查看: 4529|回复: 2
[LV工具模块] LabVIEW myRIO Toolkit 2018 Win32Eng LabVIEW 2018myRIO工具包
    前天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
    发表于 2021-9-7 22:55:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW myRIO工具包提供了在myRIO学生嵌入式设备上开发和部署应用程序所需的工具。
    LabVIEW myRIO工具包是LabVIEW的软件附件,提供了在myRIO学生嵌入式设备上快速开发和部署应用程序所需的驱动和工具。该工具包为myRIO设备上的每种I/O类型提供了基于配置的Express和Advanced I/O VI,可帮助学生快速构建想法并编写独立的应用程序。
    2018myRIO
    发布日期
    2018/5/21
    包含的版本
    2018完整版
    受支持的操作系统
    Windows 7
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows Server 2008 R2 64-bit
    应用程序位数
    32位
    语言
    英文
    校验和
    文件大小: 2503386712 字节 (2.33 GB)
    修改日期: 2018-05-21 10:55
    MD5: 3e729f0850f0b216a08ff520278db66b(官方正确)
    SHA1: 08344a8d94eb76de3eebd4dac3c9852567bd6ffa
    SHA256: a780a66e90fc52f305ba39a12c379d14c186abd8ab412ee65f44c402cd1482f5
    CRC32: c9ef4653
    myRIO2018.txt (546 Bytes, 下载次数: 6, 售价: 10 元)
    LabVIEW 2018 myRIO Toolkit Readme
    March 2018
    This file contains important information about the LabVIEW myRIO Toolkit, including system requirements, installation instructions, and known issues for the LabVIEW 2018 myRIO Toolkit.
    Installing the High Throughput Add-On for myRIO
    Accessing the LabVIEW for myRIO Environment
    The LabVIEW myRIO Toolkit provides you with tools for creating and deploying applications on the myRIO.
    The myRIO Toolkit has the following requirements:
    • (Optional for C Programming) LabVIEW 2018 Student, Full, or Professional Development System
    • (Optional for C Programming) LabVIEW 2018 Real-Time Module
    • At least 2 GB of disk space in addition to the LabVIEW-recommended minimum
    • 1 GB RAM
    Refer to the LabVIEW Readme for additional system requirements for LabVIEW 2018.
    Note
    • The myRIO Toolkit is compatible with only 32-bit LabVIEW. Install 32-bit LabVIEW even if you use a 64-bit operating system.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    The myRIO Toolkit supports the following operating systems:
    • Windows 10 (version 1709)/8.1 Update 11/7 SP12
    Note  In 2016 the LabVIEW myRIO Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2018 myRIO Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2018 myRIO Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2018 myRIO Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    To install the myRIO Toolkit using the LabVIEW myRIO Software Bundle media, complete the following steps:
    • Log in to the development computer as an administrator or as a user with administrative privileges.
    • Insert the LabVIEW myRIO Software Bundle DVD 1.
    • Select Install NI LabVIEW 2018 myRIO Toolkit.
    • (Optional for C Programming) Click the drop-down arrow next to LabVIEW Support and select Install this feature to a local drive.
    • Click Next and follow the instructions on the screen to install the myRIO Toolkit.
    To install the myRIO Toolkit using the installer from ni.com/downloads, double-click the setup.exe file in the root directory of the myRIO Toolkit installer and follow the instructions on the screen to install this product.
    The High Throughput Add-On for myRIO provides the High Throughput FPGA Personality VIs which support high-speed analog or digital data access. The High Throughput FPGA Personality VIs appear on the myRIO palette only after you install the High Throughput Add-On for myRIO.
    Visit ni.com/info and enter the Info Code ex6g5a to download the High Throughput Add-On for myRIO installer. Double-click the setup.exe file in the root directory of the installer and follow the instructions on the screen to install this product.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the myRIO Toolkit.
    The myRIO Toolkit provides the LabVIEW for myRIO environment to allow you to easily access myRIO-specific features and focus on developing myRIO applications.
    You can use the Choose Environment Settings dialog box to change your LabVIEW environment. To display this dialog box, select Tools»Choose Environment from LabVIEW.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the myRIO Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the myRIO Toolkit are located in the labview\examples\myRIO directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2013–2018 National Instruments. All rights reserved.
    375387D-01
    发表于 2022-10-27 13:11:12 | 显示全部楼层 来自:四川省绵阳市 科学城
    前天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
     楼主| 发表于 2022-10-27 18:16:25 | 显示全部楼层 来自:广东省东莞市 联通
    jingangtang 发表于 2022-10-27 13:11
    充了钱,怎么还下不了。骗人的网站
    查了一下记录,半夜0点多付的款,昨天晚上喝多了,没及时处理。现在已经给处理了。消消火气,骗人是不会骗人的,只是没有及时响应。
    GMT+8, 2025-6-2 03:47
