查看: 2489|回复: 0
[NI驱动程序] NI PXI Platform Services 21.0 x64Win10 32/64bit多国语言 PXI平台服务NI-PXIPS21.0下载
    昨天 15:45
  • 签到天数: 3536 天
    连续签到: 6 天
    发表于 2021-9-6 16:08:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    PXI Platform Services用于支持NI PXI机箱和控制器,遵循PXI软件规范,并为其他NI产品提供系统服务。
    PXI Platform Services用于识别NI PXI和PXI Express机箱和模块,以及允许触发路由。 对于特定NI模块,使用完整的模块功能仍需要适用的硬件驱动程序。 NI PXI Platform Services已包含在NI仪器驱动程序中,但有些情况下,某些应用程序只需要PXI Platform Services软件,例如在没有安装其他NI PXI硬件驱动程序的情况下使用NI MXI产品或使用NI PXI或PXI Express机箱。
    发布日期
    2021/8/3
    包含的版本
    21.0.0完整版
    受支持的操作系统
    应用程序位数
    32/64位
    语言
    中文, 德语, 日语, 法语, 英文, 韩语
    校验和
    文件大小: 1123743744 字节 (1.05 GB)
    修改日期: 2021-08-04 10:01
    MD5: 1f2ef724cfc962454a93af774849f6ff
    SHA1: 2ac736bd3df0b9dd2bce3776b979fdcc5b94c292
    SHA256: 94a725b15cf5df5ecc95f1d3d15ee09b7a88ac468fac3cbabea94d4110aad347
    CRC32: fea2d4c5
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI-PXI PS21.0.txt (596 Bytes, 下载次数: 0, 售价: 10 元)
    PXI Platform Services 21.0 Readme
    July 2021
    This file contains installation instructions and compatibility information for PXI Platform Services.
    • PXI Platform Services Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • PXI Platform Services Manuals: New features, behavior changes, and other documentation
    PXI Platform Services provides support for customers using NI PXI and PXI Express chassis and controllers.
    If you are using PXI Platform Services 21.0 to upgrade a Windows system that serves as a host for one or more LabVIEW Real-Time Module targets, it is highly recommended that you also update your targets to leverage new features and improved performance.
    Note  You cannot use PXI Platform Services 21.0 to configure a LabVIEW RT target with a version of PXI Platform Services earlier than 2.0.
    PXI Platform Services 21.0 supports the following operating systems:
    Note  PXI Platform Services 21.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use PXI Platform Services 21.0 to an unsupported OS. Additionally, after installing PXI Platform Services 21.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    PXI Platform Services 21.0 supports the following application software versions, including service packs.
    Versions Supported by PXI Platform Services
    LabVIEW2018 SP1, 2019 SP1, 2020 SP1, 2021
    LabVIEW NXG5.0, 5.1
    LabWindows™/CVI™2017 and later
    NI installs PXI Platform Services using NI Package Manager. If you do not already have NI software installed, PXI Platform Services installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/nipmdownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    The PXI Platform Services 21.0 release adds the following features:
    • Support for LabVIEW 2021.
    PXI Platform Services supports PXI and PXI Express functionality. For a complete list of hardware that is compatible with PXI Platform Services, refer to NI PXI Platform Services Hardware Support.
    PXI Platform Services will no longer provide support for the following hardware:
    • PXIe-8105
    • PXIe-8106
    The following sections detail considerations for using LabVIEW NXG with PXI Platform Services 21.0.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    PXI Platform Services no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 1998–2021 National Instruments Corporation. All rights reserved.
    374995W-01
    GMT+8, 2025-5-12 05:49
