查看: 2451|回复: 0
[NI驱动程序] NI-SWITCH 4.3 Win32/64Eng/Jpn NI开关产品驱动程序4.3下载
    昨天 15:45
  • 签到天数: 3536 天
    连续签到: 6 天
    发表于 2021-7-27 22:59:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH是用于控制和配置NI开关的NI仪器驱动程序。NI-SWITCH一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,并包含了交互式软件前面板和示例。
    Win32/64Eng/Jpn
    4.3
    文件大小: 1596851202 字节 (1.49 GB)
    修改日期: 2011-05-10 22:06
    MD5: 3d2399c973f8a544d9ff75be0a107e05(官方正确)
    SHA1: a1d52694c04d98f971d211d7ce9843efd5fffa6a
    SHA256: 13f21abaf287f3f306d3392e263c4c32745ee9f05b4d0a637cea8da4d36960fd
    CRC32: c35bf56d
    Switch4.3.txt (515 Bytes, 下载次数: 0, 售价: 10 元)
    NI-SWITCH Readme File
    Version 4.3
    Thank you for using NI-SWITCH. This file contains important information about NI-SWITCH and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying NI-SWITCH
    • Obsolete VIs and Functions
    • Known Issues
    • Bug Fixes
    NI-SWITCH 4.3 includes the following new features:
    • Support for the NI PXI-2530B and NI PXI-2571 modules.
    • Windows 7 performance improvements.
    • Dynamic power budget for NI SwitchBlock cards and carriers.
    NI-SWITCH 4.1 includes the following new features:
    • Support for the NI SwitchBlock, including the NI PXI-2800, NI 2810, NI 2811, NI 2815, and NI 2816.
    • Addition of the Analog Bus Sharing Enable property and the NISWITCH_ATTR_ANALOG_BUS_SHARING_ENABLE attribute.
    • Creation of the NI Switch Health Center for the maintenance of the NI SwitchBlock.
    • Addition of the configured topology option for the niSwitch Initialize With Topology and niSwitch Initialize With Options VIs and the niSwitch_InitWithTopology and niSwitch_InitWithOptions functions.
    • Support for Windows 7.
    NI-SWITCH 4.0.2 adds support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit)
    NI-SWITCH 4.0.1 includes bug fixes.
    NI-SWITCH 4.0 includes the following new features:
    • Support for LabVIEW 2009 (64-bit).
    • Support for NI PXI-2510 and NI PXI/PXIe-2512/2514/2515/2531 modules.
    • Support for Immediate Mode FIFO: This feature improves driver execution time of Immediate Mode Operations when operating multiple relays.
    • Support for 64-bit user mode.
    NI-SWITCH 4.3 and later supports the following National Instruments switch products:
    • NI 2810
    • NI 2811
    • NI 2815
    • NI 2816
    • NI PXI-2501
    • NI PXI-2503
    • NI PXI-2510
    • NI PXI/PXIe-2512
    • NI PXI/PXIe-2514
    • NI PXI/PXIe-2515
    • NI PXI/PXIe-2527
    • NI PXI/PXIe-2529
    • NI PXI-2530
    • NI PXI-2530B
    • NI PXI/PXIe-2531
    • NI PXI/PXIe-2532
    • NI PXI-2533
    • NI PXI-2534
    • NI PXI-2535
    • NI PXI-2536
    • NI PXI-2545
    • NI PXI-2546
    • NI PXI-2547
    • NI PXI-2548
    • NI PXI-2549
    • NI PXI-2554
    • NI PXI-2555
    • NI PXI-2556
    • NI PXI-2557
    • NI PXI-2558
    • NI PXI-2559
    • NI PXI-2564
    • NI PXI-2565
    • NI PXI-2566
    • NI PXI-2567
    • NI PXI-2568
    • NI PXI/PXIe-2569
    • NI PXI-2570
    • NI PXI-2571
    • NI PXI/PXIe-2575
    • NI PXI-2576
    • NI PXI-2584
    • NI PXI-2585
    • NI PXI-2586
    • NI PXI-2590
    • NI PXI-2591
    • NI PXI/PXIe-2593
    • NI PXI-2594
    • NI PXI-2595
    • NI PXI-2596
    • NI PXI-2597
    • NI PXI-2598
    • NI PXI-2599
    • NI PXI-2800
    • NI SCXI-1127
    • NI SCXI-1128
    • NI SCXI-1129
    • NI SCXI-1130
    • NI SCXI-1160
    • NI SCXI-1161
    • NI SCXI-1163R
    • NI SCXI-1166
    • NI SCXI-1167
    • NI SCXI-1169
    • NI SCXI-1175
    • NI SCXI-1190
    • NI SCXI-1191
    • NI SCXI-1192
    • NI SCXI-1193
    • NI SCXI-1194
    • NI SCXI-1195
    NOTES:  NI-SWITCH does not support legacy resource descriptors (SCXI:: and PXI::) under Windows 7/Vista.
