查看: 2917|回复: 0
[LV工具模块] LabVIEW myRIO Toolkit 2013 Win32Eng LabVIEW 2013myRIO工具包
    14 小时前
  • 签到天数: 3629 天
    连续签到: 3 天
    发表于 2021-9-7 22:45:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW myRIO工具包提供了在myRIO学生嵌入式设备上开发和部署应用程序所需的工具。
    LabVIEW myRIO工具包是LabVIEW的软件附件,提供了在myRIO学生嵌入式设备上快速开发和部署应用程序所需的驱动和工具。该工具包为myRIO设备上的每种I/O类型提供了基于配置的Express和Advanced I/O VI,可帮助学生快速构建想法并编写独立的应用程序。
    2013myRIO
    发布日期
    2013/8/2
    包含的版本
    2013完整版
    受支持的操作系统
    Windows XP (SP3) 32-bit
    Windows 8 32-bit
    Windows 8 64-bit
    Windows 7 64-bit
    Windows 7 32-bit
    应用程序位数
    32位
    语言
    英文
    校验和
    文件大小: 1701031444 字节 (1.58 GB)
    修改日期: 2019-06-25 02:58
    MD5: 230970d66448af60e4d2998c09a688f3(官方正确)
    SHA1: 12af305310a611048edb94e9017107c1c005f5cc
    SHA256: e8c53c20b8562766b7a810c3da81f3195128cd1ce193bface52f083fb37133a2
    CRC32: d4c81253
    myRIO2013.txt (546 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2013 for myRIO Module Readme
    Version 1.0
    June 2013
    This file contains important information about the LabVIEW 2013 for myRIO Module, including system requirements, installation instructions, and known issues.
    The LabVIEW for myRIO Module is a software package that allows you to develop NI myRIO applications by using LabVIEW.
    In addition to the system requirements for the LabVIEW Development System, the myRIO Module has the following requirements:
    • LabVIEW 2013 Student, Full, or Professional Development System (32-bit)
    • LabVIEW 2013 Real-Time Module
    • At least 2 GB of disk space in addition to the LabVIEW-recommended minimum.
    • One of the following operating systems for application development:
      • Windows 8
      • Windows 7
      • Windows Vista
      • Windows XP Pro (Service Pack 3)
    Note:
    • The myRIO Module is compatible with 32-bit LabVIEW only. Therefore, you must have 32-bit LabVIEW installed even if you use a 64-bit OS.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). Refer to the National Instruments website for information about how this might affect your use of Windows Server 2003 R2 and what actions you might have to take.
    • The myRIO Module does not support the Windows Server non-R2 editions.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    Complete the following steps to install the LabVIEW for myRIO Module on a development computer.
    • Log in to the development computer as an administrator or as a user with administrative privileges.
    • Insert the NI myRIO Software Suite DVD 1.
    • Follow the instructions on the screen to install and activate the myRIO Module.
    Installing the USBLAN Driver in Microsoft Windows XP and Windows Server 2003
    You must manually install the USBLAN driver before using the NI myRIO with Microsoft Windows XP and Windows Server 2003. Complete the following steps to install the USBLAN driver:
    Note  Before completing the following steps, make sure that you have downloaded and installed the KB 931125 package from Microsoft. For more information, refer to the Workarounds and Recommendations section of KB 65O8AH55, Why Are National Instruments Installers Failing on Windows XP and Server 2003 Machines?.
    • Connect the NI myRIO to your computer after you install the LabVIEW for myRIO Module.
    • In the Found New Hardware Wizard, select No, not this time and click Next.
    • Select Install from a list or specific location and click Next.
    • Select Include this location in the search and navigate to the National Instruments\CompactRIO\Staging\USBLAN\XP directory.
    • Click Next to install the USBLAN driver. Click Continue Anyway when you see the Windows Logo testing warning.
    • Click Finish.
    The USBLAN device driver should now appear under Network adapters in the Windows Device Manager.
    myRIO Module Updates and Notifications
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the myRIO Module.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the myRIO Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the myRIO Module are located in the labview\examples\myRIO directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI LabVIEW for myRIO Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW for myRIO Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the myRIO Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2013 National Instruments. All rights reserved.
    GMT+8, 2025-8-20 23:34
