查看: 2771|回复: 0
[NI驱动程序] NI-SWITCH 15.1.1 Win32/64Eng/Jpn NI开关产品驱动程序15.1.1下载
    昨天 15:45
  • 签到天数: 3536 天
    连续签到: 6 天
    发表于 2021-7-27 23:22:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH是用于控制和配置NI开关的NI仪器驱动程序。NI-SWITCH一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,并包含了交互式软件前面板和示例。
    Win32/64Eng/Jpn
    15.1.1
    文件大小: 1873371936 字节 (1.74 GB)
    修改日期: 2015-12-09 04:45
    MD5: 411d46ec53be1dd12c89702adb25ef4a(官方正确)
    SHA1: 034f8cae00db6b3b4aa84dd697b23bb314f153a5
    SHA256: 3e31d486550d8898dd3f93cac151d57ca1dc4c9761a56e4b0fe5355b6fa08a8d
    CRC32: 6b5ca568
    Switch15.1.1.txt (520 Bytes, 下载次数: 0, 售价: 10 元)
    NI-SWITCH Readme
    Version 15.1.1
    Thank you for using NI-SWITCH. This file contains important information about NI-SWITCH and is organized into the following sections:
    Driver Version Naming Changes
    Uninstalling/Modifying NI-SWITCH
    NI Software Support for Microsoft Windows Vista and Microsoft Windows XP
    NI-SWITCH 15.1.1 fixes bugs in NI-SWITCH 15.1.0.
    • See Bug Fixes.
    NI-SWITCH 15.1.0 includes the following new features:
    • Support for LabVIEW 2015 (32-bit) and LabVIEW 2015 (64-bit).
    • Support for the NI PXIe-2524, NI PXIe-2525, NI PXIe-2526, NI PXIe-2737, NI PXIe-2738, NI PXIe-2739, NI PXIe-2746, NI PXIe-2747, and NI PXIe-2748. For more information about driver differences between NI-SWITCH and NI-DAQmx, refer to the Knowledge Base document at ni.com/info using info code switchdriverconsiderations. For more information about hardware differences between NI-SWITCH and NI-DAQmx-based devices, refer to the Knowledge Base document at info code exmfnf.
    • The Integrated Relay Resistance Test feature in the NI Switch Health Center
    • Behavioral changes when accessing NI-SWITCH devices through the NI-ModInst API:
      • When accessing the serial number attribute, NI-ModInst pads the serial number with leading zeros up to eight digits.
      • When accessing the device model attribute, NI-ModInst returns the full model name. For example, NI-ModInst returns "NI PXI-2501" instead of "PXI-2501."
    NI-SWITCH 15.0.0 adds support for LabVIEW 2015 (32- and 64-bit).
    NI-SWITCH 14.0.0 adds support for LabVIEW 2014 (32-bit) and LabVIEW 2014 (64-bit).
    NI-SWITCH 4.8 includes the following new features:
    • Support for the NI 2865A device.
    • Support for the NI PXI/PXIe-2542 and NI PXI/PXIe-2544 modules.
    • Device pinouts in Measurement & Automation Explorer (MAX) for NI switch modules.
    • Connect multiple channels using the niSwitch Connect Channels VI, and disconnect multiple channels using the niSwitch Disconnect Channels VI.
    • Support for NI-SWITCH run-time custom installers built using National Instruments application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI switches.
    Notes:
    • The run-time installer does not contain support for interactively configuring or testing hardware using MAX.
    • The run-time installer does not support upgrading from the full NI-SWITCH 4.6.5 or earlier or NI-DAQmx 8.9.x or earlier, to a run-time only installer. You must uninstall these products prior to installing the NI-SWITCH Run-Time installer.
    NI-SWITCH 4.6.5 adds support for LabVIEW 2013 (32-bit)and LabVIEW 2013 (64-bit).
    NI-SWITCH 4.6.1 includes the following new features:
    • Support for the NI PXI/PXIe-2540 and NI PXI/PXIe-2541 modules.
    • Improved the schematic display in Switch Soft Front Panel for some RF multiplexer topologies.
    NI-SWITCH 4.6 adds support for the NI PXI-2520, NI PXI-2521, NI PXI-2522, NI PXI-2523, and NI PXIe-2790 modules.
    NI-SWITCH 4.5.5 adds support for LabVIEW 2012 (32-bit) and LabVIEW 2012 (64-bit).
    NI-SWITCH 4.5 adds support for the NI 2833, NI 2834, NI PXI/PXIe-2532B, NI PXI-2720, NI PXI-2722, NI PXIe-2725, NI PXIe-2727, NI PXI-2796, NI PXI-2797, NI PXI-2798, and NI PXI-2799 modules.
    NI-SWITCH 4.4 includes the following new features:
    • Support for the NI 2812, NI 2813, NI 2814, NI 2817, and NI PXI/PXIe-2543 modules.
    • Support for one new NI PXI/PXIe-2532 topology and the NI TB-2646 terminal block.
    NI-SWITCH 4.3.5 adds support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit).
    NI-SWITCH 4.3 includes the following new features:
    • Support for the NI PXI-2530B and NI PXI-2571 modules.