    NI-SWITCH supports the NI USB-1359 under Windows XP and the 32-bit version of Windows 7/Vista. NI-SWITCH does not support the NI USB-1359 under the 64-bit version of Windows 7/Vista.
    If you are using a cabled PXI chassis, notice that MXI-4 is supported under Windows 7/Vista/XP, but MXI-3 is supported under only Windows XP.
    NI-SWITCH 4.3 and later and NI-DAQmx 9.3 and later support the following operating systems:
    • Windows XP (32-bit)
    NOTE:  NI-SWITCH 4.3 and later and NI-DAQmx 9.3 and later do not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-SWITCH 4.0.1 or earlier.
    NI-SWITCH 4.3 and later and NI-DAQmx 9.3 and later support the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System
    • RAM
      • Windows XP: 128 MB
      • Windows 7/Vista: 512 MB
    • Windows 7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM
      • Windows XP: 256 MB
      • Windows 7/Vista: 1 GB
    • If you are running your application on an RT target, 64 MB of memory or more is recommended.
    • LabVIEW 8.5.1, 8.6.1, 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), or 2010 SP1 (64-bit)
    • LabVIEW Real-Time Module 8.5.1 or later
    • LabWindows™/CVI™ 8.1.1 or later
    • LabWindows/CVI Real-Time Module 8.1 or later
    • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    • National Instruments file folder location, :
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 7/Vista: Users\Public\Documents\National Instruments
      • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 7 (32-bit)/Vista (32-bit)/XP
    NI-SWITCH\Drivers\niSwitch
    NI-SWITCH Function Panel\Drivers\niSwitch\niSwitch.fp
    NI-SWITCH Examples\niSwitch\Examples
    NI-SWITCH Header files\Include
    NI-SWITCH Import Library files (32-bit)\Lib
    NI-SWITCH Import Library files (64-bit)\Lib_x64
    NI-SWITCH DLL (32-bit)\Bin
    Additional File Locations for Windows 7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 7 (64-bit)/Vista (64-bit)
    NI-SWITCH DLL (64-bit)\Bin
    Documentation is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
    • NI-SWITCH Readme File
    • Read Me First: Safety and Electromagnetic Compatibility
    Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
    • NI Switches Getting Started Guide
    Printed and PDF format. Includes hardware and software installation, MAX configuration, and signal connection information.
    • NI Switches Help
    HTML help format. Includes switching fundamentals, device specific information, programming information, tutorials, a LabVIEW VI reference, and LabWindows/CVI, C++, and Visual Basic function references.
    • NI Switch Specifications
    Printed and PDF format. Lists specifications for each NI switch module.
    • NI Switch Accessory Installation Instructions (Optional)
    Printed and PDF format. Lists NI switch module accessory installation information.
    Examples
    Refer to Start»All Programs»National Instrument»NI-SWITCH»Examples for the examples for the supported ADEs. The examples cover immediate operations, synchronous scanning, handshaking, and software triggering. A complete example list is available in the NI Switches Help.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-SWITCH 4.x from the dialog box that appears.
    As part of the NI-SWITCH installation, the following list of software was installed. To completely remove NI-SWITCH from your system, you must remove all of these packages also.
    • NI IVI Compliance Package 4.2
    • NI Measurement & Automation Explorer 4.8
    • NI-DAQmx 9.3
    • NI-VISA 5.0
    • NI Spy 2.7.2
    • niSwitch Can Connect Channels? VI*
    • niSwitch Connect and Wait VI/function
    • niSwitch Control a Single Switch VI/function
    • niSwitch Disconnect and Wait VI/function
    • niSwitch Error-Query VI/function
    • niSwitch Get Error Info VI/function
    • niSwitch Is Debounced? VI*
    • niSwitch Is Scanning? VI*
    • niSwitch Query a Single Switch VI/function
    • niSwitch Read Calibration Data VI/function
    • niSwitch Scan VI/function
    • niSwitch Scanning Acquisition VI/function
    • niSwitch Write Calibration Data VI/function
    * The niSwitch Can Connect Channels?, niSwitch Is Debounced?, and niSwitch Is Scanning? VIs were replaced by identical VIs without question marks in the name.
    You can access the software and documentation known issues list online. Refer to the NI-SWITCH 4.3 Known Issues List web page on the National Instruments web site for an up-to-date list of known issues in NI-SWITCH 4.3.
    The following items are changes in NI-SWITCH 4.1 from NI-SWITCH 4.0.2.
    209501Fixed an issue that disabled legacy scanning of multiple modules with NI-SWITCH.
    The following items are changes in NI-SWITCH 4.0.1 from NI-SWITCH 4.0.
    181045Fixed power budget issue for the PXI/PXIe-2515.
    181067Fixed an issue where calling Device Reset on certain PXI/PXIe devices (NI-PXI/PXIe-2512/2514/2564/2585/2586) incorrectly updated relay count.
    © 1998–2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-12 06:08
