查看: 3132|回复: 0
[NI软件产品] NI ECU Test System Maintenance Software 21.0.1 x64Win10 64bitEng NI ECU测试系统维护软件ECUTSMS21.0.1下载
    14 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2021-9-6 10:35:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    ECU测试系统维护软件
    ECU测试系统维护软件可帮助您执行现场诊断测试并管理ECU测试系统(ECUTS)。
    ECU测试系统维护软件是用于管理ECUTS配置(例如仪器资源和校准信息)的应用软件。该软件还包括现场诊断测试仪(FDT)工具,用于现场的诊断和测试。ECUTS随附了ECU测试系统维护软件。
    ECU测试系统维护软件21.0.1发布日期
    2021/4/13
    包含的版本
    21.0.1完整版
    受支持的操作系统
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 1284044800 字节 (1.20 GB)
    修改日期: 2021-04-13 17:01
    MD5: ca6a95c113b31be76732ac1969668a61
    SHA1: ca227e2077054ab0581863d6d6ce92af8b0c2d8d
    SHA256: 77bcaeac4b22259012e419aa967caa3ef4d3bc3da07a18a915ea39f94d38591d
    CRC32: c86a0e5b
    ECUTSMS21.0.1.txt (709 Bytes, 下载次数: 0, 售价: 10 圆)
    ECU Test System Maintenance Software 21.0 Readme
    February 2021
    This file contains important information about getting started with the ECU Test System Maintenance Software 21.0, including system requirements and installation instructions.
    • ECU Test System Maintenance Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Use the ECU Test System Maintenance Software to interactively test ECU Test System (ECUTS) hardware components. Launch the ECU Test System Maintenance Software from the Test System Maintenance Software desktop shortcut.
    The ECU Test System Maintenance Software has the following requirements:
    • Pentium 4 G1 (or equivalent) or later 64-bit (x64) processor
    • 2 GB of disk space
    • 4 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 pixels screen resolution
    • 64-bit version of Windows 10 (version 1903)
    The ECU Test System Maintenance Software uses the LabVIEW 2019 Run-Time Engine.
    The ECUTS is delivered with the ECU Test System Maintenance Software 21.0 installed. If you need to install the ECU Test System Maintenance Software yourself, download the installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • New user interface makes it easier to execute operations and review previous reports.
    • Added support for the FDT-16041.
    • You can now execute operations on specific hardware resources.
    • Reports are now viewable directly from the ECU Test System Maintenance Software user interface.
    • Dropped support for the FDT-16040.
    Refer to the Test System Maintenance Software Help, accessible via the Help button in the ECU Test System Maintenance Software, for information about the ECU Test System Maintenance Software.
    © 2020–2021 National Instruments Corporation. All rights reserved.
    • Additional Test System Maintenance Software licenses are located in the \Test System Maintenance directory.
    378228B-01
    GMT+8, 2026-4-1 14:20