    • Dynamic power budget for NI SwitchBlock cards and carriers.
    NI-SWITCH 15.1.1 and later supports the following National Instruments switch products:
    • NI 2810
    • NI 2811
    • NI 2812
    • NI 2813
    • NI 2814
    • NI 2815
    • NI 2816
    • NI 2817
    • NI 2833
    • NI 2834
    • NI 2865A
    • NI PXI-2501
    • NI PXI-2503
    • NI PXI-2510
    • NI PXI/PXIe-2512
    • NI PXI/PXIe-2514
    • NI PXI/PXIe-2515
    • NI PXI-2520
    • NI PXI-2521
    • NI PXI-2522
    • NI PXI-2523
    • NI PXIe-2524
    • NI PXIe-2525
    • NI PXIe-2526
    • NI PXI/PXIe-2527
    • NI PXI/PXIe-2529
    • NI PXI-2530
    • NI PXI-2530B
    • NI PXI/PXIe-2531
    • NI PXI/PXIe-2532
    • NI PXI/PXIe-2532B
    • NI PXI-2533
    • NI PXI-2534
    • NI PXI-2535
    • NI PXI-2536
    • NI PXI/PXIe-2540
    • NI PXI/PXIe-2541
    • NI PXI/PXIe-2542
    • NI PXI/PXIe-2543
    • NI PXI/PXIe-2544
    • NI PXI-2545
    • NI PXI-2546
    • NI PXI-2547
    • NI PXI-2548
    • NI PXI-2549
    • NI PXI-2554
    • NI PXI-2555
    • NI PXI-2556
    • NI PXI-2557
    • NI PXI-2558
    • NI PXI-2559
    • NI PXI-2564
    • NI PXI-2565
    • NI PXI-2566
    • NI PXI-2567
    • NI PXI-2568
    • NI PXI/PXIe-2569
    • NI PXI-2570
    • NI PXI-2571
    • NI PXI/PXIe-2575
    • NI PXI-2576
    • NI PXI-2584
    • NI PXI-2585
    • NI PXI-2586
    • NI PXI-2590
    • NI PXI-2591
    • NI PXI/PXIe-2593
    • NI PXI-2594
    • NI PXI-2595
    • NI PXI-2596
    • NI PXI-2597
    • NI PXI-2598
    • NI PXI-2599
    • NI PXI-2720
    • NI PXI-2722
    • NI PXIe-2725
    • NI PXIe-2727
    • NI PXIe-2737
    • NI PXIe-2738
    • NI PXIe-2739
    • NI PXIe-2746
    • NI PXIe-2747
    • NI PXIe-2748
    • NI PXIe-2790
    • NI PXI-2796
    • NI PXI-2797
    • NI PXI-2798
    • NI PXI-2799
    • NI PXI-2800
    • NI SCXI-1127
    • NI SCXI-1128
    • NI SCXI-1129
    • NI SCXI-1130
    • NI SCXI-1160
    • NI SCXI-1161
    • NI SCXI-1163R
    • NI SCXI-1166
    • NI SCXI-1167
    • NI SCXI-1169
    • NI SCXI-1175
    • NI SCXI-1190
    • NI SCXI-1191
    • NI SCXI-1192
    • NI SCXI-1193
    • NI SCXI-1194
    • NI SCXI-1195
    Notes:  NI-SWITCH does not support legacy resource descriptors (SCXI:: and PXI::) under Windows 8/7/Vista.
    NI-SWITCH supports the NI USB-1359 under Windows XP and the 32-bit version of Windows 8/7/Vista. NI-SWITCH does not support the NI USB-1359 under the 64-bit version of Windows 8/7/Vista.
    If you are using a cabled PXI chassis, note that MXI-4 is supported under Windows 8/7/Vista/XP, but MXI-3 is supported under only Windows XP.
    NI-SWITCH 15.1.1 and later support the following operating systems:
    Note:  NI-SWITCH 15.1.1 and later do not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-SWITCH 4.0.1 or earlier.
    NI-SWITCH 15.1.1 and later support the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP Service Pack 3 (SP3): 128 MB
      • Windows 8/7/Vista: 512 MB
    • Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP: 256 MB
      • Windows 8/7/Vista: 1 GB
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-SWITCH. To add support for ADEs installed after installing NI-SWITCH, modify your NI-SWITCH installation or launch the NI-SWITCH installer again.
    • LabVIEW 2012 SP1 (32-bit), 2012 SP1 (64-bit), 2013 SP1 (32-bit), 2013 SP1 (64-bit), 2014 SP1 (32-bit), 2014 SP1 (64-bit), 2015 (32-bit), or 2015 (64-bit)
    • LabVIEW Real-Time Module 2012 SP1, 2013 SP1, 2014 SP1, or 2015
    • LabWindows/CVI 2009 or later
    • LabWindows/CVI Real-Time Module 2009 or later
    • If you are running your application on an RT target, 128 MB of memory or more is required.
      • Windows XP: Documents and Settings\All Users\Documents\National Instruments
      • Windows 8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        NOTES: is configured as an environment variable on the target system.
