查看: 3893|回复: 0
[LabVIEW] NI LabVIEW 2021 Community Linux64ENG LV2021社区版 64位Linux系统英文版离线安装包下载
    昨天 08:11
    发表于 2021-8-23 17:44:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2021
    发布日期:
    21-8-13
    包含的版本:
    2021
    SUSE
    Scientific Linux
    RedHat
    Linux
    语言:
    英文
    文件大小: 691838976 字节 (659.79 MB)
    修改日期: 2021-07-20 04:22
    MD5: 697fff1a00f368031eae23c2f5bc415e
    SHA1: dd3604840b8df7c443cf491ca8a8eb88f8cc9c9a
    SHA256: 1e7d50474c59baa4e34c83d8a90bc0235c29c0fa4e9f68a3c999d98032785919
    CRC32: ebb0ba84
    注册登录视觉论坛会员,购买附件查看
    LV2021 64Linux.txt (516 Bytes, 下载次数: 0, 售价: 20 圆)
    LabVIEW 2021 Readme for GNU/Linux
    July 2021
    Supported Drivers
    LabVIEW 2021 for Linux has the following requirements:
    Linux
    openSUSE Leap 15.2
    openSUSE Leap 15.1
    Red Hat Enterprise Linux 8
    Red Hat Enterprise Linux 7
    CentOS 8
    CentOS 7
    Note
    • LabVIEW 2021 for Linux is available only in 64-bit.
    To install LabVIEW modules and toolkits, refer to the readme of each product for installation instructions. The VI Analyzer Toolkits installs with the LabVIEW Professional Development System for Linux.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2021.
    Complete the following steps to install a patch on computers with LabVIEW 2021. Replace f# with the specific patch you are installing.
    • Close all NI software.
    • Download LV2021_f#LPatch.tgz into a folder. For example, download the file to ~/Desktop/Patch/LV2021_f#LPatch.tgz.
    • Unpack LV2021_f#LPatch.tgz. For example, cd ~/Desktop/Patch and tar -xzf LV2021_f#LPatch.tgz.
    • Run the installation script as root. For example, type su and enter the password. Then run ./INSTALL.
    • After the installation script reports that Patch installation completed, verify that the patch installed correctly. Select Help»About LabVIEW and look for 21.0.0f# on the right portion of the window.
    LabVIEW 2021 for Linux supports the following modules and toolkits.
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    Supported Drivers
    Refer to the NI website for information about drivers compatible with LabVIEW for Linux. To use hardware with LabVIEW 2021, install the latest version of the driver for the device. Refer to the readme of each driver for more information about system requirements and installation instructions.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2021.
    © 2004–2021 National Instruments Corporation. All rights reserved.
    374718R-01
    GMT+8, 2026-3-13 05:09
