查看: 2573|回复: 0
[NI驱动程序] NI-SWITCH 17.0 Win32/64Eng/Jpn NI开关产品驱动程序17.0下载
    14 小时前
  • 签到天数: 3523 天
    连续签到: 11 天
    发表于 2021-7-27 23:25:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH是用于控制和配置NI开关的NI仪器驱动程序。NI-SWITCH一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,并包含了交互式软件前面板和示例。
    Win32/64Eng/Jpn
    17.0
    文件大小: 1912041352 字节 (1.78 GB)
    修改日期: 2017-05-18 01:32
    MD5: cfd13010c607cfc2113363122a962dd3(官方正确)
    SHA1: 78d4f6383b2fac58a8130845ec4ce509855ba21c
    SHA256: 7451e1d6a01aa583a47b68d9012d6504aeacc2bcf092f8a3cec86f8cde4f5768
    CRC32: fa2f1311
    Switch17.0.txt (517 Bytes, 下载次数: 0, 售价: 10 元)
    NI-SWITCH 17.0 Readme
    May 2017
    This file contains important information about NI-SWITCH, including installation instructions, new features, a partial list of bugs fixed for NI-SWITCH 17.0, and known issues.
    The NI-SWITCH driver provides driver support and documentation for all of NI's PXI, PXIe, and SCXI Switch products. NI-SWITCH is an IVI-compliant driver that allows NI Switch modules to be used with standard IVI Class commands.
    The NI-SWITCH driver contains both LabVIEW and text-based APIs for programming NI Switches.
    NI-SWITCH 17.0 has the following requirements:
    NI-SWITCH 17.0 supports the following operating systems:
    Note  NI-SWITCH 17.0 and later does not support Windows Server non-R2 editions.
    Note  In 2016 NI dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SWITCH 17.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SWITCH 17.0 to an unsupported OS. Additionally, after installing NI-SWITCH 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SWITCH 17.0 and later support the following real-time operating environments:
    • LabVIEW Real-Time Module
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-SWITCH. To add support for ADEs installed after installing NI-SWITCH, modify your NI-SWITCH installation or launch the NI-SWITCH installer again.
    • LabVIEW 2014 SP1, 2015 SP1, 2016, or 2017
    • LabVIEW Real-Time Module 2014 SP1, 2015 SP1, 2016, or 2017
    • LabWindows/CVI 2013 or later
    • LabWindows/CVI Real-Time Module 2013 or later
    If you are using the NI-SWITCH .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SWITCH .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    Installation InstructionsInstalling NI-SWITCH 17.0 for LabVIEW
    Complete the following steps to install NI-SWITCH 17.0 for use with LabVIEW:
    • Install LabVIEW.
    • (Optional) Install LabVIEW Real-Time.
    • Install NI-SWITCH 17.0.
    Uninstalling/Modifying NI-SWITCH 17.0
    • Select NI-SWITCH 17.0 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-SWITCH installation, the following software is installed. To completely remove the NI-SWITCH installation from your system, you must also remove all of the following packages:
    • NI-SWITCH Runtime
    • NI IVI Compliance Package
    • NI-DAQmx Runtime
    • NI-VISA
    • NI IO Trace
    NI-SWITCH no longer installs IVI Compliance Package. NI-SWITCH supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    • Added support for LabVIEW 2017
    The following list details the hardware models supported in NI-SWITCH 17.0.
