查看: 3682|回复: 0
[LV工具模块] LabVIEW myRIO Toolkit 2019 Win32Eng LabVIEW 2019myRIO工具包
    14 小时前
  • 签到天数: 3629 天
    连续签到: 3 天
    发表于 2021-9-7 22:57:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW myRIO工具包提供了在myRIO学生嵌入式设备上开发和部署应用程序所需的工具。
    LabVIEW myRIO工具包是LabVIEW的软件附件,提供了在myRIO学生嵌入式设备上快速开发和部署应用程序所需的驱动和工具。该工具包为myRIO设备上的每种I/O类型提供了基于配置的Express和Advanced I/O VI,可帮助学生快速构建想法并编写独立的应用程序。
    2019myRIO
    发布日期
    2019/5/14
    包含的版本
    2019完整版
    受支持的操作系统
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    应用程序位数
    32位
    语言
    英文
    校验和
    文件大小: 1961240576 字节 (1.83 GB)
    修改日期: 2019-05-15 08:47
    MD5: c922194cb2b6744659f6df5e8937aa7b(官方正确)
    SHA1: 185d862361ce2d2cc21e5121278faf385db7a6c7
    SHA256: 4aca026a399dc491acda9c1bd5a757fbb39c352c5016086e3c75bd40c4fcfd0e
    CRC32: 6bffd308
    myRIO2019.txt (653 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW 2019 myRIO Toolkit Readme
    March 2019
    This file contains important information about the LabVIEW myRIO Toolkit, including system requirements, installation instructions, and known issues.
    Installing the High Throughput Add-On for myRIO
    Accessing the LabVIEW for myRIO Environment
    LabVIEW myRIO Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The LabVIEW myRIO Toolkit provides you with tools for creating and deploying applications on the myRIO.
    The myRIO Toolkit has the following requirements:
    • (Optional for C Programming) LabVIEW 2019 Student, Full, or Professional Development System
    • (Optional for C Programming) LabVIEW 2019 Real-Time Module
    • At least 2 GB of disk space in addition to the LabVIEW-recommended minimum
    • 1 GB RAM
    Refer to the LabVIEW Readme for additional system requirements for LabVIEW 2019.
    Note
    • The myRIO Toolkit is compatible with only 32-bit LabVIEW. Install 32-bit LabVIEW even if you use a 64-bit operating system.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    The myRIO Toolkit supports the following operating systems:
    • Windows 10 (version 1809)/8.1 Update 11/7 SP12
    Note
    • In 2016 the LabVIEW myRIO Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2019 myRIO Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2019 myRIO Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2019 myRIO Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    • Refer to LabVIEW myRIO Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    To install the myRIO Toolkit using the installer from ni.com/downloads, double-click the setup.exe file in the root directory of the myRIO Toolkit installer and follow the instructions on the screen to install this product.
    The High Throughput Add-On for myRIO provides the High Throughput FPGA Personality VIs which support high-speed analog or digital data access. The High Throughput FPGA Personality VIs appear on the myRIO palette only after you install the High Throughput Add-On for myRIO.
    Visit ni.com/info and enter the Info Code ex6g5a to download the High Throughput Add-On for myRIO installer. Double-click the setup.exe file in the root directory of the installer and follow the instructions on the screen to install this product.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code lvmyrio2019ki for an up-to-date list of known issues in LabVIEW 2019 myRIO Toolkit.
    The myRIO Toolkit provides the LabVIEW for myRIO environment to allow you to easily access myRIO-specific features and focus on developing myRIO applications.
    You can use the Choose Environment Settings dialog box to change your LabVIEW environment. To display this dialog box, select Tools»Choose Environment from LabVIEW.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the myRIO Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the myRIO Toolkit are located in the labview\examples\myRIO directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW myRIO Toolkit will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2013–2019 National Instruments. All rights reserved.
    375387F-01
    GMT+8, 2025-8-20 23:36