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: C:/Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): C:/Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        NOTE: is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-SWITCH\Drivers\niSwitch
    NI-SWITCH Function Panel\Drivers\niSwitch\niSwitch.fp
    NI-SWITCH Examples\NI-SWITCH\examples
    NI-SWITCH Header files\Include
    NI-SWITCH Import Library files (32-bit)\Lib
    NI-SWITCH Import Library files (64-bit)\Lib_x64
    NI-SWITCH DLL (32-bit)\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-SWITCH DLL (64-bit)\Bin
    Documentation for NI Switches is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
    DocumentFormatDescription
    NI Switches HelpHTML/Windows HelpContains primary help content for NI Switches. The help is an HTML version of a traditional user manual that includes the following information:
    • Switches Fundamentals
    • Hardware device information
    • How to get starting with an application development
    • A complete reference for all Switches programming functions and VIs
    Specifications for your devicePrinted and PDFLists technical specifications for your device.
    Maintain Forced-Air Cooling Note to UsersPrintedContains important cooling information for your device.
    NI-SWITCH ReadmeHTML (this document)Cotnains information about supported hardware and operating systems, new features, and legal notices.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-SWITCH examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions:
    • Click the Browse tab to locate examples by task at Hardware Input and Ouput»Modular Instruments»NI-SWITCH or by directory structure at instr»niSwitch.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SWITCH" to locate all NI Switch examples.
    You can also access all the installed NI-SWITCH examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-SWITCH»Examples.
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information.
    NI-SWITCH versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName> . For example, is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-SWITCH 4.8. The first version released under the new numbering scheme is NI-SWITCH 14.0.0.
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-SWITCH 15.x from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-SWITCH installation, the following software is installed. To completely remove the NI-SWITCH installation from your system, you must also remove all of the following packages:
    • NI IVI Compliance Package 15.0
    • NI Measurement & Automation Explorer 15.0
    • NI-DAQmx Runtime 15.1
    • NI-VISA 15.0
    • NI IO Trace 15.0
    • NI-SWITCH Runtime 15.1.1
    You can access the software and documentation known issues list online. Refer to the NI-SWITCH 15.1.1 Known Issues web page on the National Instruments web site for an up-to-date list of known issues in NI-SWITCH 15.1.1.
    The following items are changes in NI-SWITCH 15.1.1 from NI-SWITCH 15.1.0.
    530716Fixed issue that caused MAX with NI Switch Executive to hang when users configured RouteGroups with more connections than are normally allowed by the relay drive limit.
    The following items are changes in NI-SWITCH 4.8 from NI-SWITCH 4.6.5.
    412074Fixed an issue in which the DAQmx Disconnect All VI returned an error when closing or opening multiple relays.
    338542Fixed an issue where the DAQmx Stop Task VI would time out.
    410401Fixed an issue where the NI switch software scanning examples did not work on an RT target.
    363694Fixed an issue with the Multi-Module Scan List that caused scanning to be incomplete.
    410717Fixed an issue where relay commands did not execute while using the USB-1359 with SCXI switch modules.
    The following items are changes in NI-SWITCH 4.6.5 from NI-SWITCH 4.6.1.
    408193Fixed an issue where calling DAQmx Disconnect (Multiple) on the NI PXI/PXIe-2540 or the NI PXI/PXIe-2541 left one or more relays powered.
    393334Fixed an issue where resetting the same switch in two or more parallel threads resulted in an error.
    The following items are changes in NI-SWITCH 4.6.1 from NI-SWITCH 4.6.
    372998Fixed an issue where the NI 2833/2834 power consumption was not accounted for in the carrier power budget.
    373015Removed hyphens from the SwitchBlock model strings in the NISWITCH_SUPPORTED_INSTRUMENT_MODELS constant.
    373073Fixed an issue where the default channel state of the NI PXIe-2790 did not represent the hardware state correctly.
    The following items are changes in NI-SWITCH 4.5 from NI-SWITCH 4.4.
    328251Fixed an issue where the NI PXI-2571 did not honor user-defined settling times.
    The following items are changes in NI-SWITCH 4.4 from NI-SWITCH 4.3.
    256580Improved Windows 7 performance.
    The following items are changes in NI-SWITCH 4.1 from NI-SWITCH 4.0.2.
    209501Fixed an issue that disabled legacy scanning of multiple modules with NI-SWITCH.
    The following items are changes in NI-SWITCH 4.0.1 from NI-SWITCH 4.0.
    181045Fixed power budget issue for the PXI/PXIe-2515.
    181067Fixed an issue where calling Device Reset on certain PXI/PXIe devices (NI-PXI/PXIe-2512/2514/2564/2585/2586) incorrectly updated relay count.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI-SWITCH Drops Support for Microsoft Windows Vista and Windows XP 2003 in 2016
    National Instruments NI-SWITCH will drop support for Microsoft Windows Vista and Windows XP as of July 1, 2016. Versions of NI-SWITCH that ship after July 1, 2016 will not install or run on Windows Vista or Windows XP. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 1998–2015 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-12 05:19