    Matrix Module for SwitchBlock
    • SWB-2810
    • SWB-2811
    • SWB-2812
    • SWB-2813
    • SWB-2814
    • SWB-2815
    • SWB-2816
    • SWB-2817
    • SWB-2833
    • SWB-2834
    • SWB-2865A
    PXI Carrier Module for SwitchBlock
    • PXI-2800
    PXI Matrix Switch Module
    • PXI/PXIe-2529
    • PXI-2530
    • PXI-2530B
    • PXI/PXIe-2531
    • PXI/PXIe-2532
    • PXI/PXIe-2532B
    • PXI-2533
    • PXI-2534
    • PXI-2535
    • PXI-2536
    • PXIe-2737
    • PXIe-2738
    • PXIe-2739
    PXI Multiplexer Switch Modules
    • PXI-2501
    • PXI-2503
    • PXIe-2524
    • PXIe-2525
    • PXIe-2526
    • PXI/PXIe-2527
    • PXI/PXIe-2575
    • PXI-2576
    • PXI-2584
    • PXI-2585
    • PXIe-2746
    • PXIe-2747
    • PXIe-2748
    PXI Programmable Resistor Module
    • PXI-2720
    • PXI-2722
    • PXIe-2725
    • PXIe-2727
    PXI Relay Driver Module
    • PXI-2567
    PXI Relay Module
    • PXI-2520
    • PXI-2521
    • PXI-2522
    • PXI-2523
    • PXI-2564
    • PXI-2565
    • PXI-2566
    • PXI-2568
    • PXI/PXIe-2569
    • PXI-2570
    • PXI-2571
    • PXI-2586
    PXI RF Matrix Switch Module
    • PXI/PXIe-2540
    • PXI/PXIe-2541
    PXI RF Multiplexer Switch Module
    • PXI/PXIe-2543
    • PXI/PXIe-2544
    • PXI-2545
    • PXI-2546
    • PXI-2547
    • PXI-2554
    • PXI-2555
    • PXI-2556
    • PXI-2557
    • PXI-2590
    • PXI-2591
    • PXI/PXIe-2593
    • PXI-2594
    • PXI-2595
    • PXI-2596
    • PXI-2597
    • PXI-2796
    • PXI-2797
    PXI RF Relay Module
    • PXI/PXIe-2542
    • PXI-2548
    • PXI-2549
    • PXI-2558
    • PXI-2559
    • PXI-2599
    • PXI-2799
    PXI Signal Insertion Switch Module
    • PXI-2510
    • PXI/PXIe-2512
    • PXI/PXIe-2514
    • PXI/PXIe-2515
    PXI Transfer Switch Modules
    • PXI-2598
    • PXI-2798
    • PXIe-2790
    General-Purpose Switch Module for SCXI
    • SCXI-1160
    • SCXI-1161
    • SCXI-1166
    • SCXI-1169
    Matrix/Multiplexer Switch Module for SCXI
    • SCXI-1127
    • SCXI-1128
    • SCXI-1129
    • SCXI-1130
    • SCXI-1175
    • SCXI-1191
    Relay Switch Module for SCXI
    • SCXI-1163R
    • SCXI-1167
    • SCXI-1192
    RF Multiplexer Switch Module for SCXI
    • SCXI-1190
    • SCXI-1193
    • SCXI-1194
    • SCXI-1195
    You can access the software and documentation known issues list online. Refer to the NI-SWITCH Known Issues at ni.com/info and enter the Info Code expn65 for an up-to-date list of known issues in NI-SWITCH 17.0.
    The following items are changes in NI-SWITCH 15.1.1 from NI-SWITCH 15.1.0.
    530716Fixed issue that caused MAX with NI Switch Executive to hang when users configured RouteGroups with more connections than are normally allowed by the relay drive limit.
    Documentation for NI Switches is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
    DocumentFormatDescription
    NI Switches HelpHTML/Windows HelpContains primary help content for NI Switches. The help is an HTML version of a traditional user manual that includes the following information:
    • Switches Fundamentals
    • Hardware device information
    • How to get starting with an application development
    • A complete reference for all Switches programming functions and VIs
    Specifications for your devicePrinted and PDFLists technical specifications for your device.
    Maintain Forced-Air Cooling Note to UsersPrintedContains important cooling information for your device.
    Introduction to NI-SWITCHHTMLContains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues.
    NI-SWITCH ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, and legal notices.
    NI-SWITCH IVI Compliance DocumentTXTContains information about IVI compliance.
