查看: 2689|回复: 0
[NI驱动程序] NI-DCPower 21.0 x64Win10 32/64bit ENG/JPN NI DC电源仪器驱动程序21.0下载
    昨天 08:04
  • 签到天数: 3559 天
    连续签到: 4 天
    发表于 2021-9-3 15:40:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-DCPower
    NI-DCPower自20.7版本开始,仅支持64位Win10、Win Server 2016、Win Server 2019系统,但是仍然可支持32位的LabVIEW。
    发布日期
    2021/8/13
    包含的版本
    21.0.0
    受支持的操作系统
    语言
    英语,日语
    校验和
    文件大小: 2550341632 字节 (2.38 GB)
    修改日期: 2021-08-04 10:18
    MD5: 0ed693818a385aa2b36480d88a0e60d3
    SHA1: 518a25a46728790f1757c06368a380e06558d2b3
    SHA256: bd77da08e4fb1f49b583d49b7a5f8e1f87d157d6f2d5d2ca25ae613ae5bba35d
    CRC32: 632bbabb
    注册登录视觉论坛,购买附件查看下载地址
    NI-DCPower21.0.txt (549 Bytes, 下载次数: 0, 售价: 10 元)
    NI-DCPower 21.0 Readme
    July 2021
    This file contains installation instructions and compatibility information for NI-DCPower 21.0.
    • NI-DCPower Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-DCPower Manuals: New features, behavior changes, and other documentation
    NI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes examples.
    NI-DCPower 21.0 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DCPower 21.0 supports the following operating systems:
    • NI Real-Time Phar Lap ETS1
    • NI Linux® Real-Time1
    1 These operating systems are not supported for the following features:
    • NI Linux Real-Time
      • Autopopulation of resource names in LabVIEW 2020 and earlier
      • Test panels as accessible from Measurement & Automation Explorer (MAX)
      • Support for the PXIe-4135 (40W), PXIe-4137 (40W), and PXIe-4139 (40W) SMU
      • Independent channels
    NI-DCPower 21.0 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support or Python Support.
    Versions Supported by NI-DCPower
    LabVIEW2018, 2019, 2020, 2021
    LabVIEW Real-Time Module*2018, 2019, 2020, 2021
    LabVIEW NXG†5.1
    LabWindows™/CVI™2015 and later
    LabWindows/CVI Real-Time Module*2015 and later
    * No support for PXIe-4162/4163 source measure units.
    † No support for independent channels.
    If you are using the NI-DCPower .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DCPower .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DCPower installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to .NET Resources for NI Hardware and Software.
    Python Support
    For more information on installing and using Python, refer to the nidcpower module.
    Download the NI-DCPower 21.0 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. For more information and steps to resolve this issue, refer to NI Installer Hangs While Installing Visual C++ 2015 Run-Time.
    Installing NI-DCPower 21.0 for LabVIEW NXG
    • Added support for LabVIEW 2021
    NI-DAQmx-Based Power Supplies and SMUs
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4154
    Non-NI-DAQmx-Based Power Supplies and SMUs
    • PXIe-4147
    • PXIe-4162
    • PXIe-4163
    NI-DCPower 21.0: The NI-DCPower Soft Front Panel has been replaced by InstrumentStudio, which is automatically installed when you install the NI‑DCPower driver. You can access InstrumentStudio in one of the following ways:
    • From the Windows start menu, select National Instruments»InstrumentStudio [year]. This launches InstrumentStudio and runs a soft front panel populated with devices detected on your system.
    • From Measurement & Automation Explorer (MAX), select a device and then click Test Panels.... This launches InstrumentStudio and runs a soft front panel for the device you selected.
    The deprecated NI-DCPower Soft Front Panel remains available for download. Visit Legacy Soft Front Panels for NI-DCPower, NI-DMM, NI-FGEN, and NI-SCOPE for more information.
    NI-DCPower 20.6: To support independent channels, numerous NI-DCPower functions have been superseded by new versions that can access instrument channels independently. In addition, numerous NI-DCPower properties can now be configured per channel rather than per session.
    Refer to the NI DC Power Supplies and SMUs Help accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower.
    You can access all the installed NI-DCPower examples at Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DCPower" to locate all NI-DCPower examples.
    The following sections detail considerations for using LabVIEW NXG with NI-DCPower.
    LabVIEW NXG Hardware Support
    NI 411x, 413x, 414x, and 4154 Power Supplies and SMUs
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4147
    • PXIe-4154
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-DCPower no longer installs IVI Compliance Package. NI-DCPower supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    NI-DCPower no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi.
    © 2007–2021 National Instruments Corporation. All rights reserved.
    375374AD-01
    GMT+8, 2025-6-7 01:34
