable parameter model VI has no effect
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Electric Motor Simulation Toolkit. You can find help information about this toolkit in the Toolkits»Electric Motor Simulation Toolkit book on the Contents tab.
    Refer to the NI VeriStand Help, accessible by selecting Help»Search the NI VeriStand Help from VeriStand, for information about the Electric Motor Simulation custom devices.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Electric Motor Simulation folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find examples for the Electric Motor Simulation Toolkit in the labview\examples\Electric Motor Simulation directory.
    When you install NI software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI Electric Motor Simulation Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI Electric Motor Simulation Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Electric Motor Simulation Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    © 2013–2015 National Instruments. All rights reserved.
    375059B-01
    GMT+8, 2025-6-1 04:46
