查看: 3103|回复: 0
[LV工具模块] LabVIEW 2021 Real-Time Module x64Win10 32bitJpn LabVIEW2021实时模块日文版下载RT2021
    14 小时前
  • 签到天数: 3629 天
    连续签到: 3 天
    发表于 2021-8-27 12:30:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    自2011版实时模块起,NI提供了中文、日文、英语等三个语言版。本视觉论坛提供中文和英文版,部分日文版。自RTM2021版起,有64位的RT模块(仅英文版),之前的版本,仅32位版本。
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    LabVIEW 2021 Real-Time模块
    发布日期
    2021/8/13
    包含的版本
    2021
    受支持的操作系统
    语言
    日文
    校验和
    32JPN
    文件大小: 2437613568 字节 (2.27 GB)
    修改日期: 2021-08-12 06:11
    MD5: 495154e097030d7cff599199454a0c0c
    SHA1: 604a69a51c8ed7d381a57a6ac5fc5a46b59f6fc5
    SHA256: a10d75b3ebf64492b6e6346d8aa04c980d5928c210c5b8171b33cc312bc89179
    CRC32: 46e2de51
    请注册登录视觉论坛会员,购买附件查看
    RTM2021x86JPN.txt (635 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2021 Real-Time Module Readme
    July 2021
    This file contains installation instructions and compatibility information for the LabVIEW Real-Time Module.
    • LabVIEW Real-Time Module Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW Real-Time Module Manuals: New features, behavior changes, and other documentation
    The Real-Time Module is a complete solution for creating reliable, stand-alone embedded systems with a graphical programming approach. As an add-on to the LabVIEW development environment, the Real-Time Module helps you develop and debug graphical, deterministic real-time applications that can be downloaded to and executed on embedded hardware devices such as CompactRIO Controllers, CompactDAQ Controllers, CompactRIO Single-Board Controllers, PXI Controllers, or vision systems.
    The Real-Time Module has the following requirements:
    • LabVIEW 2021 Full or Professional Development System (32-bit)
    • At least 200 MB of disk space in addition to the LabVIEW-recommended minimum
    Note
    • The Real-Time Module (32-bit) is compatible with LabVIEW (32-bit) only. Therefore, you must have LabVIEW (32-bit) installed even if you use a 64-bit OS. The Real-Time Module (64-bit) is compatible with LabVIEW (64-bit) only.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    The Real-Time Module supports the following operating systems for application development:
    Note  The Real-Time Module no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. The Real-Time Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the Real-Time Module to an unsupported OS. Additionally, after installing the Real-Time Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The Real-Time Module installs the following real-time operating systems (RTOSes). Refer to the specific RT target hardware documentation for information about which RTOS your target uses.
    • NI Linux Real-Time
    • Phar Lap ETS
    • VxWorks
    Note  Each RTOS supports only a subset of LabVIEW features. Refer to the Real-Time Module»Real-Time Operating Systems book on the Contents tab of the LabVIEW Help for a list of unsupported LabVIEW features and special considerations for each RTOS.
    The LabVIEW 2021 Real-Time Module supports the following application software versions, including service packs.
    Versions Supported by the Real-Time Module
    LabVIEW2021
    Download the Real-Time Module installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You also can install all of your LabVIEW products—including the Real-Time Module—using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    • Use the serial number that is included with your software to activate the Advanced Signal Processing Toolkit. For more information on the Real-Time Module activation, refer to NI Software Activation.
    Installing and Using Japanese and Simplified Chinese Languages on an RT Target
    After you install the Real-Time Module on your development computer, you can complete the following steps to install and use Japanese and Simplified Chinese languages on an RT target:
    • Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer (NI MAX) to install the Language Support for Japanese or Language Support for Simplified Chinese software component on the RT target. Refer to the Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
    • Open the System Settings tab and select Japanese or Simplified Chinese as the Locale.
    Note  You cannot use Japanese or Simplified Chinese characters in directory names or filenames on the RT target.
    Note  The Real-Time Module (64-bit) supports English only.
    Configuring RT Targets
    Use NI MAX to configure RT targets and to install software and drivers on targets. You can install NI MAX from the NI Package Manager or the LabVIEW Platform media.
    • Networked RT Targets—Refer to the Remote Systems book in the Measurement & Automation Explorer Help, available by selecting Help»MAX Help from MAX, for information about configuring networked RT targets.
    • Desktop PC Targets—Refer to the Using Desktop PCs as RT Targets with the Real-Time Module document for information about configuring a desktop PC as a networked RT target. Navigate to the labview\manuals directory and double-click RT_Using_PC_as_RT_Target.pdf to open the document.
    Note  If you install NI Web-based Configuration & Monitoring on an RT target, you can use a web browser to perform common monitoring and configuration tasks on the target. On the Contents tab in the LabVIEW Help, select Fundamentals»Working with Projects and Targets»How-To»Monitoring and Configuring a Remote Device from a Web Browser for information about NI Web-based Configuration & Monitoring.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Real-Time Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Real-Time Module are located in the labview\examples\Real-Time Module directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Real-Time Module no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi.
    © 1999–2021 National Instruments Corporation. All rights reserved.
    374714M-01
    GMT+8, 2025-8-20 23:29
