查看: 3010|回复: 0
[NI驱动程序] NI-SWITCH 4.0 Win32/64Eng/Jpn NI开关产品驱动程序4.0下载
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-7-27 22:55:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH是用于控制和配置NI开关的NI仪器驱动程序。NI-SWITCH一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,并包含了交互式软件前面板和示例。
    Win32/64Eng/Jpn
    4.0
    文件大小: 1262030438 字节 (1.18 GB)
    修改日期: 2010-04-25 06:36
    MD5: 636df65630b98543c8ad72d6799a534a(官方正确)
    SHA1: 7fb0665c14390ac8ab43e891006e3da95d756095
    SHA256: 8d29919bd307275015be2a0196e25b32844cba69ddb4acdc42d34a54a7faf7b2
    CRC32: 9947b7fe
    Switch4.0.txt (511 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SWITCH Readme File
    Version 4.0
    Thank you for using NI-SWITCH for Windows Vista/XP/2000.
    This file contains important information about NI-SWITCH and is organized into the following sections:
    • New Features in Version 4.0
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying NI-SWITCH
    • Obsolete VIs and Functions
    • Known Issues
    • Changes by Release
    • Support for LabVIEW 2009 (64-bit).
    • Support for NI PXI-2510 and NI PXI/PXIe-2512/2514/2515/2531 modules.
    • Support for Immediate Mode FIFO: This feature improves driver execution time of Immediate Mode Operations when operating multiple relays.
    • Support for 64-bit user mode.
    NI-SWITCH 4.0 and later supports the following switch modules:
    • NI PXI-2501
    • NI PXI-2503
    • NI PXI-2510
    • NI PXI/PXIe-2512
    • NI PXI/PXIe-2514
    • NI PXI/PXIe-2515
    • NI PXI/PXIe-2527
    • NI PXI/PXIe-2529
    • NI PXI-2530
    • NI PXI/PXIe-2531
    • NI PXI/PXIe-2532
    • NI PXI-2533
    • NI PXI-2534
    • NI PXI-2535
    • NI PXI-2536
    • NI PXI-2545
    • NI PXI-2546
    • NI PXI-2547
    • NI PXI-2548
    • NI PXI-2549
    • NI PXI-2554
    • NI PXI-2555
    • NI PXI-2556
    • NI PXI-2557
    • NI PXI-2558
    • NI PXI-2559
    • NI PXI-2564
    • NI PXI-2565
    • NI PXI-2566
    • NI PXI-2567
    • NI PXI-2568
    • NI PXI/PXIe-2569
    • NI PXI-2570
    • NI PXI/PXIe-2575
    • NI PXI-2576
    • NI PXI-2584
    • NI PXI-2585
    • NI PXI-2586
    • NI PXI-2590
    • NI PXI-2591
    • NI PXI/PXIe-2593
    • NI PXI-2594
    • NI PXI-2595
    • NI PXI-2596
    • NI PXI-2597
    • NI PXI-2598
    • NI PXI-2599
    • NI SCXI-1127
    • NI SCXI-1128
    • NI SCXI-1129
    • NI SCXI-1130
    • NI SCXI-1160
    • NI SCXI-1161
    • NI SCXI-1163R
    • NI SCXI-1166
    • NI SCXI-1167
    • NI SCXI-1169
    • NI SCXI-1175
    • NI SCXI-1190
    • NI SCXI-1191
    • NI SCXI-1192
    • NI SCXI-1193
    • NI SCXI-1194
    • NI SCXI-1195
    NOTES:  NI-SWITCH does not support legacy resource descriptors (SCXI:: and PXI::) under Windows Vista.
    NI-SWITCH supports the NI USB-1359 under Windows 2000, Windows XP, and the 32-bit version of Windows Vista. NI-SWITCH does not support the NI USB-1359 under the 64-bit version of Windows Vista.
    If you are using a PXI product, notice that MXI-4 is supported under Windows Vista/XP/2000, but MXI-3 is supported under only Windows XP/2000.