    To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-SWITCH examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions:
    • Click the Browse tab to locate examples by task at Hardware Input and Ouput»Modular Instruments»NI-SWITCH or by directory structure at instr»niSwitch.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SWITCH" to locate all NI Switch examples.
    You can also access all the installed NI-SWITCH examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-SWITCH»Examples.
    The following sections detail considerations for using LabVIEW NXG with NI-SWITCH 17.0.
    LabVIEW NXG Hardware Support
    The following list details the hardware models supported in NI-SWITCH 17.0 for LabVIEW NXG.
    • SWB-2810
    • SWB-2811
    • SWB-2812
    • SWB-2813
    • SWB-2814
    • SWB-2815
    • SWB-2816
    • SWB-2817
    • SWB-2833
    • SWB-2834
    • SWB-2865A
    • PXI-2800
    • PXI/PXIe-2529
    • PXI-2530
    • PXI-2530B
    • PXI/PXIe-2531
    • PXI/PXIe-2532
    • PXI/PXIe-2532B
    • PXI-2533
    • PXI-2534
    • PXI-2535
    • PXI-2536
    • PXIe-2737
    • PXIe-2738
    • PXIe-2739
    • PXI-2501
    • PXI-2503
    • PXIe-2524
    • PXIe-2525
    • PXIe-2526
    • PXI/PXIe-2527
    • PXI/PXIe-2575
    • PXI-2576
    • PXI-2584
    • PXI-2585
    • PXIe-2746
    • PXIe-2747
    • PXIe-2748
    • PXI-2720
    • PXI-2722
    • PXIe-2725
    • PXIe-2727
    • PXI-2567
    PXI Relay Module
    • PXI-2520
    • PXI-2521
    • PXI-2522
    • PXI-2523
    • PXI-2564
    • PXI-2565
    • PXI-2566
    • PXI-2568
    • PXI/PXIe-2569
    • PXI-2570
    • PXI-2571
    • PXI-2586
    • PXI/PXIe-2540
    • PXI/PXIe-2541
    • PXI/PXIe-2543
    • PXI/PXIe-2544
    • PXI-2545
    • PXI-2546
    • PXI-2547
    • PXI-2554
    • PXI-2555
    • PXI-2556
    • PXI-2557
    • PXI-2590
    • PXI-2591
    • PXI/PXIe-2593
    • PXI-2594
    • PXI-2595
    • PXI-2596
    • PXI-2597
    • PXI-2796
    • PXI-2797
    PXI RF Relay Module
    • PXI/PXIe-2542
    • PXI-2548
    • PXI-2549
    • PXI-2558
    • PXI-2559
    • PXI-2599
    • PXI-2799
    • PXI-2510
    • PXI/PXIe-2512
    • PXI/PXIe-2514
    • PXI/PXIe-2515
    • PXI-2598
    • PXI-2798
    • PXIe-2790
    • SCXI-1160
    • SCXI-1161
    • SCXI-1166
    • SCXI-1169
    • SCXI-1127
    • SCXI-1128
    • SCXI-1129
    • SCXI-1130
    • SCXI-1175
    • SCXI-1191
    • SCXI-1163R
    • SCXI-1167
    • SCXI-1192
    • SCXI-1190
    • SCXI-1193
    • SCXI-1194
    • SCXI-1195
    Installing NI-SWITCH 17.0 for LabVIEW NXG
    NI automates LabVIEW NXG installation using a package manager. Complete the following steps to install NI-SWITCH 17.0 for LabVIEW NXG.
    • Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
    • Click Download LabVIEW NXG 1.0.
    • NI Package Manager installs, then automatically opens a download window.
    • Select LabVIEW NXG Suite and click the green Install button.
    • Select LabVIEW NXG 1.0 and NI-SWITCH 17.0, as well as any other items you need.
    • Complete the installer instructions to download LabVIEW NXG 1.0 and NI-SWITCH 17.0.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 1998–2017 National Instruments. All rights reserved.
    375366C-01
    举报
    GMT+8, 2025-4-24 22:11
