查看: 7861|回复: 1
[RTE运行引擎] NI LabVIEW 2020 SP1 Runtime Engine X64 MACOS LV2020SP1运行时引擎RTE64位苹果系统版本离线下载
    昨天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
    发表于 2021-8-9 11:00:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2020 SP1
    发布日期:
    2021/1/8
    包含的版本:
    2020 SP1
    Mac OS
    语言:
    English
    LV2020SP1 MAC RTE
    文件大小: 63179701 字节 (60.25 MB)
    修改日期: 2020-12-17 04:20
    MD5: 4848ef27eb0750bbf93fc65f602d5af2(官方正确)
    SHA1: a1683854aece63508addd316279dbee8d42e0a63
    SHA256: 97775360b0c17d0ebe39760ba2be80f2f7c815cdae650ddaa2ae3f9903c20301
    CRC32: de8ebd35
    百度网盘和NI官方下载地址(回复可见):
    LV2020SP1MACTRTE.txt (533 Bytes, 下载次数: 1, 售价: 2 元)
    LabVIEW 2020 SP1 Readme for macOS
    January 2021
    This file contains important information about LabVIEW 2020 SP1 for macOS, including system requirements, installation instructions, known issues, and a partial list of bugs fixed. LabVIEW 2020 SP1 for macOS is available only in 64-bit.
    Supported Drivers
    LabVIEW 2020 SP1 for macOS has the following requirements:
    macOS
    RAM256 MB2 GB
    Operating SystemmacOS 10.14 or 10.15macOS 10.14 or 10.15
    Note
    • LabVIEW 2020 SP1 for macOS is available only in 64-bit.
    Note  If you download the installation image from ni.com, you may run into a macOS warning when you double-click the installer to run. Instead, right-click the installer and select Open. When you see the warning message, click Open to run the installer and proceed with the installation.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2020 SP1.
    Complete the following steps to install a patch on computers with LabVIEW 2020 SP1. Replace f# with the specific patch you are installing.
    • Close all NI software.
    • Mount LabVIEW2020f#.dmg and run LabVIEW 2020 SP1 f# Patch.
    • Verify that the patch installs correctly. Select Help»About LabVIEW and look for 20.0.0f# on the right portion of the window.
    LabVIEW 2020 SP1 for macOS supports the following modules and toolkits.
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    Supported Drivers
    LabVIEW 2020 SP1 for macOS supports the following drivers. To use hardware with LabVIEW 2020 SP1, install the latest version of the driver for the device.
    • NI-488.2
    • NI-VISA
    Refer to the readme of each driver for more information about system requirements and installation instructions.
    You can access the software and documentation known issues list online. Visit LabVIEW 2020 SP1 Known Issues for an up-to-date list of known issues.
    You can access the software and documentation bug fix list online. Visit ni.com/r/lv2020sp1bf for an up-to-date list of bug fixes in LabVIEW 2020 SP1.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2020 SP1.
    © 2004–2021 National Instruments Corporation. All rights reserved.
    374717P-01
    发表于 2021-11-3 22:00:00 | 显示全部楼层 来自:广东省中山市 电子科技大学中山学院
    视觉项目评估,就到视觉论坛http://visionbbs.com,物美价廉,技术过硬,服务周到,值得拥有
    GMT+8, 2025-6-1 03:51