    NI-SWITCH 4.0 and NI-DAQmx 9.0 support Windows Vista/XP/2000. It is recommended that you have the most recent service pack for your operating system installed. Earlier versions of NI-SWITCH/NI-DAQ support other operating systems. To find and download an earlier version of a driver that supports other operating systems, refer to ni.com/downloads.
    Minimum System
    • Processor—Pentium 200 MHz or equivalent
    • RAM—64 MB
    • A screen resolution of 800×600 with 256 colors
    • Windows XP/2000, with all available critical updates and service packs
    Recommended System
    • RAM—256 MB
    • A screen resolution of 1024×768
    • Windows Vista/XP/2000, with all available critical updates and service packs
    • LabVIEW 8.2.1, 8.5.1, 8.6.1, 2009 (32-bit), or 2009 (64-bit)
    • LabVIEW Real-Time Module 8.2.1 or later
    • LabWindows™/CVI™ 7.1.1 or later
    • LabWindows/CVI Real-Time Module 8.0 or later
    • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    • National Instruments file folder location, :
      • Windows 2000/XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows Vista: Users\Public\Documents\National Instruments
      • Windows 2000/XP/Vista 32-bit: Program Files\IVI Foundation\IVI\
      • Windows Vista 64-bit: Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        • Windows 2000/XP/Vista 32-bit: Program Files\IVI\
        • Windows Vista 64-bit: Program Files (x86)\IVI\
      • Windows Vista 64-bit: Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows XP/2000
    and Windows Vista
    NI-SWITCH\Drivers\niSwitch
    NI-SWITCH Function Panel\Drivers\niSwitch\niSwitch.fp
    NI-SWITCH Examples\niSwitch\Examples
    NI-SWITCH Header files\Include
    NI-SWITCH Import Library files (32-bit)\Lib
    NI-SWITCH Import Library files (64-bit)\Lib_x64
    NI-SWITCH DLL (32-bit)\Bin
    Additional File Locations for Windows Vista 64-bit
    ItemInstalled Location on Windows Vista 64-bit
    NI-SWITCH DLL (64-bit)\Bin
    Documentation is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
    • NI-SWITCH Readme File
    • Read Me First: Safety and Electromagnetic Compatibility
    Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
    • NI Switches Getting Started Guide
    Printed and PDF format. Includes hardware and software installation, MAX configuration, and signal connection information.
    • NI Switches Help
    HTML help format. Includes switching fundamentals, device specific information, programming information, tutorials, a LabVIEW VI reference, and LabWindows/CVI, C++, and Visual Basic function references.
    • NI Switch Specifications
    Printed and PDF format. Lists specifications for each NI switch module.
    • NI Switch Accessory Installation Instructions (Optional)
    Printed and PDF format. Lists NI switch module accessory installation information.
    Examples
    Refer to Start»All Programs»National Instrument»NI-SWITCH»Examples for the examples for the supported ADEs. The examples cover immediate operations, synchronous scanning, handshaking, and software triggering. A complete example list is available in the NI Switches Help.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    For Windows 2000/XP, complete the following steps:
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-SWITCH 4.x from the dialog box that appears.
    For Windows Vista, complete the following steps:
    As part of the NI-SWITCH installation, the following list of software was installed. To completely remove NI-SWITCH from your system, you must remove all of these packages also.
    • NI IVI Compliance Package 4.0
    • NI Measurement & Automation Explorer 4.6.1
    • NI-DAQmx 9.0
    • NI-VISA 4.5.1
    • NI Spy 2.7
    • niSwitch Can Connect Channels? VI
    • niSwitch Connect and Wait VI/function
    • niSwitch Control a Single Switch VI/function
    • niSwitch Disconnect and Wait VI/function
    • niSwitch Error-Query VI/function
    • niSwitch Get Error Info VI/function
    • niSwitch Is Debounced? VI
    • niSwitch Is Scanning? VI
    • niSwitch Query a Single Switch VI/function
    • niSwitch Read Calibration Data VI/function
    • niSwitch Scan VI/function
    • niSwitch Scanning Acquisition VI/function
    • niSwitch Write Calibration Data VI/function
    NOTE:  The niSwitch Can Connect Channels?, niSwitch Is Debounced?, and niSwitch Is Scanning? VIs were replaced by identical VIs without question marks in the name.
    The following are known issues for NI-SWITCH 4.0:
    • If you click a topic link in the NI-SWITCH Function Reference Help section of the NI Switches Help, you cannot use the Back button in the HTML Help window toolbar to return to the original topic.
    • When linking to a topic in the NI Switches Help from the context help or opening the help file from a VI within LabVIEW, the NI Switches Help launches and the relevant topic displays, but the location of the topic might not be highlighted in the table of contents.
    • Various support files, such as .h and .lib files, are installed in \Program Files\IVI and \VXIpnp directories to support ADEs that only recognize the \VXIpnp directory.
    • SCXI-1127 (Rev D and earlier) continuously drives the TTL1 trigger line on the SCXI backplane. This does not allow bus sharing of TTL1 with other SCXI modules. NI-SWITCH returns an error if an SCXI-1127 is in the chassis and if TTL1 is being used for scanning. If using the NI-DAQmx driver for your SCXI system, you get a resource reservation error if you try to perform a switching or signal conditioning operation that requires use of TTL1.
    • There are known DLL collision issues with the Microsoft Visual Basic debugger and a National Instruments device driver using Traditional NI-DAQ (Legacy). A support DLL used by NI-SWITCH fails to load if Visual Basic has already loaded another DLL into the same address space. To change the default address that is used to load the driver DLL, create the following registry key:
      \\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\NI-PAL\CurrentVersion\palConfig\Memory\
      sharedFixedAddress
      where the value is a DWORD (0x44000000 generally works). For the change to take effect, you must close and restart all applications after adding the registry key.
    • NI-DMM 2.2
      • NI-DMM 2.2 updated the niSwitch DMM Switch Handshaking example for LabVIEW. If you have an earlier version of NI-DMM installed, the VI is inoperable. To use the example with NI-DMM 2.1.2 or earlier, delete the AUX Trig 1 case from the case structure connected to Sample Trigger Source in the niDMM Configure Multi Point VI.
      • NI-DMM 2.2 introduces a new enumerated value, AUX Trig 1.
    • When you run setup.exe to install the software from the media, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using this product. These modes terminate any NI-SWITCH operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    • LabWindows/CVI
      The links in the function panel help in LabWindows/CVI versions 7.1 and 7.1.1 will not work unless you have downloaded the most recent version of the launchhelp.js file. Instructions for downloading and installing the file can be found in the KnowledgeBase entry Why Do I Get "Object Expected" Error When Opening Links in Function Panel Help? You can locate this KB by going to ni.com/info and entering rdnkbe in the Info Code field.
    • Reverting to NI-SWITCH 1.6 after installing NI-SWITCH 4.0
    If reverting back to NI-SWITCH 1.6 from NI-SWITCH 4.0, you must uninstall NI-SWITCH 4.0 and reinstall NI-SWITCH 1.6.
    Changes by Release4.0 from 3.8.5
    • Added support for LabVIEW 2009 (64-bit).
    • Added support for NI PXI-2510 and NI PXI/PXIe-2512/2514/2515/2531 modules.
    • Added support for Immediate Mode FIFO: This feature improves driver execution time of Immediate Mode Operations when operating multiple relays.
    • Added support for 64-bit user mode.
    3.8.5 from 3.8
    • Added support for LabVIEW 2009 (32-bit).
    • Removed support for LabVIEW 7.1.1.
    3.8 from 3.7.2
    • Japanese localization for driver, LabVIEW application programming interface (API), and documentation.
    • New behavior: Error and self test message strings now return localized values in LabVIEW. User applications that check the value of these strings (or trap errors by comparing the error cluster) might experience a change in behavior.
    © 1998–2009 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2025-12-12 19:31
